Used new dsdt and injected audio 3 through clover , but problem still exists.
Audio is fine when playing from internal speakers , and is fine when connecting to external speakers.
But when I connect earphones sound gets distorted as I said before , check with another set of earphones still there.
Any solution?
U need test all layout-ids for ur codec, one by one
Hi MaldOn,
I get usb sound adapter to avoid problems with my codec audio and voodoohda , and I disabled motherboard sound in bios.
every thing is OK and the sound more better than before , but I have problem with shutdown , when I connect the mic in microphone port of usb adapter system won't shutdown completely it's going to reboot.
would you please fix this for me
Thank you so much .
this is my send me file
http://www.mediafire.com/file/5awrbqbyb ... o.zip/file
try it and check if work
start up auto after a power failure
jonnyf wrote: ↑
Any solution?
Should I use any clover patches , like HDAS to HDEF ?
4TH HDEF is native
Perfect, works perfectly
Thanks MaLd0n so much.
I don't know what is happening with me, I don't change any thing and after finishing my work no shutdown !! even restart , must press the power button to shutdown :cry:
jonnyf wrote: ↑
Any solution?
Done!!
Used id 28 , headphones work ok now.
Can you check if there is anything that needs change / optimise ?
Thank you again , sir.
Send me MacBook-Pro.zip
:lol::lol::lol:
extract new files
Done!!
looks good
P.S.
I must clear logs every time before extract file because it was very large file
try
config.plist.zip
hi.excellent guide..congrats
i have a probook 4340s intel core i3 with 8 gb 2 hdd (dvdrw drive gone)
with intel hd3000
ive got installed sierra Olarila 10.12.6..works all fine
but im still see some errors maybe acpi..on the boot
can someone help me to patch all this please??
thanks again and congrats to maldon..in fact to all of you for this ..
have only one
is about processor, forget it ;)
wow.thanks mate,really appreciate..so i dont need to get worried then??
another question i like to ask,is ..i try to install mojave in the same laptop,but he said the computer dont met the requirements
can you check please my clover folder kexts if all is ok and ready for mojave?? or need to patch somethin?
thanks and best regards
i follow the guide for mojave with your clover folder but dont work or i dont know what i do bad..
use Olarila beta 6, release today, have a tools for it
Same thing reboot and not shutdown
no idea, bro
Thanks MaLd0n I appreciate your help and support
Welcome!
Enjoy!
MaLd0n wrote: ↑
jonnyf wrote: ↑
(3.32 MiB) Downloaded 1 time
@MaLdOn , do I need usbinjectall.kext ? I'm using dsdt file you sent me.
u can use without problem
Após várias tentativas consegui configurar a HD 3000, agora está funcionando quase tudo, só está faltando gravar nas partições NTFS e outra coisa é que não estou conseguindo configurar o BIOS para bootar no HD do Mac, nas opções com F11 aparece o HD (PO: SAMSUNG HD502HJ), mas na configuração de boot no BIOS aparecem MAC OS X e vários UEFI OS, mas todos entram no HD do Windows, como faço para remover essas entradas das opções de boot e configurar a certa?
Desde já agradeço.
Hi,
I installed OSX High Sierra successful, but I can't get Audio and USB 3.0 to work.
My setup:
ASUS P8P67
Intel i7-2600K
16GB 1600 MHz DDR3
NVIDIA GeForce GTX 1060 6GB 6143 MB
I run the RunME.app, file is attached.
I need help please.
Best regards
andibratan_
ur USB3 is not intel, if u use genericxhci kext, u found a some problems
CLOVER.zip
