Sorry Maldon the app has rw permissions and I gave rw permissions to the temp folder too without luck.
Sorry for my missunerstanding :C I'm somewhere lost.
Activated root user in catalina with same result.
The folder temp has drwx--rwx wheel pemissions. I don't know what to do :help
[ref]itzalak2[/ref], no idea what happen
But P55A-UD3 and P55A-UD6 won't even get to the clover menu.
They stop at "Loading Operating System 6_"
I had this same problem. I read on a nother forum that i needed to disable the USB3 controller. Did that and problem went away.
[ref]tk421_tt[/ref], check in windows what device need disable and apply a simple _dsm spoof
59 minutes ago, Francisco Nash Cardoso Junior said:
good evening, can someone fix my tables?
i patched ur file, use same
Hi..  I already install os on ssd.  I copy efi from usb to ssd efi.  But I unable to boost from OS.  It always start Window.  How can to fix this problem.?
Hello Mald0n,
First thank you so much for your work. I'm having a problem with every install I try. Every time I get apple nvme assert failed and I cannot install.
Do you think you can have a look if I show my config file?
Thanks in advance.
Abraços de Portugal!
Config.rar
Edited by Arktype
18 minutes ago, Arktype said:
Hello Mald0n
what ur hardware? sound like a dsdt problem, need a full dsdt patched
I have intel I7 8700. Asus Strix H370-F. AMD Vega 56
You need more info?
I created dsdt with SSDTime. Is that ok?
Edited by Arktype
what?
51 minutes ago, MaLd0n said:
what?
Forget about it, I passed that. Now the problem is when installing MacOS into my hard drive, the instalation freezes near the end. Any ideas?
Thank you
Edited by Arktype
Olarila is a real vanilla hack, here we use only full dsdt patched and put our hack like one mac, for me others ways = non-sense
9 hours ago, Sharl Danfa said:
Hello, can you please patch my DSDT? I'm having sleep issues. Thanks!
Hi everyone, I updated to Catalina 10.15.4, Clover Bootloader 5109, but when I update Lilu and Whatevergreen I have this error. What am I doing wrong? Thanks for your help
panic.zip
what hardware?
