Hi @MaLd0n, thanks for your help.
Finally, I have install the integrated audio and USB 3.0 work, or so I think. Sleep mode does not work. HDMI audio I don't know, don't have at this moment HDMI cable, only HDMI to DVI. I upload my config.plist to the DSDT thread to see if you can take me a hand.
Sorry for my bad English :D
Hack 2018: Z370 Ultra Gaming 2.0, 8700K, 2x8Gb Corsair Vengeance RGB 3200Mhz, Samsung 970 EVO M.2, GTX 1070 G1 Gaming, Phanteks Eclipse P400S, High Sierra.
Hack 2019: Z370M D3H, 8400, 1x8Gb Corsair LPX 2400Mhz, Samsung 850 EVO SATA, RX 580, Raijintek Styx, Catalina.
[ref]xXMulliXx[/ref], --Run_Me
RunMe.app
xXMulliXx, --Run_Me
RunMe.app
Yes, I read in the other post and upload my RunMe :D
Very thanks MaLd0n :)
Hi MaLd0n,
I have tried to install Olarila Mac OS Mojave on a Dell AIO 5250, with an intel i3-6100, Intel Q270 motherboard chipset, Intel HD 530 and 8Gb RAM DDR4 and I got a kernel panic.
I am new to Hackintosh, therefore I need some help. I attached the origin folder, not sure which files do you need from there. I also attached a printscreen of the kernel panic.
https://imgur.com/a/6kBS6Bu
Can you advise me how to solve this issue? Thanks in advance!
origin.zip
[ref]lolost[/ref], DSDT.aml.zip
lolost,
(36.25 KiB) Downloaded 2 times
I'm having massive graphical artifacts, just like before your DSDT. Any idea to fix this?
Thanks again for your support.
[ref]lolost[/ref], iMac18,1 smbios
Hi MaLd0n!
Starting with Clover r4899 until the last version I have the following errors in my logs:
(AppleACPIPlatform) ACPI Error:
(AppleACPIPlatform) [\_SB_.PR00]
(AppleACPIPlatform) Namespace lookup failure, AE_NOT_FOUND
(AppleACPIPlatform) (20160930/dsobject-207)
(AppleACPIPlatform) Executing subtree for Buffer/Package/Region
(AppleACPIPlatform) ACPI Exception: AE_NOT_FOUND,
(AppleACPIPlatform) Could not execute arguments for [PSL_] (Package)
(AppleACPIPlatform) (20160930/nsinit-513)
If is helping you, in the Clover r4899 release notes say: “make byte ACPI access, optional ASPM”.
My system is: Gigabyte Z370N, WIFI BCM94360CS2, i5-8600K, MSI RADEON RX560 AERO, Mojave 10.14.3.
Thank you very much for your help!
Send me iMac.zip
[ref]Florin_[/ref], Some update, check if work
CLOVER.zip
[ref]Florin_[/ref], the error stay in ssdt OEM, just ignore
[ref]F3lixgram[/ref], :meeting:guitar
