[ref]NOTORIOUS VR[/ref], u need extract files
--Run_Me
RunMe.app
[ref]thetristaan[/ref], use dpci manager what lan card u have
[ref]NOTORIOUS VR[/ref], DSDT.aml.zip
generate one ssdt for nativePM
https://Olarila.com/forum/viewtopic.php?f=28&t=10897
add shikigva=60 in bootargs for hardware accel
Thanks, I have done this but it tells me the CPU type is wrong when I run the script. I believe my CPU should be iMac12,1 or 12,3 which is an option but when I choose it my system doesn't boot into the OS anymore.
I went ahead anyway with the generation and copied both file to /ACPI/patched is that correct? Or do I need to find another way to force iMac 12,x?
[ref]NOTORIOUS VR[/ref], try with -no_compat_check bootargs
some smbios loose support, if don't work use imac13,2
This is the SMBIOS I have. When I run the script I get this output warning:
ssdtPRGen.sh v0.9 Copyright (c) 2011-2012 by † RevoGirl
            v6.6 Copyright (c) 2013 by † Jeroen
            v15.6 Copyright (c) 2013-2019 by Pike R. Alpha
Bugs > https://github.com/Piker-Alpha/ssdtPRGen.sh/issues <
gDataPath: /Users/sascha/Library/ssdtPRGen/Data
System information: Mac OS X 10.14.6 (18G103)
Brandstring 'Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz'
Scope (_PR_) {220 bytes} with ACPI Processor declarations found in the DSDT (ACPI 1.0 compliant)
Generating ssdt.dsl for a 'iMac13,2' with board-id [Mac-FC02E91DDD3FA6A4]
Sandy Bridge Core i7-2600K processor [0x206A7] setup [0x0703]
With a maximum TDP of 95 Watt, as specified by Intel
Number logical CPU's: 8 (Core Frequency: 3400 MHz)
Number of Turbo States: 4 (3500-3800 MHz)
Number of P-States: 23 (1600-3800 MHz)
Injected C-States for CPU0 (C1,C3,C6,C7)
Warning: 'cpu-type' may be set improperly (0x0703 instead of 0x0603)
Error: board-id [Mac-FC02E91DDD3FA6A4] not supported by Sandy Bridge – check SMBIOS data / use the -c option
Do you want to continue (y/n)? n
I said yes and generated the file anyway. Is that ok?
Also, is it ok to update to Catalina and copy over same CLOVER folder after (if needed)?
[ref]NOTORIOUS VR[/ref], no problem, ignore it and check if PM work good
Hi,
I finally managed to install Mojave. But i can't get Clover to work.
I have too SSD one with windows and the other with Mojave. I have install Clover on the Mojave SSD but the old windows mbdr is still here ( the sdd was use with windows before)
How can i erase the ols mbr and replace it with clover?
From now i have to use my usb stick to boot...
Thanks for your help.
[ref]Deferia[/ref], use Olarila clover folder to ur chipset, dont need install clover, just paste efi folder into efi partition
MaLd0n it's not working. My old windows MBR is taking the lead. I have to boot with the clover on my usb key. But everething is working. I have to use the igpu instead of my 1070. Hope nvidia is going to release drivers soon...
[ref]Deferia[/ref], forget nvidia in macos
use efi folder from ur usb stick
NOTORIOUS VR,
(14.8 KiB) Downloaded 2 times
Well I'm not sure what it is about your EFI folder but my GTX670 doesn't seem to be accelerated at all... video is extremely sluggish, even just resizing windows is very slow.
Sleep is not working either.
Any ideas?
[ref]NOTORIOUS VR[/ref], some hardware loose support u need check if ur system version support ur nvidia card
Hi,
I am looking to install macOS 10.15 Catalina on my Series 5 system. I have attached a dump taken from Clover. Could you please provide a patched DSDT and Clover folder for me to complete the Install.
Cheers
Specs: GA-P55A-UD4P - i5 750 - GT710
DSDT.zip
[ref]blu3_v2[/ref], DSDT.aml.zip
Use Olarila efi folder for serie 5
Thanks for the DSDT. I tried booting the macOS Catalina Installer from a USB containing the Olarila CLOVER folder in EFI, but received a Kernel Panic after Unsupported CPU and Unsupported PCH messages. Any ideas how to fix this?
Using Olarila Catalaina or Mojave image, on Sony Vaio Pro 13 (haswell) installer stucks on
"VoodooI2C: Got multitouch matched"
"VoodooI2C: Got multitouch preferences"
I've downloaded VoodooI2C.kext and add it with synaptics sattellite for this
But....
My touchpad it's PS/2 interface
any solution ? Thanks !
[ref]snaky90[/ref], use voodoops2
[ref]snaky90[/ref], :whistle
hello Sir, I am new to hackintosh wanna give it some try i have
i3 8100
Msi Mobo 310 Pro VDH
8gb ram 2400Mhz
120gb ssd
during instalation of high sierra my screen stuck at apfs_module_start:1279
i just download your setup and boot it from balena etcher because i use linux :help
[ref]priyansh.pj[/ref], Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here!
