Administrators MaLd0n Posted April 15, 2019 Author Administrators Posted April 15, 2019 [ref]pepe21[/ref], Clover folder and dsdt is same, just use -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepe21 Posted April 16, 2019 Posted April 16, 2019 pepe21, Clover folder and dsdt is same, just use MaLd0n, I tried 4 times now and I can't manage to get the touchpad working again. The FNKeys works fine and audio as well. I followed the steps you told me in the comments before, but doesn't fix the touchpad problem, it just doesn't work, I have to use an external USB mouse. I erase the HDD, partition it in 2, one with 120 GB and APFS for Mojave, the other one with 120GB and FAT 32 for windows. I install OS X Mojave and then I install Clover (last version) with UEFI only option and RC options enabled. After that I reboot, replace the cover files and then I execute the RunMe again. Reboot the system and replace the DSDT in EFI>CLOVER>ACPI>patched, I rebuild cache with sudo kextcache -i / in terminal and reboot the system again. Touchpad doesn't respond Do you know what can be happening? Am I doing something wrong? Here the RunMe: https://www.mediafire.com/file/3ea1im40x024mg2/Send_me_Vicentes-MacBook-Pro.zip/file Thanks for your time and support!
uran0s Posted April 16, 2019 Posted April 16, 2019 MaLd0n, Instalei uma placa wifi no meu sistema (BCM94360CS2). Aparentemente tudo funciona, wifi e bluetooth, embora não apareça nenhuma informação no PCI List do hardware. Dá para acrescentar? Envio em anexo ficheiro runme. uran0s5.zip Grande Abraço
Administrators MaLd0n Posted April 16, 2019 Author Administrators Posted April 16, 2019 [ref]pepe21[/ref], https://Olarila.com/forum/viewtopic.php?f=81&t=8238 Added in 2 minutes 35 seconds: [ref]uran0s[/ref], DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepe21 Posted April 16, 2019 Posted April 16, 2019 pepe21, viewtopic.php?f=81&t=8238 MaLd0N, I'm sorry for being so annoying, but I can't fix it neither with this tool. I tried but nothing changes, touchpad still not working. I wanted to tell you, the first time I uploaded the RunMe to the page I did some previous modifications (this way I could get the battery working) following a guide on another forum, but this guide is not online anymore and I can't manage to get everything as it was before. I've been trying for 2 days now, formatting the drive and starting all over again with different configurations, but nothing works... I can't get the touchpad to work. This is why I think maybe the files you upload before doesn't work now, because I modified something before the first RunMe I upload, and I can't do that modifications again because I can't find the guide I followed. Now I did a completely clean installation, I installed Clover with this options: -Clover for UEFI booting only -Install Clover in the ESP -UEFI Drivers: -AudioDxe-64 -DataHubDxe-64 -FSInject-64 -SMCHelper-64 -VBoxHfs-64 -Install RC Scripts on target volume After that I run RunMe again, and I uploaded it: https://www.mediafire.com/file/hsm1ham276ci990/Send_me_Vicentes-MacBook-Pro.zip/file Could you please help me? Sorry again for being so insistent with the same problem , and thanks in advance for the support!
Administrators MaLd0n Posted April 16, 2019 Author Administrators Posted April 16, 2019 [ref]pepe21[/ref], use only it wit last clover version CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepe21 Posted April 17, 2019 Posted April 17, 2019 pepe21, use only it wit last clover version CLOVER.zip (2.44 MiB) Downloaded 1 time MaLd0n, I installed Clover as UEFI and replaced the folders on EFI>CLOVER with the ones you send me. Audio works. FN Keys for audio works, but not for brightness. Battery percentage is always 0%. Touchpad doesn't work. Here is the new RunMe after replacing CLOVER folders: https://www.mediafire.com/file/grpv8ul1i24y2ei/Send_me_Vicentes-MacBook-Pro.zip/file Thanks!
Administrators MaLd0n Posted April 17, 2019 Author Administrators Posted April 17, 2019 [ref]pepe21[/ref], try kexts instead voodoops2 replace dsdt in clover/acpi/patched Arquivo Comprimido.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepe21 Posted April 17, 2019 Posted April 17, 2019 pepe21, try kexts instead voodoops2 replace dsdt in clover/acpi/patched Arquivo Comprimido.zip (525.33 KiB) Downloaded 1 time MaLd0n, kernel panic with that kext.
uran0s Posted April 17, 2019 Posted April 17, 2019 Added in 2 minutes 35 seconds: uran0s, DSDT.aml.zip Obrigado Mald0n. Um abraço
pepe21 Posted April 17, 2019 Posted April 17, 2019 (edited) MaLd0n, I finally fixed it! I tried with the first CLOVER files you sent me. First I install Clover again, then I put a FakeSMC.kext and Voodoo2PS2.kext I found on internet and reboot. I tried to boot from clover, but no boot option was appearing, so I rebooted again and boot from UBS image. After that, I tried replacing the CLOVER files you sent me on EFI>CLOVER and on EFI>CLOVER>OEM>SystemProductName. After that, I tried to boot from Clover, but the apple logo screen with the loading bar was taking soo much time to complete, so I restart manually and boot from USB image. Then I added the DSDT.aml file to EFI>CLOVER>ACPI>patched and EFI>CLOVER>OEM>patched and restart. Finally I could boot from clover with everything working perfectly and now I have a Dual Boot OS X Mojave and Windows 10 :guitar To try it again and learn what I was doing wrong, I erase and reinstall the system again, but copying the EFI folder so I could replace it after, but I don’t know why, when I replace it after a fresh installation of the SO and Clover, touchpad still not working, and I have to repeat the steps mentioned before. So, I have a question, because I can’t understand. Why is not working after a fresh installation when I replace the EFI folder that I used to boot with everything working on a previous install? Is it something related with kextcache? Thank you for everything and for all the support and time you offered me! Today beers are on me! Edited April 17, 2019 by Guest
Administrators MaLd0n Posted April 17, 2019 Author Administrators Posted April 17, 2019 [ref]pepe21[/ref], i think yes, run repair permission and rebuild cache -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
iFabio Posted April 22, 2019 Posted April 22, 2019 GTX 660 Hello Maldon replaced dsdt set in config.plist nvidia = true at black screen restart advice I7 4770K - Z97-PRO Wifi (ac) - Intel HD4600
Administrators MaLd0n Posted April 22, 2019 Author Administrators Posted April 22, 2019 [ref]iFabio[/ref], https://Olarila.com/files/Utils/nvidia-update.command.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
marcelosms Posted April 23, 2019 Posted April 23, 2019 Hello! Objective to install Mojave Send me iMac-de-Marcelo.zip
Administrators MaLd0n Posted April 24, 2019 Author Administrators Posted April 24, 2019 [ref]marcelosms[/ref], DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
marcelosms Posted April 24, 2019 Posted April 24, 2019 MaLd0n, I'm already thinking about the donation, but first I need a help, I made the installation with the image here of the forum but stopped at that point of the image ... yes and thanks for the DSDT and what could I do to have sleep?
Administrators MaLd0n Posted April 25, 2019 Author Administrators Posted April 25, 2019 [ref]marcelosms[/ref], u need one GPU, put one RX560 and avoid some problems, ur IGPU is very bad for new systems -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
marcelosms Posted April 26, 2019 Posted April 26, 2019 marcelosms, u need one GPU, put one RX560 and avoid some problems, ur IGPU is very bad for new systems Ok and as for the sleep in the High Sierra that I'm using now, it's not going to happen, any tips
Administrators MaLd0n Posted April 26, 2019 Author Administrators Posted April 26, 2019 [ref]marcelosms[/ref], what happens with sleep some serie 6, x79 have a very bug sleep -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepe21 Posted May 6, 2019 Posted May 6, 2019 MaLd0n, here is the RunMe file: https://www.mediafire.com/file/huq6el6rqookb9u/Send_me_Vicentes-iMac.zip/file Thanks!
Administrators MaLd0n Posted May 6, 2019 Author Administrators Posted May 6, 2019 [ref]pepe21[/ref], DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepe21 Posted May 6, 2019 Posted May 6, 2019 pepe21, MaLd0n, is not working, I put the DSDT.aml in CLOVER>ACPI>patched. Restart computer. Select the boot option for the Mojave and when it executes, screen stays in black, the light of the USB devices connected turn off. Nothing happens. Any clues? I can start Windows from another SSD with Clover without a problem, though. The only problem is with Mojave.
Administrators MaLd0n Posted May 6, 2019 Author Administrators Posted May 6, 2019 [ref]pepe21[/ref], the problem is not dsdt, is ur files, use Olarila clover folder check useful links https://Olarila.com/forum/viewtopic.php?f=62&t=9989 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
tsader Posted May 8, 2019 Posted May 8, 2019 Hey Mald0n, My system was running absolutely fine with your dsdt file until I backed up a bootable backup to a new drive. Now for some reason, it seems that the CPU is running a little hotter and fans a little more than usual. I have not changed anything, transferred the EFI to the new drive, made sure all necessary kexts are in /L/E folder... Average CPU cores temperature was at around 36 and now the average is 45.... Any Idea why this might be happening? Thanks
