[ref]dealsxster[/ref], rx570 is native, just use whatevergreen for some fixs
no luck after new install utilizing above dsdt same second stage flash/black screen on preboot etc. also added the dsdt.aml to existing IGD 630 install that works otherwise but exact same results when using rx 570. whatevergreen is already there.
[ref]dealsxster[/ref], u don't need dsdt for video, use this just for good fine tunning, video solve/inject via clover if need
ur RX is XFX?
its ASRock rx 570 8gb. the issue is very common (second stage flash/black screen on install and boot), and I am trying all suggestions one by one that people have tried before
[ref]dealsxster[/ref], the flash is common in all rx, vega, etc
not a problem, just ignore
I see what you are saying Mald0n, my problem is screen is black after flash no osx no display, I reboot after waiting 15-20 minutes and same thing "stuck at black screen again". I am guessing my problem is different or I am doing something wrong in my plist or command line parameters. I will try GraphicsEnabler=Yes IGPEnabler=No and see if it makes it different.
The only way it works is if I only enable IGPU and use hdmi on IGPU. I am doing something stupid. If you have a moment can you please check my plist.
config.plist.zip
[ref]dealsxster[/ref], disable csm in bios/uefi and check if problem is gone
Post by MaLd0n » 30 Apr 2019, 05:25
dealsxster, disable csm in bios/uefi and check if problem is gone
Thanks Mald0n, resolved a few minutes back, your CSM hint came in handy, CSM was disabled all this time, actually Enabling CSM/(on MSI board its called Windows WHQL blah blah) fixed the blank screen issue. Let's hope it remains stable while enabled.
What do you recommend as further test to make sure all is ok. Can i run any health diagnostics etc. is there a report/log somewhere that captures issues?
[ref]honghd1993[/ref], DSDT.aml.zip
Added in 2 minutes 40 seconds:
--Run_Me
RunMe.app
Posting Following just in case someone runs into the same issue.
MSI Mortar z370m
Bios Version 7B54v15
"Windows WHQL Options were Enabled/Disabled" -- select "Enabled" to avoid Blank Screen issue
Bios Version 7B54v16
Today after upgrading BIOS to 7B54v16 "Windows WHQL Options are CSM/UEFI" - select "UEFI" to avoid Blank Screen issue
[ref]dealsxster[/ref], :cap
Hi all! Is this guide working on a motherboard from MSI? The m.board model is MSI B250 PC MATE(KabyLake), the other components are: GeForce GTX 1060 from Zotac with 128 bit rate, CPU: i5 7500 3.4 Ghz. I dont understand what does it mean in title "on Serie 100/200/300/DSDT" :( Can help me someone? :D thx, regards Roland ^_^
[ref]vaddiszno16[/ref], use high sierra and clover folder for serie 100/200/300
Try use displayport instead hdmi. I got my asrock rx 580 working with displayport to hdm conventer. When i use hdmi i got black screen
[ref]aldita[/ref], 4k?
[ref]aldita[/ref], try disable csm option in bios/uefi
