[ref]artnr28[/ref], if don't have support...fail :mrgreen:
[ref]artnr28[/ref], back up ur clover folder ;)
[ref]Florin_[/ref], yes, update bios, after update extract tables with f4 in clover boot screen and extract SEND_ME
[ref]Florin_[/ref], DSDT.aml.zip
Hi, any chance you can help?
please.
non of my usb is working again, on the other end- the bluetooth is visible....but handsoff is not working , or airdrop. but i can see my iPhone and iPad in the list of devises.
im sending you a file.
Send me HAK28s-iMac.zip
If I update the bios on my Gigabyte Z370N WIFI do I need another DSDT?
hi, i have the same model, did you update to version 10? it say that is only for the new 9th generation of processors, so im not sure if its worth, do you think it is ?
[ref]digifreak[/ref], DSDT.aml.zip
Added in 30 seconds:
[ref]Traivanto[/ref], https://github.com/acidanthera/AirportBrcmFixup
Added in 1 minute 45 seconds:
[ref]artnr28[/ref], usb limit port patch don't work more, u need create one ssdt usb for u, check rehabman tutorial
Added in 20 seconds:
[ref]Florin_[/ref], Just Enjoy! :guitar
Added in 34 seconds:
[ref]artnr28[/ref], if u have a stable system, don't need
im sorry, what ? :)
i dont know how to create ssdt usb for my self, and dont know who rehabman is.
:cap:whistle
Added in 11 minutes 42 seconds:
ok, yes, i did found some info about rehabman :))) but im lost when comes to stuff like this:(
ps. on the first page of this post you have this:-FIX ERRORS AND WARNINGS
-HPET
-SATA
-DMAC
-SLPB
-DARWIN
-XHCI
-PLUGIN TYPE
-HDAS to HDEF
-HDEF
-RTC
-IRQs
-SBUS
-MIKEY
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-LAN
-USBX
-PMCR
-IMEI
-EC
-PNLF
-GFX0
-HDAU
-NVME
-ASMEDIA USB 1
-ASMEDIA USB 2
-ARPT
-INTELHDGRAPHICS
what do i do with this ?
where do i need to add this ?
[ref]artnr28[/ref], is my patches, now have more, xspi, new PMCR and others
Oi @Maldon , uma pergunta simples: é possivel aplicar o patch de um SSDT num DSDT, e ter todos os patches num só DSDT?
Eu explico melhor:
Eu tenho um Codec de Audio Conexant CX20751/2 , e atraves da AppleALC, eu e o MAicon conseguimos meter o Audio a funcionar, a excepção do microfone.
Mas após alguma pesquisa da minha parte, descobri um patch SSDT para esse codec e 1 micro ficou a funcionar, apesar de na carcaça do laptop ter dois micros.
Significa o que?
Que o micro do lado esquerdo nao funciona, mas o do lado direito sim.As pessoas conseguem ouvir-me sem problemas, e o audio funciona de boa.
Mas fiquei com essa duvida.. Para além disso, tenho também a kext CodecCommander em L/E juntamente com a LiLu, contudo também tenho uma LiLu na pasta do CLover.
Até a data não tenho tido problemas e o sistema está estável e funcional.
Contudo, gosto sempre de perguntar ao especialista e obter melhores recomendações :D
O que achas que devo fazer, ou que se pode fazer no caso do SSDT e DSDT ?
[ref]bcuraboy[/ref], só aplicat o patch da ssdt no dsdt
Added in 11 seconds:
[ref]naToo084[/ref], DSDT.aml.zip
[ref]MaLd0n[/ref], After 2 weeks of struggling i came across your work... Now i can finally install this! Couldn't even get to the installer before... Thank you! If all works out i'll send some beers :)
[ref]stucun[/ref], :guitar:guitar:guitar
