acquarius13 Posted November 23, 2018 Posted November 23, 2018 Booting is ok, but sleeping is not working properly: closing the lid, it goes to sleep. Opening it, it wakes but I have a completely black screen. Thank you so much for your kind help Latitude E7450, BIOS A23 | i5-5300u 2.3 GHz | 8GB DDR3 | Intel HD 5500, 1920x1080 | Dell DW1560 | Catalina 10.15 | Clover | Sleep, Yes HP Probook 450 G5, BIOS 01.09.01 | i7-8550u 1.9 GHz | 16GB DDR4 | Intel UHD 620, 1920x1080 | Dell DW1560 | Catalina 10.15 | Clover | Sleep, Yes
V2Ray Posted November 24, 2018 Posted November 24, 2018 (edited) Hello! Well, come to the point. My laptop is Lenovo Thinkpad series W540, cpu is intel Core i7 4930MX, 32G RAM, and there're 2 graphic card, intel HD 4600 and NVIDIA Quadro K2100M installed. I'm trying to use the Olarila image to install macOS Mojave(GM ver). When my computer identified the Olarila image and start loading the installation, however, it seized up while it loading (it stuck at the log(terminal?) screen). And after a couple minutes, the screen turns black but i can still hear the fan. I already disabled USB3.0 port and VT-d. Actually, I can't find CFG-Lock and AHCI setting in the BIOS setting menu so I'm not sure that are they enabled or not. I've trying to hackintosh many times, but never success. I'd tried to use clover or chameleon to boot the image, but it won't work. Also I can't find any config or EFI files are suitable for my computer. So Olarila might be my last hope Thanks for help anyway! waiting for reply! Edited November 24, 2018 by Guest
Administrators MaLd0n Posted November 24, 2018 Author Administrators Posted November 24, 2018 [ref]V2Ray[/ref], post one photo -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
V2Ray Posted November 24, 2018 Posted November 24, 2018 Boot Setting USB Setting Clover Menu Black Screen While Loading
Administrators MaLd0n Posted November 24, 2018 Author Administrators Posted November 24, 2018 [ref]V2Ray[/ref], u need select a image, not shell -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
V2Ray Posted November 24, 2018 Posted November 24, 2018 What do you mean? Sorry I'm not that good about english
Administrators MaLd0n Posted November 24, 2018 Author Administrators Posted November 24, 2018 [ref]V2Ray[/ref], Select macosinstall -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
V2Ray Posted November 25, 2018 Posted November 25, 2018 You mean the boot menu? I already select it, and as I told you it stuck while loading and the screen turn black after that
Administrators MaLd0n Posted November 25, 2018 Author Administrators Posted November 25, 2018 [ref]V2Ray[/ref], rec one movie, u extract image to .raw before burn? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
marvss4 Posted November 26, 2018 Posted November 26, 2018 i have a question can i change my SMBIOS to like iMac late 2015 something on my current hardware specs? right now my SMBIOS is iMac 13,2 on El Capitan, im also gonna test Mojave if my GT 730 DDR3 will work.
popo Posted November 26, 2018 Posted November 26, 2018 I maLd0n if you have 5 min... thank you Send me Macs-iMac.zip
Administrators MaLd0n Posted November 26, 2018 Author Administrators Posted November 26, 2018 [ref]popo[/ref], use only this folder with last clover version CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted November 26, 2018 Author Administrators Posted November 26, 2018 [ref]popo[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
V2Ray Posted November 27, 2018 Posted November 27, 2018 Mald0n I’m sure that I’ve extracted install image to raw, or I can’t get to the clover loading screen. I’ll try to rec if I face the same problem after I reburn the image
Administrators MaLd0n Posted November 27, 2018 Author Administrators Posted November 27, 2018 [ref]andres6969[/ref], http://www.acpi.info/spec.htm -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted November 27, 2018 Author Administrators Posted November 27, 2018 [ref]andres6969[/ref], need a many time, read, many hardwares, etc i start in 2007, have all chipsets in my brain -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted November 27, 2018 Author Administrators Posted November 27, 2018 [ref]andres6969[/ref], in DSDT, u can use a txt editor or MacIasl Have a some new patches after serie 300 release --DSDT Patches-- -FIX ERRORS AND WARNINGS -FIX ACPI ERRORS -REMOVE UNUSED DEVICES -HPET -SATA SERIE 10 ID -DMAC -SLPB -DARWIN -XHCI -PLUGIN TYPE -HDAS to HDEF -HDEF -RTC -IRQs -SBUS -MIKEY -BUS1 -MCHC -ALS0 -SHUTDOWN -LAN 1 -LAN 2 -USBX -PMCR -PPMC -XSPI -GMM -IMEI -EC -PNLF -ARPT -GFX0 -NVME 1 -NVME 2 -HDMI / HDAU -FULL RENAMED DEVICES -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted November 28, 2018 Author Administrators Posted November 28, 2018 [ref]andres6969[/ref], use our clover folder for serie 8 check out app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jikx19 Posted November 30, 2018 Posted November 30, 2018 hi there, trying to install (Olarila Mojave 10.14.1.raw) with your guide, and getting this. my configuration is hp probook 640 g1. processor = i5 4200m graphics = hd 4600 thanks
Administrators MaLd0n Posted November 30, 2018 Author Administrators Posted November 30, 2018 [ref]jikx19[/ref], uncheck injectintel for install, u can use -x too -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jikx19 Posted November 30, 2018 Posted November 30, 2018 thanks for the quick reply, with -x i was able to see the apple logo, but than again this screen
Administrators MaLd0n Posted November 30, 2018 Author Administrators Posted November 30, 2018 [ref]jikx19[/ref], just install without inject video, if dont work, u can check here https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v165/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
popo Posted December 1, 2018 Posted December 1, 2018 I maldOn, I followed your instructions but it blocks the reboot
Administrators MaLd0n Posted December 1, 2018 Author Administrators Posted December 1, 2018 [ref]popo[/ref], i don't remember, extract new send_me -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
