esses patches vem default qd instalamos o clover, mas eles estão desabilitados
Com muito custo consegui fazer subir o OS X, porém com uma imagem de outro tutorial, após subir o sistema, continuei por aqui, instalei o Clover que está na pasta files do pendrive do Olarila e então substitui pelo Clover da pós instalação, mas travou conforme a foto, daí bootei com o outro pendrive para subir o sistema e rodei o Runme.app (arquivo anexado), já evoluiu um pouco :D
Já agradeço a colaboração.
Send me Mac-mini-de-ZAS-TRAS.zip
a princípio use a nullcpupm pra se livrar do pendrive
NullCPUPowerManagement.kext.zip
if ur problem is framebuffer KP, u need read here
https://www.insanelymac.com/forum/topic ... or-mojave/
Idk if it's a fb related question or something else, will try to follow that guide. The only problem is that I don't know how to compile that. Tried to read the guide but didn't understand at all. :roll:
1st Hackintosh: MBP 14,2 X550VXK (7700HQ, 8GB DDR4 2400MHz, SSD+HDD 240GB+500GB, 950M 2GB)
2nd Hackintosh: Lenovo B50-50 (i3 5005U, 4GB DDR3 1333MHz, SSHD 500GB, iGFX)
3rd Hackintosh: Acer E5-571G (i3 4005U, 8GB DDR3L 1666MHz, SSD+HDD 120GB+500GB)
Hey @MaLd0n,
Just tried your new clover zip, and all works fine! QE/CI, IGFX, Audio and other works just fine! Only problem is battery (apparently shows 0%) and brightness (there's slider but no bg change).
Thanks for your hard work!
Cheers.
Run this app, and upload the file result here.
RunMe
Thanks & Regards
remova o DSDT editado, sobe o sistema sem nada
Hi I am on HP 840 g1 i7 4600-u
8gb ram ,500gb HDD
Intel HD 4600
Screen 1600x900
Can you give me clover boot folder with config.plist....please add smbios too
I will send you my dsdt sdst files for fixes
RunMe
Ran it, but it sticks every time at IOReg part. Seems it cannot save the file. Also I've granted accessibility requests, rebooted and retried, but no luck.
Mojave?
Mojave?
Yup, Mojave Beta 4. Don't know if this happens only of that pc, will try on my 1st hack in a second.
Edit: it took a while to reach that part, but it does the same thing on my 1st hack. Granted accessibility permission too, and also tried to launch it from terminal w/ sudo.
dont work good in mojave , is a beta system, need a extra permissions
How can I fix that?
How can I fix that?
u can extract dsdt, ioreg and tell me what hardware
My HW (Lenovo B50-50): i3 5005u, 4GB DDR3, SSHD 500GB, IGFX (currently fully working w/ QE/CI using your DSDT&Clover folder).
Attached Clover folder + IOReg 2.0/3.0. Thanks again man.
CLOVER.zip
IORegs.zip
looks good, what not work?
Only battery level and there's no settings for trackpad. Gestures works tho.
Hello Mald0n, I was wondering if you could help me patching this hackintosh. I love how you fine tune yours.
Thanks.
all is wrong in ur config, use only my clover folder and any hackintosh kext in L/E or S/L/E
CLOVER.zip
Battery check RehabMan repo
TrackPad, u need a correct kext
Olá pessoal.
Enfim consegui instalar e configurar o boot pelo HD, mas usei o Chameleon em BIOS Lagacy, só nãoo estou conseguindo configurar o Vídeo, li que HD Graphics 3000 é nativa, não precisa de instalação de kext, mas já gastei todo meu repertório de tentativas para configurá-la e nada, segue meu Boot.plist, se puderem me dizer se tem alguma coisa errada.
Outra coisa, porque meu Chameleon Wizard não reconhece minha conexão com a internet, Tem alguma versão mais recente que a 4.4.1?
Desde já agradeço.
aplica o patch via DSDT
"AAPL,snb-platform-id",
Buffer (0x04)
0x00, 0x00, 0x01, 0x00
