Hi to everyone,
trying to install high sierra. Burned image to usb stick and replace clover folder. After restart i,m getting kernel panic please any ideas?
What should i do next?
45285162_258232221556732_4127336414654234624_n.thumb.jpg.bd96a3c423a10e9a6deeed2a76a20f51.jpg
I have GTX 560 ti . QE/CI works with high sierra with Inject nvidia . but with Mojave QE/CI doesn't even work with Inject nvidia.and there is no webdriver for mojave yet. How can I make it work in Mojave?
Added in 3 minutes 39 seconds:
linhvk,
(48.75 KiB) Downloaded 4 times
Hi MaLd0n, after install OS 10.12.6 on HP 2570p, I run script from this guide (https://www.tonycrapx86.com/threads/guide-hp-probook-elitebook-zbook-using-clover-uefi-hotpatch.261719/) >>> I've all kext (have sound, full ram.....) but 1. No power management (it has no % baterry) and 2. laptop will be restart when click shutdown >> please help me to fix that.
sorry for my bad English
Hi MaLd0n,
Quick question, the DSDT you supplied to me works perfectly. Do I update to 10.14.1 as normal through the app store or do I have to renew the DSDT file?
Thx
[ref]terorero[/ref], no change, don't appears nothing
Added in 4 minutes 52 seconds:
[ref]stonelion[/ref], DSDT.aml.zip
Use our clover folder for ur chipset, check our app
Added in 33 seconds:
[ref]matsovagos[/ref], try other fakesmc version
Added in 34 seconds:
[ref]jinkaal420[/ref], mojave kill old hardware, need a new, u can use drivers High Sierra in Mojave, work
Added in 1 minute 1 second:
[ref]linhvk[/ref], PM in ivy bridge use kernelXCPM+PlugIn tupe in config.plist
Added in 20 seconds:
[ref]tsader[/ref], DSDT is bios, principal table, work for all systems
Hi [ref]MaLd0n[/ref], how are you, can you help me once agin. I have a working audio, but I notice no digital output. Currently using AppleALC, have tried all id but have same result. I want to try patch AppleHDA but when I open ApplePatcher it says Found more than one "Device (HDAU/B0D3)" inside your ACPI tables. Please remove those excessive!,
[ref]pangu74[/ref], use a Mirone topic about audio, AppleHDAPatcher
linhvk, PM in ivy bridge use kernelXCPM+PlugIn tupe in config.plist
Plugin Type = true (use Plist Editor Pro: ACPI/SSDT/Generate/PluginType)
KernelXCPM = Yes ( KernelAndKextPatches)
>>> nothing happen
[ref]linhvk[/ref], u need check in ioreg if x86platform is loaded
Added in 18 seconds:
[ref]pangu74[/ref], u need a debug.kext for check what patch u need
Good night! MaLd0n
I have a Computer and I want to make a Hackintosh on it!
Could you help me?
Basic Configuration:
Motherboard: ASUS H81M-A
Processor: Core i3 4160 3.60 GHz
Intel HD Graphics 4400 Video Card (1024)
AMD Radeon HD 5670 Video Card (512 MB)
Intel ® 8 Series / C220 Family Chipset SATA AHCI Controller
8 GB of RAM
Full configuration more DSDT Extracted System with EVERAST
Just below the link:
INFO CONFIG ASUS H81M-A.zip
Thank you for your attention!
Regards - Arnaldo Junior
[ref]AJProjetos[/ref], DSDT.aml.zip
linhvk, u need check in ioreg if x86platform is loaded
hic, I open IOreg and doesn't find anything about KernelXCPM and PluginType, I don't understand what you write, please detail for me, thank you
How do I create the bootable USB stick on the Windows of the High Sierra?
And you have some kexts package that I can use or one to do the correct installation?
For this configuration:
8 GB of RAM
[ref]linhvk[/ref], work
Added in 15 seconds:
[ref]AJProjetos[/ref], just check our app
Added in 38 seconds:
[ref]matsovagos[/ref], idk, never see it, remove smchelper driver and update clover bootloader
Hi [ref]MaLd0n[/ref], tried dual booting with Mojave and Windows 10 successfuly, just notice that my audio in Mojave suddenly lost? any advice? thanks in advance.
