aymantop1 Posted August 19, 2018 Posted August 19, 2018 usb 3 not intel, don't work with a vanilla way, u need use genericxhci, but kext after el capitan cause some problems Ok man I get it , Last thing I want you check clover drivers , is it right and combatable with me ?
zombiRon Posted August 19, 2018 Posted August 19, 2018 Hi MaLd0n, Would you have a look at my DSDT please? There is a patched one I attempted in the archive along with the Clover OEM dumps. I'm struggling with Audio and Sleep now. I know USB3 will never work as it's an NEC Renesas. http://www.mediafire.com/file/3ln0rr2lvo39oow/Send%20me%20MacPro.lan.zip Regards, zombiRon
Administrators MaLd0n Posted August 19, 2018 Author Administrators Posted August 19, 2018 Ok man I get it , Last thing I want you check clover drivers , is it right and combatable with me ? yes, looks good, but u can use OsxAptioFix3Drv-64.efi instead OsxAptioFixDrv-64.efi Added in 24 minutes 33 seconds: Hi MaLd0n, Would you have a look at my DSDT please? There is a patched one I attempted in the archive along with the Clover OEM dumps. I'm struggling with Audio and Sleep now. I know USB3 will never work as it's an NEC Renesas. http://www.mediafire.com/file/3ln0rr2lv ... ro.lan.zip Regards, zombiRon DSDT.aml.zip new SEND_ME after reboot -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Paulo-Guedes Posted August 20, 2018 Posted August 20, 2018 Olá. Como se atualiza o Clover sem perder as configurações, pois na atualização ele pede pra instalar a nova versão como a primeira instalação e depois de instalado dá kernel panic ou trava na hora de subir o vídeo.
Administrators MaLd0n Posted August 20, 2018 Author Administrators Posted August 20, 2018 Olá. Como se atualiza o Clover sem perder as configurações, pois na atualização ele pede pra instalar a nova versão como a primeira instalação e depois de instalado dá kernel panic ou trava na hora de subir o vídeo. só instalar por cima da versão atual, o próprio clover detecta as config que vc usou pra fazer a primeira install -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Paulo-Guedes Posted August 20, 2018 Posted August 20, 2018 Olá. Como se atualiza o Clover sem perder as configurações, pois na atualização ele pede pra instalar a nova versão como a primeira instalação e depois de instalado dá kernel panic ou trava na hora de subir o vídeo. Tinha me esquecido que pra fazer subir o vídeo eu copiei a EFI do pendrive para a partição EFI do HD depois de instalar o Clover, então foi instalado a versão 4630 mas a do pendrive é a 3763. Será por isso que dá pau? Já tentei atualizar 2 vezes e ele trava no boot.
kostas20 Posted August 21, 2018 Posted August 21, 2018 @MaLd0n , for a Haswell laptop do I need all these drivers or should I add another ?
Administrators MaLd0n Posted August 21, 2018 Author Administrators Posted August 21, 2018 Attachments drivers64uefi.png (61.63 KiB) Not viewed yet looks good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zombiRon Posted August 21, 2018 Posted August 21, 2018 zombiRon wrote: ↑ Hi MaLd0n, Would you have a look at my DSDT please? There is a patched one I attempted in the archive along with the Clover OEM dumps. I'm struggling with Audio and Sleep now. I know USB3 will never work as it's an NEC Renesas. http://www.mediafire.com/file/3ln0rr2lv ... ro.lan.zip Regards, zombiRon DSDT.aml.zip (11.4 KiB) Downloaded 2 times new SEND_ME after reboot Hi MaLd0n, Thanks for looking at this, and hope you enjoyed the beer Initial DSDT looks really good, system boots much faster and cleaner, there are less errors in verbose boot, but... 1. I can only boot system with -alcoff boot option otherwise it hangs (photo attached) 2. sleep doesn't KP and reboot like before, but doesn't power down to low power state. 3. WhatEverGreen still complains "IMEI device (00:60:00) has device-id 0x1D3A, you should change it to 0x1E3A" The spec of the system just in case RunMe doesn't collect it... Nvidia GTX1050Ti Dell Precision T3610 6 Core Xeon E5-1650 v2 and 32Gb ECC RAM Samsung 256Gb m.2 NVMe connected via PCIe adapter card Hope this feedback helps, here is latest RunMe as requested along with photo of verbose boot without -alcoff. http://www.mediafire.com/file/jlqwfxn18pl9eaj/Send_me_MacPro.lan.zip/file http://www.mediafire.com/file/pu78betb5uc9m2n/IMG_0217.HEIC/file Thanks and Regards, zombiRon
Administrators MaLd0n Posted August 21, 2018 Author Administrators Posted August 21, 2018 Hi MaLd0n, Thanks for looking at this, and hope you enjoyed the beer Initial DSDT looks really good, system boots much faster and cleaner, there are less errors in verbose boot, but... 1. I can only boot system with -alcoff boot option otherwise it hangs (photo attached) 2. sleep doesn't KP and reboot like before, but doesn't power down to low power state. 3. WhatEverGreen still complains "IMEI device (00:60:00) has device-id 0x1D3A, you should change it to 0x1E3A" The spec of the system just in case RunMe doesn't collect it... Nvidia GTX1050Ti Dell Precision T3610 6 Core Xeon E5-1650 v2 and 32Gb ECC RAM Samsung 256Gb m.2 NVMe connected via PCIe adapter card Hope this feedback helps, here is latest RunMe as requested along with photo of verbose boot without -alcoff. http://www.mediafire.com/file/jlqwfxn18 ... n.zip/file http://www.mediafire.com/file/pu78betb5 ... .HEIC/file Thanks and Regards, zombiRon check if IMEI is load now DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zombiRon Posted August 22, 2018 Posted August 22, 2018 zombiRon wrote: ↑ Hi MaLd0n, Thanks for looking at this, and hope you enjoyed the beer Initial DSDT looks really good, system boots much faster and cleaner, there are less errors in verbose boot, but... 1. I can only boot system with -alcoff boot option otherwise it hangs (photo attached) 2. sleep doesn't KP and reboot like before, but doesn't power down to low power state. 3. WhatEverGreen still complains "IMEI device (00:60:00) has device-id 0x1D3A, you should change it to 0x1E3A" The spec of the system just in case RunMe doesn't collect it... Nvidia GTX1050Ti Dell Precision T3610 6 Core Xeon E5-1650 v2 and 32Gb ECC RAM Samsung 256Gb m.2 NVMe connected via PCIe adapter card Hope this feedback helps, here is latest RunMe as requested along with photo of verbose boot without -alcoff. http://www.mediafire.com/file/jlqwfxn18 ... n.zip/file http://www.mediafire.com/file/pu78betb5 ... .HEIC/file Thanks and Regards, zombiRon check if IMEI is load now DSDT.aml.zip (11.45 KiB) Downloaded 1 time Dude, do you ever sleep?? Thanks for the quick reply. Now the Error about IMEI device-id is gone, but is replaced with WhateverGreen: weg@ failed to apply vit9696 Patch 7 I assume this means the patch is not required?? Sleep still doesn't work and I still need to put -alcoff to get it to boot. Regards, zombiRon
Administrators MaLd0n Posted August 22, 2018 Author Administrators Posted August 22, 2018 use old version of kexts, u can report it for dev too what happens with sleep -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zombiRon Posted August 22, 2018 Posted August 22, 2018 use old version of kexts, u can report it for dev too what happens with sleep Hi MaLd0n, I've sorted out the WhateverGreen and AppleALC issues. Sleep though is weird, the system sleeps for a couple of seconds, then attempts to power up, diag LEDs 3 & 4 on the Case start flashing, fans spin up to full speed, screen stays asleep, the system is not responding to anything, not even ping from another device on the network. From the information I can find, LEDs 3 & 4 flashing simultaneously points at memory issues, I've already tried swapping in different memory and had successful results from memtest and the onboard diagnostics. On reboot there is no notice about kernel panic, and the logs have no clues. Any ideas?
Administrators MaLd0n Posted August 22, 2018 Author Administrators Posted August 22, 2018 Hi MaLd0n, I've sorted out the WhateverGreen and AppleALC issues. Sleep though is weird, the system sleeps for a couple of seconds, then attempts to power up, diag LEDs 3 & 4 on the Case start flashing, fans spin up to full speed, screen stays asleep, the system is not responding to anything, not even ping from another device on the network. From the information I can find, LEDs 3 & 4 flashing simultaneously points at memory issues, I've already tried swapping in different memory and had successful results from memtest and the onboard diagnostics. On reboot there is no notice about kernel panic, and the logs have no clues. Any ideas? the SEND_ME logs dont appears nothing about sleep error? app generate many logs -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zombiRon Posted August 22, 2018 Posted August 22, 2018 by MaLd0n » 22 Aug 2018, 19:52 zombiRon wrote: ↑ Hi MaLd0n, I've sorted out the WhateverGreen and AppleALC issues. Sleep though is weird, the system sleeps for a couple of seconds, then attempts to power up, diag LEDs 3 & 4 on the Case start flashing, fans spin up to full speed, screen stays asleep, the system is not responding to anything, not even ping from another device on the network. From the information I can find, LEDs 3 & 4 flashing simultaneously points at memory issues, I've already tried swapping in different memory and had successful results from memtest and the onboard diagnostics. On reboot there is no notice about kernel panic, and the logs have no clues. Any ideas? the SEND_ME logs dont appears nothing about sleep error? app generate many logs So what is the next step for troubleshooting this? ACPI isn't my area of expertise.
Administrators MaLd0n Posted August 22, 2018 Author Administrators Posted August 22, 2018 So what is the next step for troubleshooting this? ACPI isn't my area of expertise. send me new SEND_ME, i'll check logs -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zombiRon Posted August 22, 2018 Posted August 22, 2018 zombiRon wrote: ↑ So what is the next step for troubleshooting this? ACPI isn't my area of expertise. send me new SEND_ME, i'll check logs latest SEND_ME http://www.mediafire.com/file/26chp96s2n6adku/Send_me_MacPro.lan.zip/file
Administrators MaLd0n Posted August 22, 2018 Author Administrators Posted August 22, 2018 latest SEND_ME lan don't work with Mieze kext instead AppleIntelE1000e? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zombiRon Posted August 22, 2018 Posted August 22, 2018 Never tried mieze, I’ve used AppleIntele1000e for years in all my previous hacks. Do you suspect it as the cause?
Administrators MaLd0n Posted August 23, 2018 Author Administrators Posted August 23, 2018 Do you suspect it as the cause? this kext have a some bugs, the abandonned project -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zombiRon Posted August 24, 2018 Posted August 24, 2018 zombiRon wrote: ↑ Do you suspect it as the cause? this kext have a some bugs, the abandonned project I've replaced AppleIntelE100e.kext with IntelMausiEthernet.kext. I've tried other SMBIOS Mac Models. So far all behave the same way when I try to sleep. The one idea I have now is to switch the BIOS into legacy mode instead of UEFI.
Administrators MaLd0n Posted August 24, 2018 Author Administrators Posted August 24, 2018 I've replaced AppleIntelE100e.kext with IntelMausiEthernet.kext. I've tried other SMBIOS Mac Models. So far all behave the same way when I try to sleep. The one idea I have now is to switch the BIOS into legacy mode instead of UEFI. is a mistery -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zombiRon Posted August 25, 2018 Posted August 25, 2018 zombiRon wrote: ↑ I've replaced AppleIntelE100e.kext with IntelMausiEthernet.kext. I've tried other SMBIOS Mac Models. So far all behave the same way when I try to sleep. The one idea I have now is to switch the BIOS into legacy mode instead of UEFI. is a mistery So I tried both Legacy and UEFI boot methods, no luck. I changed the SMBIOS from MacPro6,1 to iMac13,2 This has resulted in much higher performance in cinebench, better speed stepping (higher turbo freq and lower idle freq) and smoothed out graphics in Rise of the Tomb Raider. I think this is due to the iMac having NVIDIA graphics on board as the MacPro6,1 was never available with NVIDIA. I tried to stay with a SMBIOS definition which has Ivy Bridge, although the MacPro definition is a closer match to my hardware (C600 chipset and Xeon E5 cpu with ECC memory) What I have now is an interesting inject of USB devices, I've been through the whole USBInjectAll plug a device into all ports and note the ports active in IORegistryExplorer, the SSDT that resulted didn't change from the previous one though. However I now have two devices complaining about being over current in the system log, this device is not in the DSDT anywhere. 000578.792648 AppleUSB20HubPort@1d180000: AppleUSBHostPort::interruptOccurred: overcurrent detected with port status 0x4000, localSimulatedInterrupts = 0x0 000583.866713 AppleUSB20HubPort@1d170000: AppleUSBHostPort::interruptOccurred: overcurrent detected with port status 0x4000, localSimulatedInterrupts = 0x0 I then looked at pmset -g log, I think USB is my sleep issue, so I'm working on finding a way to correct the way it's detecting it. Sleep/Wakes since boot at 2018-08-25 15:22:52 +0100 :0 Dark Wake Count in this sleep cycle:1 Time stamp Domain Message Duration Delay ========== ====== ======= ======== ===== UUID: (null) 2018-08-25 15:31:05 +0100 Start powerd process is started 2018-08-25 15:31:05 +0100 Assertions Summary- [system: No Assertions] Using AC 2018-08-25 15:31:06 +0100 Assertions Kernel Idle sleep preventers: IODisplayWrangler 2018-08-25 15:31:17 +0100 Assertions PID 97(hidd) Created UserIsActive "com.apple.iohideventsystem.queue.tickle.4294968964.3" 00:00:00 id:0x0x90000804e [system: DeclUser BGTask kDisp] 2018-08-25 15:32:23 +0100 Assertions PID 62(mds) Released BackgroundTask "com.apple.metadata.mds.power" 00:01:15 id:0x0xb00008016 [system: PrevIdle DeclUser BGTask kDisp] 2018-08-25 15:32:28 +0100 Assertions PID 202(mds_stores) Released BackgroundTask "com.apple.metadata.mds_stores.power" 00:01:07 id:0x0xb0000804f [system: PrevIdle DeclUser BGTask kDisp] 2018-08-25 15:32:33 +0100 Assertions PID 561(AddressBookSourceSync) Released PreventUserIdleSystemSleep "Address Book Source Sync" 00:01:00 id:0x0x1000080e3 [system: DeclUser kDisp] 2018-08-25 15:33:26 +0100 Assertions PID 281(backupd) ClientDied PreventUserIdleSystemSleep "Time Machine backup" 00:02:13 id:0x0x10000803b [system: DeclUser kDisp] 2018-08-25 15:33:26 +0100 Assertions PID 281(backupd) ClientDied BackgroundTask "Time Machine backup" 00:02:13 id:0x0xb0000803a [system: DeclUser kDisp] Total Sleep/Wakes since boot at 2018-08-25 15:31:05 +0100 :0 2018-08-25 15:43:10 +0100 : Showing all currently held IOKit power assertions Assertion status system-wide: BackgroundTask 0 ApplePushServiceTask 0 UserIsActive 1 PreventUserIdleDisplaySleep 0 PreventSystemSleep 0 ExternalMedia 1 PreventUserIdleSystemSleep 0 NetworkClientActive 0 Listed by owning process: pid 52(powerd): [0x0000000e00088000] 00:12:05 ExternalMedia named: "com.apple.powermanagement.externalmediamounted" pid 97(hidd): [0x0000001b0009804e] 00:00:03 UserIsActive named: "com.apple.iohideventsystem.queue.tickle.4294968964.3" Timeout will fire in 597 secs Action=TimeoutActionRelease Kernel Assertions: 0x10c=USB,BT-HID,MAGICWAKE id=500 level=255 0x4=USB mod=01/01/1970, 01:00 description=com.apple.usb.externaldevice.1d100000 owner=IOUSBHostDevice id=501 level=255 0x4=USB mod=01/01/1970, 01:00 description=com.apple.usb.externaldevice.1a100000 owner=IOUSBHostDevice id=504 level=255 0x4=USB mod=01/01/1970, 01:00 description=com.apple.usb.externaldevice.1a140000 owner=IOUSBHostDevice id=506 level=255 0x4=USB mod=01/01/1970, 01:00 description=com.apple.usb.externaldevice.1d120000 owner=BCM20702A0 id=507 level=255 0x4=USB mod=01/01/1970, 01:00 description=com.apple.usb.externaldevice.1a150000 owner=USB Mass Storage Device id=508 level=255 0x4=USB mod=01/01/1970, 01:00 description=com.apple.usb.externaldevice.1d160000 owner=SoundSticks id=509 level=255 0x4=USB mod=01/01/1970, 01:00 description=com.apple.usb.externaldevice.1d150000 owner=USB 2.0 Hub id=512 level=255 0x4=USB mod=01/01/1970, 01:00 description=com.apple.usb.externaldevice.1d154000 owner=USB 2.0 Hub id=514 level=255 0x4=USB mod=01/01/1970, 01:00 description=com.apple.usb.externaldevice.1d154300 owner=IOUSBHostDevice id=515 level=255 0x4=USB mod=01/01/1970, 01:00 description=com.apple.usb.externaldevice.1d154400 owner=SpacePilot PRO id=516 level=255 0x100=MAGICWAKE mod=01/01/1970, 01:00 description=en0 owner=en0 id=517 level=255 0x8=BT-HID mod=01/01/1970, 01:00 description=com.apple.driver.IOBluetoothHIDDriver owner=BNBMouseDevice id=518 level=255 0x8=BT-HID mod=01/01/1970, 01:00 description=com.apple.driver.IOBluetoothHIDDriver owner=AppleBluetoothHIDKeyboard Idle sleep preventers: IODisplayWrangler Any thoughts? am I on the right track??
Administrators MaLd0n Posted August 25, 2018 Author Administrators Posted August 25, 2018 c600 is very problematic in some cases for sleep, ure not alone -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
MMido Posted August 25, 2018 Posted August 25, 2018 Hello MaLd0n, I hope that you remember my setup and the problem I had with sleep in HS, now I followed your guide and install the Mojave image you provided I didn't add any extra KEXT or any patches to my DSDT or USB or anything. I really want you to do that from the beginning maybe we can fix the old problem I had in my X10DAI motherboard with HS if we start on a clean setup. Send me Idriss-iMac-Pro.lan.zip
