Administrators MaLd0n Posted February 23, 2019 Author Administrators Posted February 23, 2019 [ref]Mo8r3[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
student_al Posted February 25, 2019 Posted February 25, 2019 Thank you for your suggestion MaLd0n about program ResXtreme but unfortunately it does not work. I decided to replace my current card(MSI rx 560) with an old card(XFX 5770) I did not have any problems with. I have one question for you: Is it reasonable to buy i7-3770 or i7-3770K and replace my current CPU: i7-2600K? Is it worthwhile in terms of better compatibility with MACOS? I already know that Sandy Bridge has some problem with MACOS. I read that Ivy Bridge handle much better than Sandy Bridge in terms Power management for example.
Administrators MaLd0n Posted February 26, 2019 Author Administrators Posted February 26, 2019 [ref]student_al[/ref], yes, 3770k is good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
student_al Posted February 27, 2019 Posted February 27, 2019 MaLd0n, I replaced i7 2600k with i7 3770k. I successfully boot after CPU replacement but now I need help about DSDT and SSDT. I hope you will help me as always.
Administrators MaLd0n Posted February 27, 2019 Author Administrators Posted February 27, 2019 [ref]student_al[/ref], post ur files for power management run it and put ssdt.aml ion clover/acpi/patched too https://Olarila.com/files/Utils/ssdtPRGen.command.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
FaRa62 Posted March 23, 2019 Posted March 23, 2019 -FIX ERRORS AND WARNINGS -HPET -SATA -DMAC -SLPB -DARWIN -EHCI -XHCI -PLUGIN TYPE -XXXX to HDEF -HDEF -RTC -IRQs -SBUS -MIKEY -BUS1 -MCHC -ALS0 -SHUTDOWN -LAN -USBX -IMEI -EC -PNLF -GFX0 -HDAU -NVME -ARPT -INTELHDGRAPHICS
Administrators MaLd0n Posted March 23, 2019 Author Administrators Posted March 23, 2019 [ref]farabetis[/ref], ??? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
haydendo Posted March 26, 2019 Posted March 26, 2019 Hello. I'm trying to install Mojave on my ThinkPad T420S using the Olarila Mojave image but I'm getting a message "This version of macos 10.14.3 cannot be installed on this computer". Previous versions (High Sierra) installed successfully. Can this be fixed using Clover changes, or by a Mojave Patcher? Please help. Thank you. Added in 45 minutes 3 seconds: Solved it. I used iMac 18,3 for SMBIOS.
nafjang Posted March 26, 2019 Posted March 26, 2019 help me install problem i3 8100 MSI H370 Gaming plus This version of macos 10.14.3 cannot be installed on this computer AMFILoadTrustedKeysFromNVRam: No NVRam Available"
Administrators MaLd0n Posted March 26, 2019 Author Administrators Posted March 26, 2019 [ref]nafjang[/ref], don't use a last bios/uefi version, use previous version -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted March 26, 2019 Author Administrators Posted March 26, 2019 [ref]nafjang[/ref], go to manufacturer site and check bios/uefi versions -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted March 26, 2019 Author Administrators Posted March 26, 2019 [ref]nafjang[/ref], https://www.msi.com/Motherboard/support/H370-GAMING-PLUS -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
nafjang Posted March 27, 2019 Posted March 27, 2019 [ref]MaLd0n[/ref], bios ver 7B22v16 Finished update
nafjang Posted March 29, 2019 Posted March 29, 2019 [ref]MaLd0n[/ref], Which version should I use? Ver 1.5,1.4,1.3,1.2 Currently using this version 1.6
Administrators MaLd0n Posted March 29, 2019 Author Administrators Posted March 29, 2019 [ref]nafjang[/ref], is a last version? if yes, done -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
nafjang Posted March 30, 2019 Posted March 30, 2019 [ref]MaLd0n[/ref], nafjang, is a last version? if yes, done Yes ver 1.6 a last version
Administrators MaLd0n Posted March 30, 2019 Author Administrators Posted March 30, 2019 [ref]nafjang[/ref], and error stay there? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted March 31, 2019 Author Administrators Posted March 31, 2019 [ref]nikhilpal2705[/ref], u don't need use kexts in l/e or s/l/e, put in clover/kexts/other and set inject -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted March 31, 2019 Author Administrators Posted March 31, 2019 [ref]nikhilpal2705[/ref], Someone needs to pay the expense. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
devhost97 Posted April 1, 2019 Posted April 1, 2019 Where is the link for notebook chipset series ? I didn't see them now.
Administrators MaLd0n Posted April 1, 2019 Author Administrators Posted April 1, 2019 [ref]devhost97[/ref], https://Olarila.com/forum/viewtopic.php?f=28&t=8222 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
uran0s Posted April 3, 2019 Posted April 3, 2019 Olá mald0n! Precisava que me criasses um dsdt e configuração do config.plist, por favor. - Z87n wifi - i5 4570 - Radeon Vega 56 Pulse Obrigado, grande abraço!! pedro.zip
