[ref]Mexox[/ref], DSDT.aml.zip
Thanks MaLdOn!
Unfortunately I've got a kp and I am having difficulties booting with your EFI folder.
Can you please suggest a config.plist for my computer?
I am also trying to use 2 monitors connected to dp. Thank you
Computing System
Processor Intel Core i5-6400T Processor (quad core 2.2GHz, up to 2.8 GHz)
Chipset Intel 100 series chipset
System Memory 2 x DDR3L-1600 SODIMM Slots, Max 16GB
Graphics
Graphics Engine Intel HD Graphics 530
Video Output 2 x DisplayPort: 3840x2160 @ 60Hz;
HDMI: 4096x2160 @ 24Hz
(max 4K@60Hz output with one panel display)
Storage
Hard Drive 1 x 2.5" SATA 6Gbps HDD/SSD Slot
Mass Storage N/A
Optical Drive N/A
mSATA N/A
M.2 1 x M.2 SATA SSD slot (22/42,22/60,22/80)
Card Reader 3-in-1 (SD/SDHC/SDXC) / USB 3.1 port Combo
I/O Ports
Audio Stereo output , Microphone
USB Port 1 x USB 3.1 type-C (front)
2 x USB 3.0 (back)
1 x USB 2.0 (top)
LAN 2 x 10/100/1000 Mbps
Antenna Yes
Wifi 802.11ac
Bluetooth Bluetooth 4.0
Legacy I/O N/A
CIR Infrared Port Yes
[ref]Mexox[/ref], use our clover folder for serie 100
post one KP photo
Mexox, use our clover folder for serie 100
post one KP photo
Get KP trying to install Mojave. I also get KP if I use your clover folder for my current High Sierra install.
The boot sequence is very quick and I get to the attached screen. Thanks
[ref]kaitgaming[/ref], DSDT.aml.zip
Added in 38 seconds:
[ref]Mexox[/ref], u need check what cause it, some drivers UEFI or InjectIntel
hi MaLd0n
i'd installed Mojave and was using it before sent my MB for warranty... now i got it back and i cant boot into OS or Installer...
i used this link to install but i boot into OS with your provided EFI :
i tried many different EFI's or methods to create USB Installer but the same problrm.
my hack specs : msi B360 gaming plus - 8700k - 16GB ram - ssd EVO 960 250GB - GTX 1070
may you help me?
[ref]pi2in3[/ref], MSI, ASROCK and ASUS, new mobos 300 series, have a problems, the best now is Gigabyte
tnx
i found the the problem origin, the updated my bios to last version. i downgraded to older one. and now i'm on majave 10.14.1 but i have some problem.
USB3.1(0) ports only detect USB2.0 devices. USB3.1(0) devices work only on USB2.0 Ports.
when i power-off it restarts instead , and it's obvious that restart isn't a real reboot.
i think i need some DSDT patch but i'm not familiar with.
[ref]pi2in3[/ref], u need post ur files
RunMe.app
[ref]pi2in3[/ref],
[ref]pi2in3[/ref], use only this clover folder with last clover version
CLOVER.zip
shutdown and reboot work smooth, thanks. also sleep/awake works perfectly but after awake my USB flash didn't mount
USB ports now are working nice. Tnks again
Added in 11 minutes 12 seconds:
may i ask you teach me DSDT patching?
i want to patch my friends Hackintoshs
i'm sorry i bother you, USB issues return again. i connect ext-HHD and Flash disk (both usb3.0) to USB3.0 ports but don't work. just work on USB2 ports. :?:?
i send you my files again
appreciate if you check it again
@Maldon, tenho um Lenovo P50 qual versão voce recomenda para tentar um Hackintosh?
Baixei a imagem do Mojave, gerei o PenDrive ... mas quando dou o Boot ele fica no shell> e não avança
