Hi Mald0n,
currently running 10.13.6 with your image
and clover 4630 on the SSD
Asus Sabertooth X79 - SandyBridge-e i7 3930k - Radeon RX570 -Smbios macpro6,1
can you help me with this files please :
https://www2.zippyshare.com/v/gArq1chp/ ... ac-Pro.zip
including origin dsdt extract files.
have got some problems with Powermanagement and frenquencies
and the sound output.
CLOVER.zip
generate one ssdt with Pike Script
https://Olarila.com/files/Utils/ssdtPRGen.command.zip
usb non-intel u need a genericxhci, don't work native
Hello Maldon
question: could you tell me why Clover-kext-other does not load all kext
Hello Maldon
minimal kexts don't work there
some kexts need stay in l/e or s/l/e, kernel cache, kextcache
today, 98% work in clover/kexts/other
its look like my problem ? USB not assigned / not work natively ?
i have to put genericUSBXHCI in L/E and/or S/L/E to active them ?
i prefer KetkToPatch in clover if it's possible
i have try to put genericXHCI.kext in CLover/Kexts/Other same problem no usb detect.
i have to find how i fix this for my previous install (usb2 only)
maybe i disable XHCI handoff in my bios
x79 don't have a usb3 intel, don't work with vanilla way ;)
Boa tarde Mald0n,
Aqui fica o file gerado pelo runme.zip para criação de DSDT.
Mobo: Gigabyte Z97X UDH5 Rev 1.0; i7 4790K @ 4,7GHZ; 32GB DDR 3 2400MHZ; AMD Asus Strix 570 OC 4GB; NVMe Samsung 960 EVO, Mojave Beta 8.
Um Abraço
nuno.zip
Ok am booting with USB2 thanx for the sound.
got some problems with my SSDT generation file. no speedstep.
even if i use my old working 10.12 ssdt file
have to work on it, i have to look more deeply in my bios i think
thanx a lot for your help.
Boa tarde Mald0n,
vc está usando PEGP to GFX0 , isso estraga as tabelas, renomeia muitos devices que não são de vídeo pra GFX0
Added in 28 seconds:
PM in x79 need a extra steps
need help please
CLOVER.zip
retirei o patche PEGP to GFX0, reiniciei e corri novamente o runme. Era isso que você queria?
Abraço
nuno2.zip
after complete instantiation only show this ....... how to fix it
<a class=40892510_DesktopScreenshot2018_08.30-09_45_37_04.thumb.png.43967515a229188da78d5eb3f046bc5e.png' alt='40892510_DesktopScreenshot2018_08.30-09_45_37_04.thumb.png.43967515a229188da78d5eb3f046bc5e.png'>
Added in 9 minutes 48 seconds:
after complete instillation macOS Mojave .... show this screen
CPU - i5 4460
GPU - gtx 750ti
Motherboard - gigabyte H81-S2PV
947483894_DesktopScreenshot2018_08.30-09_45_37_04.thumb.png.7d4b371a58037ece803a0cf3c79a56aa.png
disable intelhdgraphics in bios
This is my clover/other folder.
Should I install any of these kext to l/e ?
don't need
use in clover/kexts/other
Olá Mald0n, já experimentei o ficheiro DSDT :)
Ao adicionar o DSDT deixa de dar boot, assim que começa a preencher a barra de loading faz reboot automaticamente constantemente. Só arranca em modo verbose. O que poderá causar isto?
Anonymous UUID:       6BFA7BC8-DF7E-C94C-0220-AC3D6215A3A7
Fri Aug 31 11:13:39 2018
*** Panic Report ***
panic(cpu 7 caller 0xffffff80048d87bd): Kernel trap at 0xffffff8004e0da3d, type 14=page fault, registers:
CR0: 0x000000008001003b, CR2: 0xffffff800530f578, CR3: 0x0000000013f80000, CR4: 0x00000000001626e0
RAX: 0xffffff80052fed18, RBX: 0xffffff800535bb98, RCX: 0x0000000000000000, RDX: 0x0000000000001086
RSP: 0xffffff83a691bb20, RBP: 0xffffff83a691bb70, RSI: 0x0000000000000030, RDI: 0xffffff83a5f4e950
R8:  0x0000000000000031, R9:  0xffffff8004fee196, R10: 0xffffff8004600de0, R11: 0x0000000000000001
R12: 0x0000000000010860, R13: 0x0000000000001086, R14: 0xffffff804a0f15e0, R15: 0xffffff83a5f4e920
RFL: 0x0000000000010206, RIP: 0xffffff8004e0da3d, CS:  0x0000000000000008, SS:  0x0000000000000000
Fault CR2: 0xffffff800530f578, Error code: 0x0000000000000000, Fault CPU: 0x7, PL: 0, VF: 2
Backtrace (CPU 7), Frame : Return Address
0xffffff83a691b5f0 : 0xffffff80047aca1d
0xffffff83a691b640 : 0xffffff80048e6b13
0xffffff83a691b680 : 0xffffff80048d859a
0xffffff83a691b6f0 : 0xffffff8004759ca0
0xffffff83a691b710 : 0xffffff80047ac437
0xffffff83a691b830 : 0xffffff80047ac283
0xffffff83a691b8a0 : 0xffffff80048d87bd
0xffffff83a691ba10 : 0xffffff8004759ca0
0xffffff83a691ba30 : 0xffffff8004e0da3d
0xffffff83a691bb70 : 0xffffff8004e0bacd
0xffffff83a691bbc0 : 0xffffff8004e04aeb
0xffffff83a691bc50 : 0xffffff8004e055e9
0xffffff83a691bcc0 : 0xffffff8004dd2c51
0xffffff83a691bda0 : 0xffffff8004dd0b1c
0xffffff83a691be10 : 0xffffff8004dde6c8
0xffffff83a691be60 : 0xffffff8004e4dc7b
0xffffff83a691be80 : 0xffffff8004e2b951
0xffffff83a691bf00 : 0xffffff8004e2b537
0xffffff83a691bf50 : 0xffffff8004e2d006
0xffffff83a691bfa0 : 0xffffff80047590ce
BSD process name corresponding to current thread: Unknown
Boot args: -rad4200 dart=0 shikigva=28 ngfxpatch=cfgmap
Mac OS version:
Not yet set
Kernel version:
Darwin Kernel Version 18.0.0: Wed Aug 22 20:59:21 PDT 2018; root:xnu-4903.201.2~4/RELEASE_X86_64
Kernel UUID: D05DACF4-9869-35A1-B56A-299FC3DB9A93
Kernel slide:     0x0000000004400000
Kernel text base: 0xffffff8004600000
__HIB  text base: 0xffffff8004500000
System model name: iMac15,1 (Mac-FA842E06C61E91C5)
System uptime in nanoseconds: 842419484
last loaded kext at 840325727: com.apple.driver.usb.AppleUSBXHCIPCI	1.2 (addr 0xffffff7f85b21000, size 196608)
loaded kexts:
Deixo printscreen de como estava a minha gráfica e como ficou.
Quanto á lista de hardware ficou espetacular.
Muito obrigado desde já.
486123418_Screenshot2018-08-31at09_16_10.thumb.png.5e069e90dc74a23af5501fb9a117a392.png
495727255_Screenshot2018-08-31at09_24_33.thumb.png.dc3d04841a07defc1d94d375b1d0a4b4.png
512644214_Screenshot2018-08-31at09_25_02.thumb.png.3b6f18a0bc2f051594584f0b18929c3f.png
Hello everyone :)
I use Hackintosh High Sierra Zone Without problems
When I try to install High Sierra Olarila & any Olarila images & Fresh Images, I have this problem and I can't solve it
The picture has the same problem that I have when boot to the system
img_20170309_014757-jpg.240746
Computer Hardware
Hp compaq 8100 elite sff PC
with board 304Ah
CPU : intel ® Core i5 650 @ 3.20GHz (1 generation)
Ram : 6 G
Geforce GT 710 Graphics Card
Thank you, Regards
try other usb port
serie 5 need a usb fix, is a very old problem
ahci is enable?
ahci is enable?
ahci is enable, Of the default settings
is there a solution to fix USB ?
thank you, mr. MaLd0n
