is a XFX card?
[ref]Sarbaz[/ref], u use Olarila Image?
No luck for me. The same thing with SMBIOS to iMac 13.1.
No luck with ssd, when I put an hd, I've got a KP when 2 mn remaining ...
I also try to install with usb disk (install from osx to usb ssd disk, and then put the ssd sata, but clover doesn't see the ssd :(
NB : I'm in legacy mode, no UEFI with my motherboard.
Did someone have an idea ?
(I will try Mojave tomorrow or after tomorrow)
[ref]farniera[/ref], in insanelymac have one topic about it, check there
I have a few small problems, can you help me?
I asked the DSDT Patch a few days ago and I'm very grateful for that, so now I'm having a problem when I close the screen (lid close) when I wake up the screen with the power button. However, the screen does not show up (black). I'm just the only way is shut off and restarted by pressing and holding the power button down.
I can not adjust the brightness of the screen, you can guide me fixed it. I have re-created the send me item and attached it below.
My display: https://drive.google.com/open?id=123tpOMrmn8kE5yMMDURWU-9byCfjEUiC
I look forward to hearing from you, thank you very much.
Send me Nguyens-MacBook-Air.zip
[ref]DiegoIrineu3nd[/ref], DSDT.aml.zip
delete Apple folder in EFI too
Hi MaLd0n,
I've got macOS Mojave up and running all thanks to you & Olarila.com.
I've got a Asrock Z75 Pro3 motherboard.
All my USB ports , HDMI, LAN port, back audio works.
Only my front HD Audio port doesn't work right now.
I've got the Realtek ALC892 Audio Codec on my motherboard.
I've attached my send_me file below.
https://www85.zippyshare.com/v/W8aBhptN/file.html
Hope you can help me out with the DSDT.
[ref]InfamousGamer[/ref], DSDT.aml.zip
Audio check here
Hi [ref]MaLd0n[/ref], I got this output while trying to map brightness keys. Can you guide me what to do next? Thanks...
2018-11-07 13:38:09.149916+0800 0x2451     Default     0x0                  520    kextcache: kext-dev-mode allowing invalid signature -67062 0xFFFFFFFFFFFEFA0A for kext ACPIDebug.kext
2018-11-07 13:42:03.964222+0800 0xae       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: Version 0.1.4 starting on OS X Darwin 16.7.
2018-11-07 13:42:04.155843+0800 0xe7       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q47 enter"
2018-11-07 13:42:04.167077+0800 0xe7       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q47 exit"
2018-11-07 13:44:42.929876+0800 0x76       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q11 enter"
2018-11-07 13:44:42.929974+0800 0x76       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q11 exit"
2018-11-07 13:44:54.264982+0800 0xf8       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 enter"
2018-11-07 13:44:54.265085+0800 0xf8       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 exit"
2018-11-07 13:44:54.527712+0800 0x145      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 enter"
2018-11-07 13:44:54.527813+0800 0x145      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 exit"
2018-11-07 13:44:55.094122+0800 0x145      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 enter"
2018-11-07 13:44:55.094222+0800 0x145      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 exit"
2018-11-07 13:44:59.605046+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q11 enter"
2018-11-07 13:44:59.605148+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q11 exit"
2018-11-07 13:45:33.081570+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 enter"
2018-11-07 13:45:33.081671+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 exit"
2018-11-07 13:45:37.591301+0800 0x76       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q11 enter"
2018-11-07 13:45:37.591405+0800 0x76       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q11 exit"
2018-11-07 13:49:59.045109+0800 0xf8       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 enter"
2018-11-07 13:49:59.045212+0800 0xf8       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 exit"
2018-11-07 13:49:59.614259+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 enter"
2018-11-07 13:49:59.614395+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 exit"
2018-11-07 13:50:03.218273+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q11 enter"
2018-11-07 13:50:03.218439+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q11 exit"
2018-11-07 13:50:04.087818+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 enter"
2018-11-07 13:50:04.087922+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 exit"
2018-11-07 13:50:04.502299+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 enter"
2018-11-07 13:50:04.502410+0800 0x535      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 exit"
2018-11-07 13:50:07.344070+0800 0xf8       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 enter"
2018-11-07 13:50:07.344176+0800 0xf8       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 exit"
2018-11-07 13:50:08.517105+0800 0x145      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 enter"
2018-11-07 13:50:08.517211+0800 0x145      Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q12 exit"
2018-11-07 13:50:58.234934+0800 0xf8       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q11 enter"
2018-11-07 13:50:58.235046+0800 0xf8       Default     0x0                  0      kernel: (ACPIDebug) ACPIDebug: "EC _Q11 exit"
[ref]pangu74[/ref], _Q11, _Q12?
just apply patch with it
Added in 42 seconds:
[ref]InfamousGamer[/ref], extract new SEND_ME
RunMe.app
pangu74, _Q11, _Q12?
now brightness keys are working but Fn+F12 & Pause/Break BTN still adjust brightness too? How to apply the patch? Edited by Guest
[ref]pangu74[/ref], idk u need test
