uran0s Posted September 25, 2018 Posted September 25, 2018 após actualização para mojave, houve algum problema com o sleep? faço sleep, dá a sensação que funciona, pois desliga normalmente como se estive-se a funcionar. Quando faço o wake up, liga o computador do 0, a iniciar a bios novamente. algum patch novo?
Administrators MaLd0n Posted September 25, 2018 Author Administrators Posted September 25, 2018 eu não tive problema nenhum, até pq já vinha testando desde o primeiro beta -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rachidbenlala Posted September 25, 2018 Posted September 25, 2018 I wanto to install mac os mojave but is reboot in furts boot . but in mac os high sierra is work verywell this is my origen DSDT.aml hp probook 450 g5 i5 8250u graphique cart uhd 620 DSDT.aml.zip
Administrators MaLd0n Posted September 25, 2018 Author Administrators Posted September 25, 2018 i think is a video problem DSDT.aml.zip take a in stall without video enable -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
uran0s Posted September 25, 2018 Posted September 25, 2018 eu não tive problema nenhum, até pq já vinha testando desde o primeiro beta tinha o darkwake no clover como "darkwake", mudei para darkwake=0 e ficou a funcionar... estranho? EDIT: nas definições, em Energy Saver, se activar o power nap voltou a ter sleep/wake... aconteceu que não queria ter essa opção activa, alguma dica?
Pumba Posted September 26, 2018 Posted September 26, 2018 Hi Daniel! Just did my first try on Hackintosh... and I got stuck I guess now I do need your help, sorry for that. Sending you the RunMe file Send me FDIs-MacBook-Air.zip HP ProBook 650 G1, last Bios, i7-4712MQ/HM87, HD 4600, 1980x1080, SSD 1TB Evo Samsung, WiFi Azurewave AW-CB160H BCM94360HMB not yet installed. Obrigado, abraço
Administrators MaLd0n Posted September 26, 2018 Author Administrators Posted September 26, 2018 and I got stuck post one photo -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Pumba Posted September 26, 2018 Posted September 26, 2018 The problem is that, on the video help (Mojave) one should copy MaLd0nSERIE10.20.30.txt to add to the compile app (I guess). I cannot find this file anywhere Up to this point everything went ok, as far as I know... It should be my mistake, but this is really my first try, so please go easy on me Obrigado
pulga_lipe Posted September 26, 2018 Posted September 26, 2018 Hello @Mald0n! I've been trying to install High Sierra on my mobo but with no luck. On every try I got a KP and I dont know where to look for these logs. I already have Sierra working well on it but I know that my DSDT is far from being perfect. Because of that, I just want to know if you could help me patch my original dsdt cause I see a bunch of warnings floating around my logs and my USB3's aren't working with any external/flash disk at all (it works with peripherals). Thanks for your support and cheers from Brazil. My PC Specs: Dell XPS 8700 i7 4770 3.4GHz 14GB RAM DDR3 NVIDIA GT360 1GB (HDMI AUDIO/VIDEO) ALC898 Chipset Intel Z87 Express WiFi + Bluetooth (Atheros AR9485) LAN Realtek RTL8111/8168 DSDT-pulgalipe-25-09-2018.zip Send me pulgalipe.zip Motherboard: Generic Motherboard CPU: i5-2400S 2.50GHz Chipset: Intel 6 Series C200 RAM: 8GB DDR3 1333 Audio: VIA VT1708S GPU: GTX 560 TI 1GB OS: High Sierra 10.13.6 LAN: Atheros AR8151 (non-working)
Administrators MaLd0n Posted September 26, 2018 Author Administrators Posted September 26, 2018 ello @Mald0n! I've been trying to install High Sierra on my mobo but with no luck. On every try I got a KP and I dont know where to look for these logs. I already have Sierra working well on it but I know that my DSDT is far from being perfect. Because of that, I just want to know if you could help me patch my original dsdt cause I see a bunch of warnings floating around my logs and my USB3's aren't working with any external/flash disk at all (it works with peripherals). Thanks for your support and cheers from Brazil. My PC Specs: Dell XPS 8700 i7 4770 3.4GHz 14GB RAM DDR3 NVIDIA GT360 1GB (HDMI AUDIO/VIDEO) ALC898 Chipset Intel Z87 Express WiFi + Bluetooth (Atheros AR9485) LAN Realtek RTL8111/8168 Attachments Send me pulgalipe.zip (2.7 MiB) Not downloaded yet DSDT-pulgalipe-25-09-2018.zip DSDT.aml.zip Added in 1 minute 44 seconds: The problem is that, on the video help (Mojave) one should copy MaLd0nSERIE10.20.30.txt to add to the compile app (I guess). I cannot find this file anywhere Up to this point everything went ok, as far as I know... It should be my mistake, but this is really my first try, so please go easy on me Obrigado is my personal patch, for my mobo -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Pumba Posted September 26, 2018 Posted September 26, 2018 is my personal patch, for my mobo I have no idea now how to do the patch for my system. Should I follow another guide? I'm feeling stupid Obrigado do outro lado do Atlântico
Administrators MaLd0n Posted September 26, 2018 Author Administrators Posted September 26, 2018 post ur files here -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
hoangmytr Posted September 26, 2018 Posted September 26, 2018 Hi, Could you please fix my DSDT? I'm using Z77x-UD3H + i7 2600k. I extracted original ACPI time ago, so I attach them along with "Send Me iMac.zip". Thanks so much! Sendme iMac.zip
Administrators MaLd0n Posted September 26, 2018 Author Administrators Posted September 26, 2018 Hi, Could you please fix my DSDT? I'm using Z77x-UD3H + i7 2600k. I extracted original ACPI time ago, so I attach them along with "Send Me iMac.zip". DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
hoangmytr Posted September 26, 2018 Posted September 26, 2018 DSDT.aml.zip Thank you so much! I've just tried it but after verbose, it goes black on both of my screens.
nicksilverstein Posted September 26, 2018 Posted September 26, 2018 Is there anyway you could modify the Config.plist for me? I have the Dell Precision T7500 with 2x X5650 6-Core 2.66Ghz. I also have a AMD Radeon RX 580 and I would like to run Mojave. You're a legend MaLd0n! Thank You Very Much! It is very much appreciated!
uran0s Posted September 26, 2018 Posted September 26, 2018 MaLd0n wrote: ↑ após actualização para mojave, houve algum problema com o sleep? faço sleep, dá a sensação que funciona, pois desliga normalmente como se estive-se a funcionar. Quando faço o wake up, liga o computador do 0, a iniciar a bios novamente. algum patch novo? Mald0n, era a kext AtherosE2200Ethernet.kext que entrava em conflito. Deixei apenas a placa de rede intel e já faz sleep normalmente sem qualquer problema. Abraço
Pumba Posted September 26, 2018 Posted September 26, 2018 post ur files here I believe this is for me. Is this the necessary file? If there are any other needed files, can you, please, point me the ones needed? Obrigado pela ajuda e desculpa Send me FDIs-MacBook-Air.zip
Administrators MaLd0n Posted September 26, 2018 Author Administrators Posted September 26, 2018 Thank you so much! I've just tried it but after verbose, it goes black on both of my screens. use last whatevergreen kext Added in 46 seconds: Is there anyway you could modify the Config.plist for me? I have the Dell Precision T7500 with 2x X5650 6-Core 2.66Ghz. I also have a AMD Radeon RX 580 and I would like to run Mojave. You're a legend MaLd0n! Thank You Very Much! It is very much appreciated! post ur files here RunMe.app Added in 17 seconds: Mald0n, era a kext AtherosE2200Ethernet.kext que entrava em conflito. Deixei apenas a placa de rede intel e já faz sleep normalmente sem qualquer problema. Abraço Added in 6 minutes 33 seconds: I believe this is for me. Is this the necessary file? If there are any other needed files, can you, please, point me the ones needed? Obrigado pela ajuda e desculpa DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
liemhatang Posted September 26, 2018 Posted September 26, 2018 Hi madl0n My system: Main: Giga-B75M-D3V Cpu: i3-2100 VGA: Quado K620 I use your clover, installer 10.12 but don”t boot . My error
Administrators MaLd0n Posted September 26, 2018 Author Administrators Posted September 26, 2018 cant perform kext scan, something wrong with ur installer -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepitopito Posted September 26, 2018 Posted September 26, 2018 upload my file to zippishare and donate 10 dollars for you. https://www81.zippyshare.com/v/tn2ila2C/file.html Send my fast,please.I need DSDT,SSDT and config.plist My mail is lorenzocold@gmail.com motherboard gigabyte Z97-HD3 RADEON SAPPHIRE RX580 4G Intel® Core i7-4770 CPU @ 3.40GHz Running Mojave Added in 9 minutes 22 seconds: 26 de septiembre de 2018 Daniel Nascimento Maldonado -negativo 10,00 USD Donativo Pagado con Saldo de PayPal Id. de transacción 47081333AA0564832 Enviado a Daniel Nascimento Maldonado danielnmaldonado@yahoo.com.br Detalles de la compra MaLd0n0,00 USD Total10,00 USD
Administrators MaLd0n Posted September 26, 2018 Author Administrators Posted September 26, 2018 upload my file to zippishare and donate 10 dollars for you. https://www81.zippyshare.com/v/tn2ila2C/file.html Send my fast,please.I need DSDT,SSDT and config.plist My mail is lorenzocold@gmail.com motherboard gigabyte Z97-HD3 RADEON SAPPHIRE RX580 4G Intel® Core i7-4770 CPU @ 3.40GHz Running Mojave CLOVER.zip REMOVE FakePCIID.XHCIMux and fakesmc sensors -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepitopito Posted September 26, 2018 Posted September 26, 2018 where is FakePCIID.XHCIMux and fakesmc sensors?
