[ref]uran0s[/ref], use somente essa pasta clover com a última versão do clover
CLOVER.zip
Hello Maldon
update 10.14.4 which KextsToPatch should I add for hardware in the signature
uran0s, use somente essa pasta clover com a última versão do clover
]Obrigado Maldon!! :)
Está tudo a funcionar menos o USB 3.0!
Envio novo runme.
Obrigado e grande abraço!
pedro2.zip
[ref]iFabio[/ref],
<dict>
			<key>Comment</key>
			<string>External icons patch</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			RXh0ZXJuYWw=
			</data>
			<key>InfoPlistPatch</key>
			<false/>
			<key>MatchOS</key>
			<string>10.13.x,10.14.x</string>
			<key>Name</key>
			<string>com.apple.driver.AppleAHCIPort</string>
			<key>Replace</key>
			<data>
			SW50ZXJuYWw=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 1 ©PMHeart</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g/sPD4cLBAAA
			</data>
			<false/>
			<key>MatchOS</key>
			<string>10.14.4,10.14.5</string>
			<key>Name</key>
			<string>com.apple.iokit.IOUSBHostFamily</string>
			<key>Replace</key>
			<data>
			g/s/D4cLBAAA
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 2 ©PMHeart</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			QYP/Dw+DlAQAAA==
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.usb.AppleUSBXHCI</string>
			<key>Replace</key>
			<data>
			QYP/Pw+DlAQAAA==
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 3 ©PMHeart</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g+MP0+NBCd8=
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<key>Replace</key>
			<data>
			g+M/0+NBCd8=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>MikeyDriver Patch Assertions</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			U291bmQgYXNzZXJ0aW9uIA==
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.AppleMikeyDriver</string>
			<key>Replace</key>
			<data>
			AAAAAAAAAAAAAAAAAAAAAA==
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 1 ©ydeng</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g/sPD4cWBAA=
			</data>
			<false/>
			<key>MatchOS</key>
			<string>10.14.3</string>
			<key>Name</key>
			<key>Replace</key>
			<data>
			g/s/D4cWBAA=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 2 ©ydeng</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g/sPD4OPBAAA
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<key>Replace</key>
			<data>
			g/s/D4OPBAAA
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 3 ©ydeng</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g+MP0+NBCd8=
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<key>Replace</key>
			<data>
			g+M/0+NBCd8=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>Prevent AGDP from loading</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			ugUAAAA=
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.AppleGraphicsDevicePolicy</string>
			<key>Replace</key>
			<data>
			ugAAAAA=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>Prevent Apple I2C kexts from attaching to I2C controllers</string>
			<key>Disabled</key>
			<true/>
			<key>Find</key>
			<data>
			U1U5TGFYUT0=
			</data>
			<true/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.AppleIntelLpssI2C</string>
			<key>Replace</key>
			<data>
			U1U5TGFYTT0=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<key>Disabled</key>
			<true/>
			<key>Find</key>
			<data>
			U1U5TGFYUT0=
			</data>
			<true/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.AppleIntelLpssI2CController</string>
			<key>Replace</key>
			<data>
			U1U5TGFYTT0=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB 10.13.6 by PMHeart</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g32IDw+DpwQAAA==
			</data>
			<false/>
			<key>MatchOS</key>
			<string>10.13.6</string>
			<key>Name</key>
			<key>Replace</key>
			<data>
			g32ID5CQkJCQkA==
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>AppleHDA Patch Assertions</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.AppleHDA</string>
			<key>Replace</key>
			<data>
			</data>
		</dict>
Added in 31 seconds:
[ref]uran0s[/ref], é só atualizar pro 10.14.4, vai funcionar
Added in 5 minutes 37 seconds:
[ref]uran0s[/ref], USE ESSE DSDT, REINICIE E RODA O RUN_ME DE NOVO
o usb é só atualizar
[ref]uran0s[/ref], parece legal, usb 3 ok agora
Hello Maldon
Thanks for the reply
question: using macOS mojave - Windows 10 - High Sierra from the config.plist how to set it in the GUI
[ref]iFabio[/ref], have all with correct matchOS
[ref]iFabio[/ref], 5HdOout.png
Hello Maldon
from the GUI of the config.plist how to set up the various hard disks
Hi!
This are my send me files.
https://www51.zippyshare.com/v/DEL0hjPf/file.html
I installed Mojave on my Asus UX410UA Laptop, because I have an Intel 620.
Audio, microphone, touchpad and FN keys are not working. I managed to get the battery indicator, but that's pretty much of what I achieve. :help
Neither Bluethoot and wifi, but that's because I need to buy a different model. I'm using an USB ethernet adapter and works like charm! :D
Thank you so much for the help and support! You deserve the beer! ;)
[ref]pepe21[/ref], use it with last clover version, reboot and extract new send_me
CLOVER.zip
pepe21, use it with last clover version, reboot and extract new send_me
CLOVER.zip
MaLd0n, I installed again the last Clover version (config set as default) and copied the content of the CLOVER.zip you attached on the previous comment. Now audio is working fine, and also the volume controls on the FN keys, but the bright keys are not working properly, I just can turn on/off the screen, but not get up/down the brightness on the screen.
The touchpad is not working, and also Siri is malfunctioning.
When I turn on the computer after the reboot, an iCloud error jumped to the screen, seems like my password wasn't stored.
Any clues about how to fix this?
This is the send_me generated after the reboot.
https://www83.zippyshare.com/v/coG0ikkR/file.html
Thank you again for the support! :):guitar
[ref]pepe21[/ref], replace dsdt
rebuild cache
configure ur hack again, icloud etc
[ref]iFabio[/ref], DSDT.aml.zip
(38.86 KiB) Downloaded 2 times
rebuild cache
Hi MaLd0n, thank you for everything! The touchpad works like charm now, and I can use a properly Mackintosh experience, but the only problem I face is the one with the Apple accounts. I can log in into iCloud, but I can't download any apps from AppStore, I can't neither use iMessage or FaceTime. iMessage and FaceTime could be disabled for good if there is not an easy fix for that, but I would love to be able to download apps from the AppStore. Any suggestion in order to fix this problem?
Thanks a lot for your time and effort! :guitar:D:guitar
[ref]pepe21[/ref], generate new smbios with clover configurator, run it, and reboot, configure again
iMessage.FaceTime.command.zip
Hi there guys! New Hackintosh venturer here. I'm trying to make a hackintosh out of a Dell Precision T3600. However I'm getting stuck at kexts stall [n] (240s) AppleACPICPU. Any clues as to why this might be happening? Thanks!
[ref]tristan.jorge[/ref], use last clover version and use apfs.efi instead ApfsDriverLoader-64.efi
this clover is only for uefi
Clover_v2.4k_r4919.pkg.zip
Hi again MaLd0n,
I was trying to do a dual boot for OS X Mojave and Windows 10 and when I was installing Windows 10 there was an error and I couldn't complete installation.
I had to format the HHD and now I installed again OS X Mojave, but using the fixes you told me before, is not working...
Would you mind to check out again my RunMe file?
I just did a clean installation with the image, and didn't installed clover or anything, just run the RunMe app, I uploaded the file here
https://www.mediafire.com/file/4p4f24m4cwa97nd/Send_me_Vicentes-MacBook-Pro.zip/file
Thank you again in advice for your support!
