hi, this is file , and also new stuff on the screen, today the computer freezes 3 times :( , only when i try to convert 4k, 1080p videos :(
i lost all of my progress.
if you can help, i will be extremely happy.
Added in 33 minutes 11 seconds:
wow. and Preview is not responding :( ...at all , i cant open a JPG , or tiff foto.
Send me HAK28s-iMac.zip
[ref]artnr28[/ref], u need enable IntelHDGraphics in bios
CLOVER.zip
But if I do this, the Main graphics card will still work?
I did this , but the computer was frozen even on the main screen , no chance to even see the main screen...
I tried to do this many times, and ofter 5 time the computer was working ok...
I did change the settings in Bios - i changed the size of VRAM to max ...
I’m not sure if that’s the case, or it was simply luck.
And I did replace the clover with your new one from here.
I will test the computer over night.
Thanks a lot for your time
[ref]artnr28[/ref], yes, is just pra h264, hvec, for a good work
After booting to clover, different commands run for few seconds and the screen goes blank. Any idea what might be causing this? :cry:
disable auto sleep, disable hibernate, install web driver
hi, it looks like the intel its not in any use, im converting 4k video now, as we speak, but there is no activity on the intel Graphics, just a litle on ATI and CPU is up high.
any advise maybe? :)))
GVA info: Successfully connected to the Intel plugin, offline Gen95
Hardware acceleration is fully supported
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Added in 8 minutes 45 seconds:
offline Gen95 - it means thats is offline ?
[ref]artnr28[/ref], looks good
I am not able to reach the installation screen. How do I disable auto sleep?
[ref]aiham[/ref], SYSTEM PREFERENCES
aiham, SYSTEM PREFERENCES
I am trying to install mac os following the tutorial. I still haven't reached the installation screen of mac os. How am I going to have system preferences yet? :lol:
Added in 4 minutes 44 seconds:
Can you send me a clover folder for my system?
CPU: i3 8100
Motherboard: ASUS PRIME H370-PLUS
GPU: GIGABYTE GEFORCE GTX 1050 Ti
maybe that might help?
[ref]aiham[/ref], Inside Olarila images or our app have it
aiham, Inside Olarila images or our app have it
tried with the files from the app, still the same problem. After the ++++ screen, few commands run, I don't notice any error messages. And the screen goes blank. Being trying to figure what's wrong whole day. I guess it's time to give up.
[ref]aiham[/ref], checl procedure, all images is tested
yes, but its not used, its just there, how it works ? do you know? its auto ? now only RAM, CPU and ATI its busy , the intel GPU is just there....
[ref]artnr28[/ref], intel HD stay in "sleep" mode, use only for some work
u see in ioreg with Intel Accelerator
I'm having problems installing. Formatted disk correctly, but still getting "This version of macOS 10.14 cannot be installed on this computer." Trying to install it on IBM 4900-785 (INTEL CORE i3 (2120) 3,30Ghz). Is it even possible?
Attached DSDT.
DSDT.zip
[ref]friendlyfriend[/ref], use smbios iMac13,2 or iMac14,2
