[ref]cassaregh[/ref], try without weg.kext
cassaregh, try without weg.kext
I don't know how to include weg.kext. I successfully installed mojave. But my problems are the color of the monitor and PC won't boot without the USB inserted.
[ref]cassaregh[/ref], u need a boot from hdd/ssd
copy efi from usb stick or use Olarila clover folder for ur chipset
Hi Guys,
A few days back my ryzen hackintosh started to reboot randomly and also freeze, it starts usually after 3-5 sometimes more like 10 minutes on, doing things or just on with nothing running. i've attached the runme files to help clarify!
thanks since now!
Send me BENDs-Mac-Pro.zip
[ref]gsspipolo[/ref], amd don't have native support, etc
use it just for one lovely adventure lol :crazy:
Hey, can someone help me? i've tried to install Mojave and high sierra. When i tried to install mojave it boots perfectly, but it says that macOS can't be installed on my computer, so i tried to install high sierra but it even boots, i just got stucked on the black screen with a bunch of code lines. I'm using a i3 2100 with a h61m board, and i'm not using any gpu, only the intel onboard 2000 hd graphics. Can anybody help me? because idk if my hardware is not compatible or if im just doing the wrong thing.
*Im don't have any mac around, so im using windows to burn the Olarila image on the usb stick.
Onboard hd2000 is not supported. Get a supported gpu
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]efrost22[/ref], that will depend on your budget and usage. I hv no specific recommendations.
Donate
Gitter Chat
but it has a range of gpus that are compatible? sorry for being lazy, but i saw on google a lot of false information. I just need something cheap and compatible, i saw that nvidia gpus are no more working on mojave, so in any case i'll figure out something that works, but thanks for the support, peace!
I have hp EliteBook 840 g2
core i7 5600U cpu
display
intel hd graphics 500
AMD Radeon R7260X
ram 12gb
I want to install hackintosh
but I don't have any system running mac os that I can use to do the clover config
kindly help with how to configure efi using windows
[ref]MaLd0n[/ref], I'm having some problems with the AppStore.
My iCloud works fine, but I can't get the AppStore to work. It says I can't connect to the AppStore, and when I go and hit the update button on an application, ask me for my Apple ID and password, but it doesn't begin to download the update. A wheel appears and after a few seconds, the update button next to the app appears again, so I can't update any app. Also I can't download any app from the AppStore as well.
I have configured the SMBIOS with a new Serial Number, new SmUUID and new Board Serial Number. I did repair permissions and rebuild cache, and rebooted, configured iCloud and stuff. I experimented problems with iBooks also, when I log in.
Any ideas?
Thanks for the help and support!!! :guitar:guitar
[ref]pepe21[/ref], generate new smbios, delete files into library/preferences/systemconfiguration and reboot
[ref]MaLd0n[/ref], when I do it, my computer start freezing after reboot and UBS wifi adapter doesn't works, so I can't reconnect to internet. I put the files back in the folder.
The list of files is this one:
-ApplicationFirewallStartup.bundle
-CaptativeNetworkSupport.bundle
-EAPOLController.bundle
-InterfaceNamer.bundle
-InternetSharingPreference.bundle
-IPConfiguration.bundle
-IPMonitor.bundle
-KernelEventMonitor.bundle
-LinkConfiguration.bundle
-PPPController.bundle
-PreferencesMonitor.bundle
-PrinterNotifications.bundle
-QoSMarking.bundle
Maybe deleting some in stead of everyone of them?
Thanks!
[ref]pepe21[/ref], library in the root of the hd
Thanks for your help just over a year ago. I now have a new laptop and wonder if you can help with a DSDT.
HP Pavilion 15-cc665cl
Intel i7 8550U @ 1.8GHz - 4.0 GHz
12GB Ram
RTL8111 Ethernet
Insyde BIOS F.32
Intel Graphics UHD 620
Intel Wifi 3168 - Yes, I know I need to replace this.
I bought you a beer last year on May 27, 2018 18:53:16 EDT. I'd like to buy you another. :D
[ref]ancientbriton[/ref], hey
send me files
--Run_Me
RunMe.app
[ref]ancientbriton[/ref], replace full efi, reboot, check if work
EFI.zip
Some successes, but still some issues:
Bluetooth works, which it didn't before.
No Audio through speakers, which I did have working.
Bluetooth audio to my Bose portable speakers only works if I select the BT speaker as both input and output and is poor quality. This only works if I have the System Preferences -> Sound -> Input pane open.
Audio Fn keys seem to work ok
I now have a Backlight slider under preferences which works. Auto-Brightness doesn't work, but maybe that's because there is no light sensor. Brightness adjustment keys (fn-F2,fn-F3) do not work.
System Information says I have 1 processor with 4 cores, not 4 with 8. This was working:
Model Name: MacBook Pro
Model Identifier: MacBookPro14,1
Processor Name: Intel Core i7
Processor Speed: 1.99 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Hyper-Threading Technology: Enabled
Memory: 12 GB
Boot ROM Version: 196.0.0.0.0
Apple ROM Info: Apple ROM Version.
BIOS ID:MBP141.88Z.F000.B00.1905281616
EFI Version:196.0.0.0.0
Built by: Clover
SMC Version (system): 2.43f6
Touchscreen works, including 2 finger zoom and 2 finger scroll
Trackpad works, but no 2 finger actions
Webcam works
Card reader slot doesn't work, and I don't care.
My PCI devices now show up in System Info, which they did not before
Ethernet works great at 1Gbps
No battery information and no ability to have icon on bar:
Battery Information:
Charge Information:
Charging: No
Battery Installed: No
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 1
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Sleep on Power Button: Yes
Wake on LAN: Yes
AutoPowerOff Delay: 28800
AutoPowerOff Enabled: 1
Current Power Source: Yes
DarkWakeBackgroundTasks: 1
Display Sleep Uses Dim: Yes
GPUSwitch: 2
Hibernate Mode: 3
High Standby Delay: 86400
PrioritizeNetworkReachabilityOverSleep: 0
ProximityDarkWake: 1
Standby Battery Threshold: 50
Standby Delay: 10800
Standby Enabled: 1
TCPKeepAlivePref: 1
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Charging: No
Both USB 3.0 ports work. I don't know if USB-c works, as I have nothing to test it with.
Keyboard backlight key works, but auto control does not. I don't care.
It's better than it was. What next?
[ref]ancientbriton[/ref], extract new send_me
[ref]ancientbriton[/ref], audio, alc295, check here
https://Olarila.com/forum/viewtopic.php?f=28&t=9788
Hotkeys
https://Olarila.com/forum/viewtopic.php?f=28&t=8396
battery
https://Olarila.com/forum/viewtopic.php?f=28&t=8208
Added in 1 minute 35 seconds:
[ref]MaLd0n[/ref], one little fix _L6F
