uran0s, use shikigva=60
continua igual, assim que meto a converter para HEVC, bloqueia e diz na console:
kernel virtual IOReturn IOAccelEventMachine2::waitForStamp(int32_t. stamp_t, stamp_t *): timeout waiting for AMDRadeonAccelerator stamp 2 (GPUs_stamp=1)
pelo sim pelo não, experimentei a deixar apenas a RX 580, mas acontece o mesmo.
Kernel_2018-10-18-223236_uran0s-macpro.gpuRestart.zip
:guitar:cap
inject ids via clover and test one by one
I've done this already but none of the ids give me digital output, tried voodoo all IO sounds appear but when I connected to HDMI, still no digital audio out.
Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
[ref]rositaott[/ref], try with AppleHDAPatcher
rositaott, try with AppleHDAPatcher
With AppleHDAPatcher, Do i need to use the DSDT patches? Copied aDummyHDA CodecCommander to Clover/Kext/Others, how abou HDAEnabler. And for the fully patche AppleHDA, do I need to replaced /Systems/Library/Extensions?
[ref]rositaott[/ref], use applehdapatcher topic, Mirone check there ;)
[ref]danielhutapea[/ref], :guitar:cap
Hi MaLd0n,
Thanks for your great work,
I read you have solved the problem for "zombiRon" on page 24 of this forum.
Mine is so similar;
WhatEverGreen writes "IMEI device (00:60:00) has device-id 0x1C3A, you should change it to 0x1E3A"
and from my dsdt.aml
Card Type Drv. Slot
Broadcom BCM43xx Wireless Network Adapter Airport Extreme Yes Built In
Intel Corporation, Series Chipset MEI Controller IMEI Controller No Built In
Intel Corporation, Series Chipset SATA Controller AHCI Controller Yes Built In
Can you please correct imei on dsdt,
Thanx, requires files; already patched dsdt below,
Intel H61 mb, i5 3rd gen cpu, Intel hd 4000 gpu, ivy bridge, 2x4 ddr3 1333, 1920x1080,
SSDT.aml.zip
Send me WaterMojs-Mac-mini.zip
[ref]tuncas[/ref], DSDT.aml.zip
Mald0n, estou mandando meu arquivo Send Me
mas eu acho que fiz algo que não deveria ter feito. talvez não tenha problema. Eu rodei o app "Kext Utility" que estava dentro da pasta "Files" no pendrive e tentei adicionar a kext do aúdio e rede mas nenhuma das duas funcionaram
No vídeo, apesar de ser bem lúdico, fiquei sem entender o que ta acontecendo a partir do minuto 10:00
Send me MacBook-Pro-de-Anaisa.zip
[ref]rfl7[/ref], DSDT.aml.zip
AUDIO Realtek ALC269
REDE, tem de ver qual a placa, use o DPCI Manager
MaLd0n, My hackintosh can't shutdown. I checked "Fix Shutdown" in config.plist but no change. Can you help me? (I used ACPIbaterydriver but still can't shutdown)
tuncas,
(15.58 KiB) Downloaded 1 time
Intel Corporation, Series Chipset MEI Controller IMEI Controller Yes Built In
Thank you so much, cheers.
[ref]tranluan1[/ref], try Halt Enabler in config.plist
Added in 3 minutes 39 seconds:
[ref]linhvk[/ref], DSDT.aml.zip
Added in 9 seconds:
[ref]tuncas[/ref], :guitar:cap
hi
my p55a-ud3r installing to Mojave, But your clover folder is i/o error..
Clover USB boot..
not format when format to target HDD ...
Now Solved !!!!!!
using kext2patch....
Thank you!!! :lol:
[ref]BlueGuerrilla[/ref], k
have a kext2patch, just enable
Added in 7 minutes :
[ref]kuertel[/ref], DSDT.aml.zip
update all kexts
KEXTS.zip
Hello all,
I have a Dell Optiplex 790 with following specs.
Motherboard: Intel Q65 Express
Intel Core i5-2400 Sandybridge LGA1155 Socket
4GB 1333 MHz DDR3 SDRAM
250 GB SSD
PCI Express x16
AMD Radeon HD 6450 2GB
Ethernet Controller(s): Intel 82579LM
I want use it for home computing, a secondary machine. little bit of video editing, and planning to install High Sierra.
Please advice if this specs will work or not.
