Do we not need to make any bios changes before we attempt high sierra install?
Usually, Default settings are fine.
Donate
Gitter Chat
MSI B360 Gaming Arctic
Ok so I just finished installing HS on my GA-Z370-HD3 and everything seems to work except my graphics is crazy. Its bugging and theres a pink haze. Sleep even works correctly. How do i fix the onboard graphics?
[ref]honghd1993[/ref], replace full efi, reboot
EFI.zip
Hello Maldon. I am Lorenzo, from France. How are you doing?, hope you're fine my friend. I am needing help another time with a fresh installation of Mojave, with your 100/200/300 DSDT guide, and I have a kernel panic. I tried some times to install, but any time the same problem appears. The processor isn't recognised, and It is not possible to restart or shut down without a kernel panic. Even during the first installation, the restarting time is very long, thing I never noticed before.. I tried some things found on the net, but nothing worked, so I am asking for your help another time....Here are my files.
Thanks in advance !
Send me Lorenzs-iMac.zip
[ref]Lorenzoo[/ref], replace full EFI, reboot, enjoy
EFI.zip
MaLd0n wrote: ↑17 Jul 2019, 18:49
Lorenzoo, replace full EFI, reboot, enjoy
Thanks a lot, I will try this later and I tell you. Have a nice day.
Good evening Maldon. So with your new EFI folder, it works like a charm, processor well recognised and everything works perfectly. Thanks again !! have a nice day !
[ref]Lorenzoo[/ref], ;)
[ref]ariqk88[/ref], DSDT.aml.zip
Donate-Beer <---Useful Links <--
Problems with Paypal Donate? Check HERE
-Donated? Send me one PM
Can sleep but can't wake,can you help to fix this?
what happens with wake?
When my mac sleep and i want to wake but after i wake he can't wake and must restart, in kernel log he says "System Automatically restart After panic" i think is kernel panic
what the solution?
[ref]ariqk88[/ref], ur intelHD, some cases have a several problems with sleep
[ref]ariqk88[/ref], use one simple RX560, good price and amazing working under macos
