orozcopc Posted October 23, 2018 Posted October 23, 2018 please help me with this kernel panic, I'm stuck trying install Anonymous UUID: 1FED4A85-AD5F-0DE5-4E9C-71C41E80A6AE Tue Oct 23 11:23:54 2018 *** Panic Report *** panic(cpu 0 caller 0xffffff7f9bae8cd5): "Panic on FB memory manager Init. Required stolen memory size (58720256 bytes) is higher than available (33550336 bytes)\n"@/Library/Caches/com.apple.xbs/Sources/GPUDriversIntel/GPUDriversIntel-12.0.34/Common/IONDRV/Intel/BDW/AppleIntelFramebuffer/AppleIntelController.cpp:21621 kernel_panic.txt
Administrators MaLd0n Posted October 23, 2018 Author Administrators Posted October 23, 2018 [ref]CamBuff[/ref], yes, work Added in 16 seconds: [ref]orozcopc[/ref], https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v153/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
CamBuff Posted October 24, 2018 Posted October 24, 2018 CamBuff, yes, work Added in 16 seconds: orozcopc, https://www.insanelymac.com/forum/topic ... cher-v153/ Thank you! Let me try it out.
Administrators MaLd0n Posted October 25, 2018 Author Administrators Posted October 25, 2018 [ref]CamBuff[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
romanoz Posted October 26, 2018 Posted October 26, 2018 (edited) can you patch my file please. https://drive.google.com/file/d/1VzBXYE2yeu4ctJzrLV0dqvKqrEYUcVux/view?usp=sharing donated Edited October 26, 2018 by Guest
mr.vs_k Posted October 26, 2018 Posted October 26, 2018 hello bro possible to send me folder My pc gtx 1050 Mobo z270d3hm I5 7600k 16gb ram 250gb ssd
Administrators MaLd0n Posted October 26, 2018 Author Administrators Posted October 26, 2018 [ref]romanoz[/ref], DSDT.aml.zip Added in 27 seconds: [ref]mr.vs_k[/ref], post files RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Simania_NL Posted October 26, 2018 Posted October 26, 2018 Great, great work guys (girls)! Kudos Hereby my files, maybe you find time to take a look at it. https://www15.zippyshare.com/v/hLM7gALh/file.html I'm running on a i7-4770K with a Gigabyte Z97X-UD7 TH. Many regards in advance! Simania
Administrators MaLd0n Posted October 26, 2018 Author Administrators Posted October 26, 2018 [ref]Simania_NL[/ref], Hey here CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Simania_NL Posted October 26, 2018 Posted October 26, 2018 Whoooooo @MaLd0n that was very quick! Thank you very much, I owe you a donate-beer or two! Two questions, first, at this moment I disabled the thunderbolt functionality in the BIOS, do I need a new DSDT when I enable it? And second, my internal Intel HD4600 shows as it is connected to the firewire port. Is this as it supposed to be, or can it be changed in de DSDT? Once again many regards for your great work. Cheers!
Administrators MaLd0n Posted October 26, 2018 Author Administrators Posted October 26, 2018 [ref]Simania_NL[/ref], enable THUNDERBOLT and test about video, is just cosmetic enable TB and extract new send me Added in 10 seconds: [ref]romanoz[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Saqsy Posted October 27, 2018 Posted October 27, 2018 Getting stuck at this. Tried to replace aptiomemory in clover didn't work. Using your Olarila mojave image. Trued both config and config2 Hp touchsmart 15-r052nr laptop I3 4th gen
djsova Posted October 27, 2018 Posted October 27, 2018 Wrote the extracted raw from Olarila mojave bz2 archive on my 8 gb usb via elevated Win32DiskImager (the hash dropdown was left blank, default) and tweaked the bios settings on my mobo. usb first to boot, onboard video, and i tried loading it without kexts, with kexts, every time I get the same error. After the ++++ screen shows the scrolling text for 20 seconds, it stops at @kec.Libm 1 @kec.pthread 1 @kec.corecrypto 1.0 Please go to panic.apple.com to report this panic What could be the cause of this? The computer is offline and blank SSD is inside. --- EDIT : tried disabling onboard gpu and went with the 580, also did "without kexts" boot and there's progress, installation is going on. Hopefully all will be alright, this is my first attempt at hackintosh. ------ EDIT 2 : Mojave installation finished, now I have to fine tune I guess. Thank Olarila! Everything shows up correctly in About This Mac so not sure how to spot the fixes I need. But I'll figure it out. Thanks! Obrigado!
Administrators MaLd0n Posted October 27, 2018 Author Administrators Posted October 27, 2018 [ref]Saqsy[/ref], u need change some config for discovery problem Added in 44 seconds: [ref]djsova[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
achill3 Posted October 28, 2018 Posted October 28, 2018 Hi MaLd0n I installed High Sierra on my PC and I need ur help please. Send me MacBook-Pro-de-Achille.zip
Administrators MaLd0n Posted October 28, 2018 Author Administrators Posted October 28, 2018 [ref]achill3[/ref], DSDT.aml.zip -Audio "> -Battery https://bitbucket.org/RehabMan/os-x-acpi-battery-driver -Video https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v151/ -Brightness https://bitbucket.org/RehabMan/applebacklightfixup -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
CyCLoBoT Posted October 28, 2018 Posted October 28, 2018 [ref]MaLd0n[/ref], could you please help me create a patched DSDT for my system? I have an Asus Maximus Gene VI motherboard. In your original post, you have mentioned a list of patches which I don't think have been implemented on my system. There are few patches that I do have in the ACPI section in the config file. I do have some SSDTS in patched folder that were created to display device information in the PCI section of System Properties. If possible, I would like to have those merged in the DSDT if it's a feasible solution. For USB, I have created a custom USB port kext that only requires the rename of EHCi1/EHC2 to EH01/EH02. USBInjectAll kext is not needed so that's why it's missing from the Other folder. I am also using onboard graphics along with MSI Radeon RX 480 8GB. Without the onboard graphics, hardware acceleration is not functioning, If you know how to fix this then it would be appreciated. Send me imac.lan.zip
psycmos Posted October 28, 2018 Posted October 28, 2018 Já baixei 2 vezes a imagem Final do Mojave e dá me sempre o mesmo erro. Já coloquei a pasta do clover, como anuncia no tutorial e tenho o mesmo erro: "Esta cópia da aplicação Instalar o macOS Mojave está danificada e não é possivel usa-la para instalar o macOS". Alguma Ideia?
CamBuff Posted October 28, 2018 Posted October 28, 2018 I tried installing, once I was able to successfully install and completed Clover boot loader. But forgot to configure clover Now retrying it but stuck at a line says: "Please switch to XPC or bootstrap_check_in (): com.apple.bsd.dirhelper Added in 17 minutes 20 seconds: CamBuff, yes, work orozcopc, https://www.insanelymac.com/forum/topic ... cher-v153/ I tried installing, I was able to complete the installation but I think some post installation error happened. I forgot to configure "Clover configurator". but I have intected GPU with the AMD GPU injector tool. When I booted it shown Kernal Panic. Now I'm trying to reinstall again but im stuck at a line :" Please switch to XPC or bootstrap_check_in():com.apple.bsd.dirhelper" Can you suggest what to do? This is my spec: Motherboard: Intel Q65 Express Intel Core i5-2400 Sandybridge LGA1155 Socket 4GB 1333 MHz DDR3 SDRAM 250 GB SSD PCI Express x16 AMD Radeon HD 6450 2GB Ethernet Controller(s): Intel 82579LM
Administrators MaLd0n Posted October 28, 2018 Author Administrators Posted October 28, 2018 [ref]CyCLoBoT[/ref], DSDT.aml.zip Added in 32 seconds: [ref]psycmos[/ref], use um gerenciador de download para não falhar Added in 46 seconds: [ref]CamBuff[/ref], use smbios iMac13,2 or iMac14,2 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
CyCLoBoT Posted October 28, 2018 Posted October 28, 2018 CyCLoBoT, DSDT.aml.zip [ref]MaLd0n[/ref], do I have to make any other changes in my Clover folder or the config file?
Administrators MaLd0n Posted October 28, 2018 Author Administrators Posted October 28, 2018 [ref]CyCLoBoT[/ref], use my clover folder for chipset series -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
psycmos Posted October 28, 2018 Posted October 28, 2018 ja deu MaL0n, era a hora que estava mal na bios!!! Da erro nas USB durante o verbose... Pode dar uma ajuda no dsdt do meu colega? Send me Mac-mini-de-DEAD.zip
