i manage to install high sierra, now im getting trouble working on my nvidia 1080 drivers
Added in 16 minutes 17 seconds:
i install the pkg nvidia drivers for the high sierra version, and i think it work im running the mac osx from my nvidia 1080gtx, the hdmi sound is the problem now any guess?
[ref]darktrevize[/ref], the whatevergreen have a hdmi patch, check there
Hi, MaLd0n ... I just build my first hackintosh, and with your help, and great tutorial it went smoothly ... for w while :hammer
System is now booting. I create clover partition on ssd, and replace with yours clover folder (x299).
System work fine, but few things don't work :help ... for this time I notice - USB 3.0, WIFI (info: there is no wifi card install), Bluetooth (Not available), sleep mode don't work property (I can't wake up computer), USB-C not working(this is very important, because I have to plug-in wacom tablet), my sound card on USB generate some crackling in the speakers (maybe on USB 3.0 it will work fine)
Hardware specification:
AsRock Taiche XE x299
i9 7920x
RX 580
970 EVO 1 TB
I guess it is DSDT tune problem, so I send you file from RunMe.app
Send-me-MBP15.zip
Thank you MaLd0n for the file. I think I do something wrong.
I put your DSDT.ami file in EFI (mount) --> EFI --> CLOVER --> ACPI --> patched
but everything still not working. I read about 20 pages of this threat, but can't find any tip.
Can you tell me how to patch this DSDT file ? Maybe there is some youtube tutorial (i try to search on my own, find, but unfortuletly on video, guys change file in "origin" folder, but my "origin" folder is empty :|
or maybe you can send me whole "CLOVER" folder ?
I'm sorry for my poor knowledge in this matter, but on my defense I will remind that this is my first hackintosh.
Thanks for your help! I promise I don't forget buy you a beer :)
Define "everything not working".
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]denisgrusz[/ref], use our clover folder for serie x299 and DSDT
[ref]jessen[/ref], DSDT.aml.zip
onemanosx i define it in my first post
MaLd0n I used yours clover for serie x299 and paste DSDT ... I do it on EFI partition, and on MacOS SSD drive in folder EFI (path I show on screenshot).
I also try to patch DSDT as you show on this video ...
I download MaciASL software to open DSDT.ami as you do, but no luck. File don't want to open with this software :(
I must doing something wrong :frantics Sorry for being such a noob :oops:
OK. I have read a lot of post on this forum, and I think maybe I don't reboot after put your x299 CLOVER folder, and immediately start RunMe.app and send to you.
Maybe we should try again ?
What I have done this time:
- Instal Fresh Clover EFI v2.4k r4844
- Put your x299 CLOVER folder on both partition (EFI and MacOS) - please tell me ... where I exactly should put it ?
- Reboot
- Start RunMe.app
- Send you SEND ME file
Also I mention I download a "Clover Configuration", and I don't know why i cannot mount EFI partition (so if I will need to paste your DSDT.aml file to EFI partition I can't) to see EFI partition I must install once again "Clover EFI v2.4k r4844".
Also I attach photo from Clover ACPI patching menu (maybe there is some issue?)
Thanks! and sorry for post by post.
Send-me-MBP15.zip
[ref]denisgrusz[/ref], install clover, replace folder and install clover again
Hi MaLd0n,
I use usb 2.0 for making installer.
I have a problem, my pc boot from usb complete but after that, it disconnect to my display (HDMI port) so i cant install. I think problem is HDMI Port ?
Edit: add screenshot
Thanks for your help!!!
MaLd0n I got to work USB 3.0 (thanks for link to tutorial), with wake on sleep is strange ... because once it's working, once not. I must check on windows if there is the same problem ...
Also WIFI after patching still don't working. I don't really need this ... but it will be nice to have it. Any idea where may be a problem ?
[ref]denisgrusz[/ref], extract new SEND_ME
[ref]brucemen[/ref], audio and video inject via clover
This time, when I use a RunMe.app it can't save file ... don't know why.
In app I have this log:
"IOREG dump failed. Retrying
Increased delay x2 for IOREG dump. This will take a while...(33 sec)"
I notice in /tmp folder there is "send_me" folder, so I compressed folder, and send to you.
send_me.zip
[ref]denisgrusz[/ref], u have a full dsdt patched
Hi MaLd0n,
I try to patch iGPU so many time (mine is UHD 630), but if i try inject value 0x59120000 or 0x591B0000 to ig-platform-id then i only get 7MB vram.
If i try another value then my hackintosh cant connect to HDMI port.
You can show me some example for inject via clover?
Thanks for your help!!! :D
brucemen, audio and video inject via clover
(47.87 KiB) Not downloaded yet
[ref]brucemen[/ref], my notebook with IntelHD620
1833302276_CapturadeTela2019-01-13s14_24_54.thumb.png.c69c8aa047a6c117654f18a90e3612cd.png
Hi MaLD0n,
Mine is Coffelake IntelUHD630.
which ig-platform-id i shoud try ? i try 00001259 and 00001b59 w
without any luck, only get 7MB :cry:
Thanks.
Refer by username
Report this post Quick quote
Post 13 Jan 2019, 23:25
brucemen, my notebook with IntelHD620
Captura de Tela 2019-01-13 às 14.24.54.png (266.73 KiB) Viewed 5 times
