Hi Mald0n
My System
CPU: i3-2100
Main: Asus H61
VGA: Quado K620
But i can't not boot with clover to install
You can help me?
Thanks u so much!
What happens?
I installed the high Sierra finished, when the error appears as image, click cancel or open the computer stand, press the power button shutdown.
i use Clover #1
36389662_1483743388398414_6990476538902740992_o.thumb.jpg.bfa04f82f21de7e07a0828634a10dfad.jpg
i use Clover #1
what hardware?
use it
and check if appears log after new crash
My clover.
don't every change. just install nVidia Driver
run our app
RunMe.app
app generate all logs
run our app
RunMe.app
I can not run it because when I boot into the main screen, about 10 to 15 seconds is my computer has been standing, CPU is not working, mouse, keyboard ....
Audio and sleep problem here.
Using macOS High Sierra 10.13.1, with model identifier iMac12,2.
I managed to install video, LAN, audio with AppleALC.kext, PS2 and USB drivers and besides sleep, everything worked fine. Then, I left my computer unattended and it went to sleep. Funny, since if I try to put it to sleep with mac menu - Sleep, it doesn't shut down, only the monitor goes to sleep. When I tried to wake it up, it kept coming out of sleep and going back. Even the reset switch was useless. I had to shut it down completely and start it up again to properly boot. Since then, audio is dead, even if I redownloaded and replaced Lilu.kext 1.2.3. AppleALC.kext and VoodooHDA.kext are both useless. In Windows and Linux, audio works fine, as before.
All my kexts are in EFI partition, in /EFI/CLOVER/kexts/Other.
I have no idea how to fix sound or sleep problems.
Update:
Sound is working now. After more reading about kexts, I downgraded Lilu.kext from version 1.2.3 to 1.0.0 in EFI partition, /EFI/CLOVER/kexts/Other. Though I don't understand this, because it worked fine with version 1.2.3 for a day or so.
Send me admins-iMac.zip
MB: Asus P8P67 rev3.1
CPU: Intel i7 2600k (8M Cache, up to 3.80 GHz)
RAM: 16 GB DDR3 Corsair
VIDEO: NVIDIA GTX 1080 8GB GDDR5X 256bit memory
HDD 250GB (macOS 10.13.1), GPT, Clover
Update:
CLOVER.zip
MaLd0n,
should I replace my Clover folder with the one provided by you in the archive?
Will this config work if I upgrade to a newer version, like 10.13.5?
MaLd0n,
yes
take a shot
I just tried your Clover folder.
Audio: works.
LAN: does not work.
Sleep: works
Wake up from sleep: is horribly wrong.
I have noticed IntelGraphicsFixup.kext in there. I don't have an Intel graphics card. Does it have any other meaning?
Audio: works.
LAN: does not work.
Sleep: works
run .app again and post new files
These are the files generated by RunMe, with the CLOVER folder exactly as you uploaded it.
The only modification I did to the system was to install Nvidia Web Driver. But it does not load, macOS still uses OSX Default Graphics Driver.
with my files
Yes, with your CLOVER folder. I copied it in EFI partition, then I installed Nvidia Web Driver.
