[ref]pangu74[/ref], :guitar
MaLdOn,
i used the Olarila image for mojave but after clover some scripts/text are running on my screen which tells Unsupported cpu
Unsupportes pch but after that it enters installation fine after reboot for installation it tells installation failed error occured
my processor is core 2 quad 9550
cpu dell vostro 230
6gb ram
1 tb hardisk
[ref]abivishvas[/ref], ur processor dont wor in Mojave, native no, u need mod some files
check here
http://dosdude1.com/software.html
Hi MaLd0n
I see there are couple fix in the Acpi/Fixes. Do I need all that? or it depends on what I need?
I also see Boot has -No_Compat_check, but my old one has shikigva=60, do i still need it?
or I can just replace entire confit.plist?
[ref]zoe934[/ref], post ur clover folder here
[ref]zoe934[/ref], looks good
[ref]zoe934[/ref],
update what?
[ref]zoe934[/ref], CLOVER.zip
[ref]zoe934[/ref], :guitar
[ref]khicon9[/ref], use bootkey for boot
[ref]khicon9[/ref], AHCI is enable?
is a nvme?
