rositaott Posted October 17, 2018 Posted October 17, 2018 [ref]MaLd0n[/ref], I want to make a fresh install for my notebook (specs on my signature) cause I've messed up my system again trying to figure out the hdmi audio and brightness keys after installing mojave. Which clover should I use from these 2 links; http://Olarila.com/forum/viewtopic.php?f=28&t=6257 http://Olarila.com/forum/viewtopic.php?f=28&t=6255 Thanks Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
bibinalappatt Posted October 17, 2018 Posted October 17, 2018 timeworking thnx man also my brightness keys are f2&f3 they ate not working with slider any way to make them working also my battey not detected using acpi battey manager.also power management issue
Administrators MaLd0n Posted October 17, 2018 Author Administrators Posted October 17, 2018 [ref]danielhutapea[/ref], WLAN check here if work https://bitbucket.org/RehabMan/os-x-fake-pci-id AUDIO "> Added in 3 minutes 23 seconds: [ref]chuongga2vn[/ref], DSDT.aml.zip Added in 58 seconds: [ref]rositaott[/ref], i don't remember, test both xD Added in 23 seconds: [ref]bibinalappatt[/ref], Battery check Rehabman repo -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
bibinalappatt Posted October 17, 2018 Posted October 17, 2018 bibinalappattfor better power management and heating issue
Administrators MaLd0n Posted October 17, 2018 Author Administrators Posted October 17, 2018 [ref]bibinalappatt[/ref], plugin type -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
rositaott Posted October 17, 2018 Posted October 17, 2018 rositaott, i don't remember, test both xD Hi Maldon, please help me with my audio Send me Corneliouss-iMac.zip Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
jimikill666 Posted October 17, 2018 Posted October 17, 2018 hi.. newbie here. i downloaded Elcapitan at the link above and install it to usb stick using win32diskimager. when i boot on usb, nothing happen. it bootel straight to windows. what should i do? my laptop is acer aspire 4750G there is no UEFI setting on bios but internet says this laptop has Hybird EFI. Intel Core i5 2410M Sandy Bridge @2.30GHz Acer Aspire 4752 RAM 4GB Intel HD GRAPHIC 3000
Administrators MaLd0n Posted October 17, 2018 Author Administrators Posted October 17, 2018 [ref]jimikill666[/ref], u extract image before burn? use boot key and select uefi usb stick -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
jimikill666 Posted October 17, 2018 Posted October 17, 2018 jimikill666, u extract image before burn? use boot key and select uefi usb stick i did extract it. n get .raw file.. i burn it with win32diskimager and reboot and press F12 choose usb . i did recreate the usb installer using bootdisk utility by cvad n install clover with it.. it made 2 partition on usb stick.. then i replace the clover folder on usb stick with the one u provide above.. end up with this Intel Core i5 2410M Sandy Bridge @2.30GHz Acer Aspire 4752 RAM 4GB Intel HD GRAPHIC 3000
Administrators MaLd0n Posted October 18, 2018 Author Administrators Posted October 18, 2018 use uefi and boot with bootkey -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Administrators MaLd0n Posted October 18, 2018 Author Administrators Posted October 18, 2018 check clover wiki or config.plist -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
bibinalappatt Posted October 18, 2018 Posted October 18, 2018 Can you make a proper DSDT patch for my System with power management, brighness key fix,battery fix(f2 ,Q11 & f3,Q12) for hp. because my system cpu temperature is always above 50°c and when it keep for idle it goes to black screen then i need to rebot to use it you already given me a DSDT with brightness fix it working thnx my system is HP 14 r000ne intel core i5 4210U intel HD Graphics 4400 Nvidia GT820m Send me bibinalappatts-MacBook-Pro.zip
Administrators MaLd0n Posted October 18, 2018 Author Administrators Posted October 18, 2018 [ref]bibinalappatt[/ref], ur dsdt is edited, dsdt is bios, dont need edited every time Added in 25 seconds: notebook is common 50c + -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
bibinalappatt Posted October 18, 2018 Posted October 18, 2018 (edited) bibinalappattit is going black screen while idle why?also wake lid not working Edited October 18, 2018 by Guest
Administrators MaLd0n Posted October 18, 2018 Author Administrators Posted October 18, 2018 disable hibernate and auto sleep use sleep in apple menu -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Administrators MaLd0n Posted October 18, 2018 Author Administrators Posted October 18, 2018 rehabman repo -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
bibinalappatt Posted October 18, 2018 Posted October 18, 2018 while adding DSDT giving errors that i dont know to solve
Administrators MaLd0n Posted October 18, 2018 Author Administrators Posted October 18, 2018 report to rehabman -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
rositaott Posted October 18, 2018 Posted October 18, 2018 [ref]MaLd0n[/ref], I'm still trying to fix my audio, and explore my IOREG, found HDAU & HDEF is that normal, because my audio output is only internal speaker. Not sure if its supported on Mojave because it was from Sierra. Help...please don't leave me... Send me Corneliouss-iMac.zip Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
bibinalappatt Posted October 18, 2018 Posted October 18, 2018 anyone knows which patches are required for power management
rakesh0836 Posted October 18, 2018 Posted October 18, 2018 Please Help me compile DSDT for my Hackintosh, Run me output is attached, Regards, Rakesh0836 Send me Macs-iMac-2.zip
kar2wlan Posted October 18, 2018 Posted October 18, 2018 (edited) hi, i have hp z420 motherboard with E5-2670, 48 gb ram. i installed mojave, but i cant get CPU management to work. about mac shows unknown CPU, also cpu frequency stays as 2.6ghz only. attaching my files. please take look. Send me kars-MacBook-Pro.zip Edited October 18, 2018 by Guest
uran0s Posted October 18, 2018 Posted October 18, 2018 necessito de alteração do DSDT por ter duas gráficas? para já a única coisa que noto é na identificação da slot, uma diz Slot- e a outra PCI Slot. às vezes ao acordar de sleep crasha a RX 570 e por sua vez crash no sistema. abraço
