[ref]pridees[/ref], DSDT.aml.zip
Hello, in my case the Intel UHD Graphics 630 is not displayed as "Display controller" and "Build In". Do you think is OK?
Thank you very much!
[ref]Florin_[/ref], yes, is ok too ;)
[ref]pridees[/ref], :guitar
Baptiste94, the patches
change GFX0 to IGPU
47465830
49475055
change HDAS to HDEF
48444153
48444546
change HECI to IMEI
48454349
494d4549
change SAT0 to SATA
53415430
53415441
is mandatory, some ssdt oem have a device and need rename too
the IGPU is mandatory for good hardware acceleration, work together with NVIDIA/AMD
Hi MaLd0n, thank you for your detailed answer. I've changed my config.plist and enabled the IGPU of the 8700k according to your advices.
I attached the "send me" file, can you please provide me a fully patched DSDT ?
8700k - 64Go DDR 3200MHz - Z370 Aorus Gaming 5 - Gigabyte GTX 1080Ti - Samsung 860 Pro - Samsung 970 Pro NVme - Blackmagic DeckLink Mini Monitor 4K
MacOS 10.13.6
Thank you :)
Send me BlueGene.zip
[ref]Baptiste94[/ref], CLOVER.zip
[ref]Baptiste94[/ref], :guitar
[ref]MaLd0n[/ref], Just one question, my main SSD used for the OS ( Samsung 860 Pro) has T.R.I.M support disabled under "About My Mac>SATA" is it normal ? My Nvme 970 Pro has TRIM support enabled under "About My Mac>NVMExpress".
[ref]Baptiste94[/ref], NVME have a native trim, SATA HDD/SSD no, u need enable it, in some cases trim+apfs cause a slow boot time
[ref]MaLd0n[/ref], ok, would you recommend turning it on even tho my ssd is APFS ? I don't mind slow boot time.
Can I revert to TRIM disabled if the boot time is way to long or is it permanent once enabled ? Thanks
[ref]Baptiste94[/ref], yes and yes, u can use without any problem, just gain some seconds in boot :cap
[ref]MaLd0n[/ref], I hope you can help me with DSDT patching. Attached is the output from the runme.app. I am using a gigabyte h370n wifi board, i5-8400 and igpu. Let me know if you need anything else. Thanks.
Archive.zip
[ref]Maxdawg[/ref], DSDT.aml.zip
open . /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/English.lproj/
Added in 2 minutes 32 seconds:
[ref]klraj[/ref], ?
