Administrators MaLd0n Posted September 29, 2018 Author Administrators Posted September 29, 2018 Hi MaLd0n, sorry for late reply, just back from 1 week seminar, today i got time to further test your DSDT, my system keep restarting, 4 to 5 times restarting till it reach loading screen and boot to mojave, if i remove drop oem and delete DSDT file, system can boot normally. Actually i need DSDT coz my mojave cant shutdown...its restart whenever i click shutdown menu, i already tried all suggestion i can find about fixing shutdown restart problem, none work, so i read somewhere DSDT might fix my problem try with dsdt and uncheck dropOEM Added in 17 seconds: yes, it is optimus don't work, use intelHD -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
liemhatang Posted September 30, 2018 Posted September 30, 2018 Hi MaLd0n After days, I also installed hackintosh on my computer. Can you help me see if I'm fine? I have not used dsdt, you help me patch dsdt my computer offline? Thank you! Send me vos-imac.zip
Administrators MaLd0n Posted September 30, 2018 Author Administrators Posted September 30, 2018 Hi MaLd0n After days, I also installed hackintosh on my computer. Can you help me see if I'm fine? I have not used dsdt, you help me patch dsdt my computer offline? Thank you! DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Jinnz Posted September 30, 2018 Posted September 30, 2018 Greets forum peps I decided to give Mojave a test run on my Z77X-UD5H but the installer gets stuck.I've downloaded the image, run etcher, created the USB boot disk, configured bios but with one exception (I have to leave OS Type - Other) anything else results in the system hanging with I believe 2 beeps and nothing, only way is to rest cmos.I tried all the USB ports still the same result.Any suggestion are welcomed.Bless
tsader Posted September 30, 2018 Posted September 30, 2018 Hi I am trying to install from USB but I get stuck at appleusbhostresources any suggestions? Thanks
Administrators MaLd0n Posted September 30, 2018 Author Administrators Posted September 30, 2018 Greets forum peps I decided to give Mojave a test run on my Z77X-UD5H but the installer gets stuck.I've downloaded the image, run etcher, created the USB boot disk, configured bios but with one exception (I have to leave OS Type - Other) anything else results in the system hanging with I believe 2 beeps and nothing, only way is to rest cmos.I tried all the USB ports still the same result.Any suggestion are welcomed.Bless try other smbios and disable IntelHD Added in 52 seconds: Hi I am trying to install from USB but I get stuck at appleusbhostresources any suggestions? Thanks try -x for disable ur GPU in installation -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
tsader Posted September 30, 2018 Posted September 30, 2018 try -x for disable ur GPU in installation Unfortunately I am getting the same issue it getting stuck at appleusbhostresources thx
Administrators MaLd0n Posted September 30, 2018 Author Administrators Posted September 30, 2018 test other usb port -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
tsader Posted September 30, 2018 Posted September 30, 2018 test other usb port I have tested 2, USB 2 and 3 ports but same issue. Should I try more ports?
Administrators MaLd0n Posted September 30, 2018 Author Administrators Posted September 30, 2018 post one photo -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted September 30, 2018 Author Administrators Posted September 30, 2018 is a usb problem -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
tsader Posted September 30, 2018 Posted September 30, 2018 is a usb problem I first tried your config file the way it was and kept tweaking things but always the same issue. This is what I have under KextToPatch, should I change it?
Jinnz Posted October 1, 2018 Posted October 1, 2018 @ MaLd0n I open the config but there was nothing in smbios section ? is that how it suppose to be initially ? Looking at the verbose output it picks it up as an iMac though so where is it getting that from? In any case I left it blank and I just unchecked Inject Intel and checked Inject ATI since it's a 6870 I'm using, and I'm now looking at the Welcome screen for the installer.Unfortunately though it seems my spare drive has just died so I gotta put it on hold until further notice Bless
Administrators MaLd0n Posted October 1, 2018 Author Administrators Posted October 1, 2018 I first tried your config file the way it was and kept tweaking things but always the same issue. This is what I have under KextToPatch, should I change it? enable all Added in 22 seconds: @ MaLd0n I open the config but there was nothing in smbios section ? is that how it suppose to be initially ? Looking at the verbose output it picks it up as an iMac though so where is it getting that from? In any case I left it blank and I just unchecked Inject Intel and checked Inject ATI since it's a 6870 I'm using, and I'm now looking at the Welcome screen for the installer.Unfortunately though it seems my spare drive has just died so I gotta put it on hold until further notice Bless clover generate one for u -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
lokey Posted October 1, 2018 Posted October 1, 2018 Hi MaLdOn, can you take a look please? My DSDT is patched. PM and AGPM seem to be working, but I get kp reboots on waking from sleep on Mojave. happy to donate a few beers for any help. Send me Logoss-Mac-mini.zip
ford2201 Posted October 1, 2018 Posted October 1, 2018 ASUS B250-Plus Prime ASUS GTX 1050TI i7-7700K kaby lake MEMORY 16GB ALC887 https://www67.zippyshare.com/v/RHOqD9xk/file.html
Administrators MaLd0n Posted October 1, 2018 Author Administrators Posted October 1, 2018 Hi MaLdOn, can you take a look please? My DSDT is patched. PM and AGPM seem to be working, but I get kp reboots on waking from sleep on Mojave. happy to donate a few beers for any help. DSDT.aml.zip Added in 3 minutes 22 seconds: My Graphics card is Radeon RX580 4GB Just use WhateverGreen kext -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ford2201 Posted October 1, 2018 Posted October 1, 2018 ASUS B250-Plus Prime ASUS GTX 1050TI i7-7700K kaby lake MEMORY 16GB ALC887 https://www67.zippyshare.com/v/RHOqD9xk/file.html please clover all
Administrators MaLd0n Posted October 1, 2018 Author Administrators Posted October 1, 2018 ASUS B250-Plus Prime ASUS GTX 1050TI i7-7700K kaby lake MEMORY 16GB ALC887 https://www67.zippyshare.com/v/RHOqD9xk/file.html please clover all i edit it some time for u just use same files Enjoy -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepitopito Posted October 1, 2018 Posted October 1, 2018 O problema vem do kext AppleALC.Eu removi e substitui-lo com HDMIAudio.kext tonycrap.Agora o áudio HDMI funciona perfeitamente, mas o áudio na placa não funciona, você pode me consertar por favor?
Administrators MaLd0n Posted October 1, 2018 Author Administrators Posted October 1, 2018 RX580 tem hdmi audio nativo -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
srut2000 Posted October 1, 2018 Posted October 1, 2018 Has anybody got this to work on the x79 chipset
pepitopito Posted October 1, 2018 Posted October 1, 2018 Mas se eu colocar o kext appleALC na pasta kexts other, o audio hdmi não funciona bem
