[ref]bin209199x[/ref], DSDT.aml.zip
[ref]javad[/ref], solve what?
hello MaLdOn,
had to change my Graphics with Sapphire Nitro+ Radeon RX590 8G, because my GTX 760 just died - Nvidia Web Drivers are installed.
tried to boot into the Sierra (config iMac 17.1 with Clover v2.4k r4769) System, but there's only a black screen and some seconds later the fans blow up at full speed.
can you help with the modification of my last used Send Me file.
thx
Send me CooSeeS-iMac.zip
bequiet! Silent Base 800 Black
MSI C236A Workstation - Intel Xeon E3-1245v5 - 32GB RAM Kingston - Sapphire Nitro+ Radeon RX590 8G
Samsung SSD PM970 EVO M.2 500GB - Gigabyte AORUS PCI-E NVME 1TB
Teufel Concept C 2.1
HyperX Alloy Elite RGB - Optical Gaming Mouse G400
[ref]CooSee[/ref], use it with last clover version
CLOVER.zip
enable intelhdgraphics in bios/uefi too
thx for quick reply :frantics
why should i activate Intel graphics ?
i have a multi monitor system - should i buy a third one :lol:
sorry to say, but the system just restart with rx 590, with your sierra image.
should i install current Clover on USB and replace it with the modified one ?
or boot the USB with enabled Intelgraphics ?
wich option is necessary at the boot option on my old sierra system to boot and get rid of Nvidia Web Drivers.
using >> dart=0 nvda_drv=1 >> Clover Version r4769 right now.
i forgot some things - used osx 3 month ago.
[ref]CooSee[/ref], i think u need a high sierra, rx5xx don't work native in sierra
CooSee, i think u need a high sierra, rx5xx don't work native in sierra
ok, good to know - thx for your help.
[ref]CooSee[/ref], use a high sierra 10.13.6 and GPU work native, just use whatevergreen for some fixs
CooSee, use a high sierra 10.13.6 and GPU work native, just use whatevergreen for some fixs
sorry to bother you again :boxing
i somehow managed to install Mojave - Graphics show up as RX 580 - should be 590 >> is this ok ?!
my modified Clover Folder works on all OSX Versions, maybe except Sierra ?
and with current Clover, at Boot, what is the ' Prebooter ' Option ?
it seems that i can't install Updates >> Mojave Supplemental Update !
after restart, the Update reappears again.
[ref]CooSee[/ref], no problem about 580/590, just cosmetic
in Mopjave, update is like one new install, download update via app store, reboot and select install macos... and wait 2 or 3 reboots
ok, got it, update went through - everything's perfect now.
MaLd0n, you should consider buying this fruit dealer company, because you make by far better software and support :lol:
i'll buy you a beer when i got my next big paycheck!
thx a lot for your time and effort.
[ref]CooSee[/ref], :mrgreen: just enjoy, my friend :cap
Hardware: asus z370 Prime A , Thunderbolt Ex3 , Usb 3.1
try with a KGP SSDT for TBH
Hi
As you wrote here:
1.
I have downloaded Olarila Image - Mojave 10.14.3
https://drive.google.com/file/d/1malP3BGbC6coziRouv4mnqmJBcY1jFVY/view?usp=sharing
2.
Unzipped and burned at my 16GB USB stick
3.
Replaced Clover folder to this
https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.100.200.300.zip
4.
Run installation at my machine - configuration below
5.
Result is frozen mouse cursor / screen at last minute of installation
Verbose error screen:
https://www.dropbox.com/s/7mp59vvr7ogo2jp/hck_screen_error_10mar.jpg?dl=0
What is reason of it? And how to fix it?
At local Hackintosh forum someone said that it might be unsupported NVRAM by Z390 chipset. I'd like to confirm it here - this forum seems to be much more professional :)
My configuration:
* Asus Prime Z390-Plus Gaming
* Intel i7 8700
* 16GB 3200MHz CL16 Predator
* Sapphire Radeon RX 580 4GB Nitro+ (currently power cables are disconnected, I use GPU for installation time. Is it necessary?)
* Samsung 970 Evo M.2 250GB
* 600W powed supply
Bios configuration taken from this video:
Hi
use bios/uefi in default, dont need change nothing
don't need replace clover folder inside usb stick, Olarila image have it
