aymantop1 Posted July 28, 2018 Posted July 28, 2018 (edited) use my DSDT, remove AppleAlc check what id u need use, u see that in app http://www.mediafire.com/file/bgm686e1x5i7btm/audio.zip/file My codec is not supported in desktop Edited July 28, 2018 by Guest
Administrators MaLd0n Posted July 28, 2018 Author Administrators Posted July 28, 2018 back for VoodooHda -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
aymantop1 Posted July 28, 2018 Posted July 28, 2018 back for VoodooHda need to do any config or fixes at clover and DSDT file you need send me file again
Administrators MaLd0n Posted July 28, 2018 Author Administrators Posted July 28, 2018 no just use voodoohda and AppleHDADisabler AppleHDADisabler.kext.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
aymantop1 Posted July 28, 2018 Posted July 28, 2018 no just use voodoohda and AppleHDADisabler AppleHDADisabler.kext.zip Many Thanks MaLd0n
Paulo-Guedes Posted August 1, 2018 Posted August 1, 2018 Não estou conseguindo habilitar a HD Graphics 3000 de jeito nenhum, então peguei uma ATI Radeon HD3850 de um PC encostado que tinha aqui. Sabem me dizer se é compatível? Obrigado.
Administrators MaLd0n Posted August 2, 2018 Author Administrators Posted August 2, 2018 Não estou conseguindo habilitar a HD Graphics 3000 de jeito nenhum, então peguei uma ATI Radeon HD3850 de um PC encostado que tinha aqui. Sabem me dizer se é compatível? Obrigado. a intelhd3000 é nativa, vc não precisa de nada, flag nem nada, precisa daquele patch que te disse somente se não funcionar a 3850 funcionava bem, usei durante muito tempo, a 4850 tb, teria de ver se ainda tem suporte, creio que sim -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Paulo-Guedes Posted August 2, 2018 Posted August 2, 2018 a intelhd3000 é nativa, vc não precisa de nada, flag nem nada, precisa daquele patch que te disse somente se não funcionar a 3850 funcionava bem, usei durante muito tempo, a 4850 tb, teria de ver se ainda tem suporte, creio que sim Pois então com a HD 3000 só entro com GraphicsEnabler=No (se não trava) e não consigo ativar a aceleração, coloquei o patch no DSDT.aml mas não adiantou. Para usar a 3850 tenho que fazer algo expecífico, tem um kext, como consigo? Com ela, o boot trava na hora que iria aparecer a tela da maçã. Obrigado.
rohit_dd06 Posted August 3, 2018 Posted August 3, 2018 for install use only one monitor with nvidia, use nv_disable=1 As per your instruction i completed my install but now how to work everything like original mac, I have no audio, no graphics i am sending you runme app files Please see & send me the Proper guide about post installation.... Thanks MaLd0 in Advance.... Please download From Below Link..... https://mega.nz/#!2cBTyCKb!x1n-mNGTHNEuZ9Mi50rXSYRVTMZWyP8EHvgcsQfRRfU
Administrators MaLd0n Posted August 3, 2018 Author Administrators Posted August 3, 2018 As per your instruction i completed my install but now how to work everything like original mac, I have no audio, no graphics i am sending you runme app files Please see & send me the Proper guide about post installation.... Thanks MaLd0 in Advance.... Please download From Below Link..... https://mega.nz/#!2cBTyCKb!x1n-mNGTHNEu ... vgcsQfRRfU CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rohit_dd06 Posted August 4, 2018 Posted August 4, 2018 CLOVER.zip Thanks MaLdon I will Check & Confirm you as fast as possible....
rohit_dd06 Posted August 4, 2018 Posted August 4, 2018 CLOVER.zip All r Set but now the Problem is Screen Jello at the time off Boot & desktop background set moment....Please See the screenshot Nvidia Connected Monitor is OK but Intel Connected is Jello Screen....
rohit_dd06 Posted August 4, 2018 Posted August 4, 2018 (edited) MaLdon Please see this image also.... How Can I Fix This? Now again I Attach My Run Me App File.... Send me Sayantikas-iMac.zip Edited August 4, 2018 by Guest
Administrators MaLd0n Posted August 4, 2018 Author Administrators Posted August 4, 2018 All r Set but now the Problem is Screen Jello at the time off Boot & desktop background set moment....Please See the screenshot Nvidia Connected Monitor is OK but Intel Connected is Jello Screen.... ur IntelHD work only for hardware acelleration, don't connect nothing there, connect only in nvidia -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rohit_dd06 Posted August 4, 2018 Posted August 4, 2018 ur IntelHD work only for hardware acelleration, don't connect nothing there, connect only in nvidia That means I have to connect my Duel Monitor in my Nvidia Graphics Card Slot?
Administrators MaLd0n Posted August 4, 2018 Author Administrators Posted August 4, 2018 That means I have to connect my Duel Monitor in my Nvidia Graphics Card Slot? Yes -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jonnyf Posted August 6, 2018 Posted August 6, 2018 Can anyone please help me ? I'm going to install Mojave beta for first time, even tonight if we have a new release. I need help with dsdt , ssdt and also whatever modification/optimisation for kexts and config.plist. Things I' like have (but feel free to change whatever you think is for the best for my system) : 1) HDMI audio 3) Brightness control 4) Proper cpu/gpu power management is proper for my laptop 5) Usb Injection. 6) Everything that's gonna make my laptop work like a true Mac. Send me MacBook-Pro.zip
jonnyf Posted August 7, 2018 Posted August 7, 2018 Can anyone help ? Wanna try out Mojave Beta 6. Thanks.
Administrators MaLd0n Posted August 7, 2018 Author Administrators Posted August 7, 2018 Can anyone please help me ? I'm going to install Mojave beta for first time, even tonight if we have a new release. I need help with dsdt , ssdt and also whatever modification/optimisation for kexts and config.plist. Things I' like have (but feel free to change whatever you think is for the best for my system) : 1) HDMI audio 3) Brightness control 4) Proper cpu/gpu power management is proper for my laptop 5) Usb Injection. 6) Everything that's gonna make my laptop work like a true Mac. use a last clover version and stay with one usb stick with system for boot if need CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jonnyf Posted August 7, 2018 Posted August 7, 2018 Seems ok , except audio. When listening to music with EarPods the sound is distorted , it hears like it comes from 2 different channels , to hear clearly the voice I have to move balance to upper right or left. Also , can you check if everything else is right? Thank you , sir. Send me MacBook-Pro.zip
Grigoris Posted August 7, 2018 Posted August 7, 2018 Hi MaldOn, I am sending you Send me file for my new iMac14,2 Board is Gigabyte B85-HD3 Processor Intel i5-4440S Video card MSI GTX 950 2048MB 10 Gb of memory Can you also setup config.plist for me. I will add part for SMBIOS. Thank you Grigoris
Administrators MaLd0n Posted August 8, 2018 Author Administrators Posted August 8, 2018 Seems ok , except audio. When listening to music with EarPods the sound is distorted , it hears like it comes from 2 different channels , to hear clearly the voice I have to move balance to upper right or left. Also , can you check if everything else is right? Thank you , sir. use it inject audio via clover DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted August 8, 2018 Author Administrators Posted August 8, 2018 Hi MaldOn, I am sending you Send me file for my new iMac14,2 Board is Gigabyte B85-HD3 Processor Intel i5-4440S Video card MSI GTX 950 2048MB 10 Gb of memory Can you also setup config.plist for me. I will add part for SMBIOS. Thank you Grigoris send me files, post here -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jonnyf Posted August 8, 2018 Posted August 8, 2018 jonnyf wrote: ↑ Seems ok , except audio. When listening to music with EarPods the sound is distorted , it hears like it comes from 2 different channels , to hear clearly the voice I have to move balance to upper right or left. Also , can you check if everything else is right? Thank you , sir. use it inject audio via clover DSDT.aml.zip Used new dsdt and injected audio 3 through clover , but problem still exists. Audio is fine when playing from internal speakers , and is fine when connecting to external speakers. But when I connect earphones sound gets distorted as I said before , check with another set of earphones still there. Any solution? Send me MacBook-Pro.zip
aymantop1 Posted August 8, 2018 Posted August 8, 2018 Hi MaldOn, I get usb sound adapter to avoid problems with my codec audio and voodoohda , and I disabled motherboard sound in bios. every thing is OK and the sound more better than before , but I have problem with shutdown , when I connect the mic in microphone port of usb adapter system won't shutdown completely it's going to reboot. would you please fix this for me Thank you so much . this is my send me file http://www.mediafire.com/file/5awrbqbybb41z68/Send_me_aymans-Mac-Pro.zip/file
