bbeyes, viewtopic.php?p=65287#p65287
no caso eu vou ter que formatar e instalar o os de novo para fazer isso ?
não entendi muito bem, desculpe
[ref]bbeyes[/ref], não
só seguir o tutorial e add as infos no config.plist
Added in 1 minute 31 seconds:
[ref]arthe[/ref], u need activate IntelHDGraphics in bios and use shikigva=60
arena, use one usb stick usb2 and check if work
I tried with usb2 and it seems, solved my problem. But after the command screen, my monitor is turned off, no signal and I cannot get the mac os installation language selector. Any idea? Thanks! (I have no GPU card, using integrated)
arthe, u need activate IntelHDGraphics in bios and use shikigva=60
I did it but not help. I use RX 580 Pulse 8GB so i dont know that can help. Still have random restart, few minutes after start :(
I use i7-9700K processor model, maybe this is the reason of problems (9 generation).
[ref]arthe[/ref], 9th have a native support, the problem is video and usb
arthe, 9th have a native support, the problem is video and usb
Ok i understand. But you help me create correct config.plist so i don't know what can be wrong. Or you only add dsdt?
I attached again my config.plist if you could check it one more time maybe you find what is wrong.
I attached that do not recognaize my cpu too.
config.plist.zip
Could you help me with the correct configuration of the BIOS in an MSI Z370M Gaming Pro AC? I am having problems installing hackintosh on my computer, I have tried both with mojave and with high saw but finally I can not install the system.
I am using an MSI Z370M Gaming Pro AC + i7-9700K + Corsair Vengeance LPX DDR4 3000 PC4-24000 32GB 2x16GB CL15
Thank you.
[ref]arthe[/ref], looks good
Added in 13 seconds:
[ref]Pako Soto[/ref], what problem u have?
[ref]Pako Soto[/ref], format a entire disk
Thanks Marlon, finally I was supposed to format with APFS instead of MacOS Plus registered. I have been able to install the system but there are still many things that do not work. I created the file with RunMe.app and I posted it in DSDT request forum.
Thanks again!
arthe, looks good
But Photos still reboot :(
I tried to check is gpu problem and when i boot system from iGPU (i changed settings in BIOS) i have turquoise screen and i don't see login screen. Unfortunatelly this config.plist not fully working for me.
I tried with clean clover config.plist but problem with Photos still exist.
[ref]arthe[/ref], dont change any bios config, only serial port if need
"Youtube MacOS Install Guide Olarila" is dead (Video unavailable
"Hackintosh Guide - MacOS In..." is no longer available due to a copyright claim by Apple Inc.)
Please re-upload this video to another site, so we can download it then play
[ref]sabbirbd[/ref], post in only one topic
[ref]amoloxo90[/ref], DSDT.aml.zip
hello my pc config its and i7 7700 processor , geforce 1080gtx gpu and a msi h170a motherboard, my instalations fails at the starts, i recive a prohibited simbol , can you help me through this, i think my bios config is ok, but somehow the installation don't run, my monitor is plugued in the native video card of the board, and i disable the gpu
[ref]darktrevize[/ref], use other usb port, usb 2 port
[ref]darktrevize[/ref], some images need 16gb, check it
