Hello,
can someone help me with this configuration?
Asus Tuf z390 M PRO GAMING
MSI Radeon 580x Armor
I7 8700k
The system freezes when loading Mojave, with the apple screen. The bios has been correctly configured and I can't even start using the USB clover key. I can't understand what I could have done wrong.
Any help is really appreciated.
[ref]mattz80[/ref], put ur bios/uefi in default, disable casam and go
Got it done! Awesome!!! Thanks guys, I still need to do post install stuff because I don’t have Bluetooth working, and my pci tab on system report is all blank and stuff. Is there anyone that can help walk me through finishing this proper? Thanks again so much!
New build ASRock Z390 Phantom Gaming 9 i9-9900K MSI RX580 8GB Big Sur 11.0.1 32GB DDR4
First build ASRock Z270 Gaming K6 i7-7700K MSI RX580 8GB Mojave 10.14.6 32GB DDR4
[ref]rocky_mtn[/ref], u need post ur files
--Run_Me
RunMe.app
Sent them in the DSDT request thread, thanks again.
Sorry can u help me? I cant Runme.app although i do it same as on
. My error Increased delay x2 for IOREG dump. This will take a while...(33 sec).
My Laptop Lenovo T460 I5 6200- HD520- 8GB- SSD INTEL- ALC293. I run Mojave.
[ref]dunglq2ah[/ref], --Run_Me
RunMe.app
check utube video
Thanks u but I do it but its export my desktop file .ioreg not ZIP. I try again but not sucsess. Although i check runme.app on Security & Privacy !
If u had time seem me error in my dsdt when i run complie
5021, 6126, syntax error, unexpected PARSEOP_NOTIFY(Notify(\_SB.PCI0.LPC.PS2K, 0x01e9)). I search gg but not how to fix.
[ref]dunglq2ah[/ref], post ioreg and untouched dsdt
[ref]dunglq2ah[/ref], DSDT.aml.zip
ur brightness key is q14 and q15, i think ur ps2k device stay in oem ssdt, check it
[ref]dunglq2ah[/ref], need, but not in dsdt
[ref]dunglq2ah[/ref], ???
[ref]dom123you[/ref], check video about solution for it, need permission
Hi,
I have the same problem. Give permissions, reboot, run runme.app and same result. Isuing fresh catlina 10.15.1 installation from Olarila.
Any suggestion?
Thanks in advance.
[ref]itzalak2[/ref], need rw and extra permission
