[ref]kar2wlan[/ref], check rehabman tutorial about it
Added in 43 seconds:
[ref]uran0s[/ref], [ref]mamaro[/ref], excluam as portas não usadas, dessa forma vc não precisa mais do limit port em nenhum sistema
uran0s, mamaro, excluam as portas não usadas, dessa forma vc não precisa mais do limit port em nenhum sistema
excluir através de DSDT? ou SSDT? algum tutorial?
I am Trying to Install mojave on my old laptop. with Lenovo G560 i3 380m + igpu. which smbios should I set? I can boot to mac install screen but cant install as it say "This Version os macos 10.14 cannot be installed in this computer"
[ref]jinkaal420[/ref], u need a supported smbios
idk u need test, one with support in Mojave
[ref]pangu74[/ref], have a simpla patch in config.plist for it, u can just ignore too ;)
[ref]pangu74[/ref], u need use google for search it, i don't have any notebook now for test
[ref]MaLd0n[/ref], Thank you for so much help...Try to changed resolution, and my logon screen was fix, but on apple logo still have distorted display, I can live with that though :mrgreen: , but can you make one test patch on my plist and I will test it :)
[ref]pangu74[/ref], :guitar
[ref]Simania_NL[/ref], yes, now all ppl need it, u can use flag too instead ssdt
terorero, check what cause it
MacBook-Pro:~ terorero$ log show --style syslog | fgrep "Wake reason"
Para Dios el futuro es historia..!
Hi to everyone,
trying to install high sierra. Burned image to usb stick and replace clover folder. After restart i,m getting kernel panic please any ideas?
What should i do next?
45285162_258232221556732_4127336414654234624_n.thumb.jpg.bd96a3c423a10e9a6deeed2a76a20f51.jpg
I have GTX 560 ti . QE/CI works with high sierra with Inject nvidia . but with Mojave QE/CI doesn't even work with Inject nvidia.and there is no webdriver for mojave yet. How can I make it work in Mojave?
Added in 3 minutes 39 seconds:
linhvk,
(48.75 KiB) Downloaded 4 times
Hi MaLd0n, after install OS 10.12.6 on HP 2570p, I run script from this guide (https://www.tonycrapx86.com/threads/guide-hp-probook-elitebook-zbook-using-clover-uefi-hotpatch.261719/) >>> I've all kext (have sound, full ram.....) but 1. No power management (it has no % baterry) and 2. laptop will be restart when click shutdown >> please help me to fix that.
sorry for my bad English
Hi MaLd0n,
Quick question, the DSDT you supplied to me works perfectly. Do I update to 10.14.1 as normal through the app store or do I have to renew the DSDT file?
Thx
[ref]terorero[/ref], no change, don't appears nothing
Added in 4 minutes 52 seconds:
[ref]stonelion[/ref], DSDT.aml.zip
Use our clover folder for ur chipset, check our app
Added in 33 seconds:
[ref]matsovagos[/ref], try other fakesmc version
Added in 34 seconds:
[ref]jinkaal420[/ref], mojave kill old hardware, need a new, u can use drivers High Sierra in Mojave, work
Added in 1 minute 1 second:
[ref]linhvk[/ref], PM in ivy bridge use kernelXCPM+PlugIn tupe in config.plist
Added in 20 seconds:
[ref]tsader[/ref], DSDT is bios, principal table, work for all systems
