xwajuk Posted March 10, 2019 Posted March 10, 2019 don't need replace clover folder inside usb stick, Olarila image have it At first time, before I replaced CLOVER folder at USB stick I run installation and it crashed at the end shown at screen. So raw Olarila image doesn't have it Added in 11 minutes 6 seconds: Today I found this guide: https://github.com/cmer/gigabyte-z390-aorus-master-hackintosh/blob/master/STEP_BY_STEP.md Section: Fixing Kernel Panics at Reboot/Shutdown Author says that NVRAM is not natively working on Z390 motherboard. I realise it is Gigabyte and I have Asus. But both are very similar Z390's motherboards. Quote author: When I added EmuVariableUefi-64.efi to /EFI/CLOVER/drivers64UEFI , I got a crash at bootup. The solution to that crash is to remove AptioMemoryFix-64.efi and to replace it with OsxAptioFix2Drv-free2000.efi. Does it make sense?
Administrators MaLd0n Posted March 10, 2019 Author Administrators Posted March 10, 2019 Author says that NVRAM is not natively working on Z390 motherboard. I realise it is Gigabyte and I have Asus. But both are very similar Z390's motherboards. i fix it via dsdt, use emuvariable only in install if need, after i'll patch it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zackal Posted March 13, 2019 Posted March 13, 2019 Thanks to it, I am using it well. offline Gen95, I want to know if this is full acceleration. Can you tell me if there is a solution? Thank you.. Send me zzkui-iMac.zip
Administrators MaLd0n Posted March 13, 2019 Author Administrators Posted March 13, 2019 [ref]zackal[/ref], yes, is config is correct, looks good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
minseung0119 Posted March 14, 2019 Posted March 14, 2019 can you make this system's DSDT? CPU : Intel i9 9900K M/B : GIGABYTE Z390 AORUS MASTER VGA : Sapphire RX590 Thunderbolt : ASUS ThunderboltEX3 w/CABLE Send me hacui-iMac.zip
Administrators MaLd0n Posted March 14, 2019 Author Administrators Posted March 14, 2019 [ref]minseung0119[/ref], DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
minseung0119 Posted March 15, 2019 Posted March 15, 2019 minseung0119,DSDT.aml.zip (40.94 KiB) Downloaded 1 time Thanks. I used this file on mojave. I have found some problems. 1. The Sapphire RX590 Nitro + fan stops when it enters the OS. And it does not turn on. It worked normally during the OS installation process. WEG + Lilu has been updated to the latest version. 2. USB 3.0 port and USB 3.1 port do not work except 4 USB 2.0 ports. 3. I mistakenly mistakenly inserted a ThunderboltEX3 card into a PCI-E 8x slot. It is now properly installed in the PCI-E 4x slot. Send me hacui-iMac.zip acpi_origin.zip when I booted Clover, I pressed F4 to attach ACPI Origin. Attach Runme.app with no DSDT applied.
Administrators MaLd0n Posted March 15, 2019 Author Administrators Posted March 15, 2019 [ref]minseung0119[/ref], about fan, it's common, if stay in low temp, fan stop, some times before enter system fan is crazy, u can try a agpm enable --USB Fix https://Olarila.com/forum/viewtopic.php?p=65287#p65287 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
minseung0119 Posted March 15, 2019 Posted March 15, 2019 minseung0119, about fan, it's common, if stay in low temp, fan stop, some times before enter system fan is crazy, u can try a agpm enable Is DSDT about replacing slots in Thunderbolt cards possible to work without being created?
Administrators MaLd0n Posted March 15, 2019 Author Administrators Posted March 15, 2019 [ref]minseung0119[/ref], thunderbolt dont work with "built in" inside tables, we need create one by one -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
snakepit122 Posted March 16, 2019 Posted March 16, 2019 MaLd0n wrote: ↑10 Mar 2019, 06:58 don't need replace clover folder inside usb stick, Olarila image have it At first time, before I replaced CLOVER folder at USB stick I run installation and it crashed at the end shown at screen. So raw Olarila image doesn't have it Added in 11 minutes 6 seconds: Today I found this guide: https://github.com/cmer/gigabyte-z390-a ... BY_STEP.md Section: Fixing Kernel Panics at Reboot/Shutdown Author says that NVRAM is not natively working on Z390 motherboard. I realise it is Gigabyte and I have Asus. But both are very similar Z390's motherboards. Quote author: When I added EmuVariableUefi-64.efi to /EFI/CLOVER/drivers64UEFI , I got a crash at bootup. The solution to that crash is to remove AptioMemoryFix-64.efi and to replace it with OsxAptioFix2Drv-free2000.efi. Does it make sense? I have the same problem, the installation gets stuck 1 minute before I finish, I will try to remove AptioMemoryFix-64.efi and replace it with OsxAptioFix2Drv-64.efi, and it will not work for me, but when I change my USB 3.0 into port 2.0 the installation it ended perfectly Asus Prime H310 Intel Core i3 8100 8GB RAM HyperX 2400mhz Asus Rx 470 4GB Strix
Administrators MaLd0n Posted March 16, 2019 Author Administrators Posted March 16, 2019 [ref]snakepit122[/ref], the best is fix it via DSDT and use aptiomemoryfix, best driver ever -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
minseung0119 Posted March 19, 2019 Posted March 19, 2019 minseung0119, thunderbolt dont work with "built in" inside tables, we need create one by one Can you tell what the ACPI error is during boot?
Administrators MaLd0n Posted March 19, 2019 Author Administrators Posted March 19, 2019 [ref]minseung0119[/ref], some is about ssdt oem, ignore it, other is about usb extract one send_me, i'll check -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
minseung0119 Posted March 19, 2019 Posted March 19, 2019 minseung0119, some is about ssdt oem, ignore it, other is about usb extract one send_me, i'll check Yes I uploaded. DSDT used the modified DSDT for the Z390 Aorus Master. CPU : Intel i9 9900K M/B : GIGABYTE Z390 AORUS MASTER VGA : Sapphire RX590 Thunderbolt : ASUS ThunderboltEX3 w/CABLE Send me hacui-iMac.zip
Administrators MaLd0n Posted March 19, 2019 Author Administrators Posted March 19, 2019 [ref]minseung0119[/ref], use only it with last clover version CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
yumo Posted March 23, 2019 Posted March 23, 2019 minseung0119, use only it with last clover version CLOVER.zip Hi, MaLdon What is RTCMemoryFixup.kext in the Kext folder?
Administrators MaLd0n Posted March 23, 2019 Author Administrators Posted March 23, 2019 [ref]yumo[/ref], https://github.com/acidanthera/RTCMemoryFixup -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
xXMulliXx Posted March 23, 2019 Posted March 23, 2019 Anyone have a guide for Z370M D3H? Install Mojave but when I install clover the system does not start without the pendrive. I followed the guide there but I can not start it from the SSD. I've been trying to install everything well since yesterday but it's impossible, I'm about to give up Im novice in hackintosh. My hack: Gigabyte Z370M D3H i5 8400 Radeon RX 580 8Gb Ram Corsair 1xM.2 SSD Kingston 1xSATA SSD Samsung EVO (when i install MOJAVE) Thank you Hack 2018: Z370 Ultra Gaming 2.0, 8700K, 2x8Gb Corsair Vengeance RGB 3200Mhz, Samsung 970 EVO M.2, GTX 1070 G1 Gaming, Phanteks Eclipse P400S, High Sierra. Hack 2019: Z370M D3H, 8400, 1x8Gb Corsair LPX 2400Mhz, Samsung 850 EVO SATA, RX 580, Raijintek Styx, Catalina.
Administrators MaLd0n Posted March 23, 2019 Author Administrators Posted March 23, 2019 [ref]xXMulliXx[/ref], use last bios/uefi version, if don't work, use previous version -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
