Administrators MaLd0n Posted October 18, 2018 Author Administrators Posted October 18, 2018 [ref]mrbrains77777[/ref], CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mrbrains77777 Posted October 18, 2018 Posted October 18, 2018 [ref]MaLd0n[/ref], I took the clover folder and removed it and placed your folder it in the EFI Partition. The machine had issue with the graphics using the SMBIOS 18,1-3 even though they match the hardware closest. I then went to 17,1 and had the same issue (windows jump around and get distorted or it appears that cursor is clicking in places it isn't) I then removed the bios version in the SMBIOS settings and it appears to have resolved the graphic issues. I still get issues with sleep. If you sleep the machine it won't wake from sleep properly. Based on what I see it is as follows: Machine will attempt to go to sleep. the display goes off and then the machine light shows as sleeping. If you let the display sleep but then move the move before the machine sleeps (light on front flashes) then the machine will wake normally. If you let the machine sleep fully (display and machine sleep) then moving the mouse makes the machine wake (fans spin up and keyboard and mouse light up) but no display. For a brief moment whilst it is waking from sleep the keyboard responds to caps lock presses (you can see the caps lock turning on and off but after a short time it will stop responding. Fans still run full speed but display and keyboard do not respond. If you can help me fix this I will really appreciate it. Thanks
Administrators MaLd0n Posted October 18, 2018 Author Administrators Posted October 18, 2018 [ref]mrbrains77777[/ref], sleep don't work with ur GPU, forget it, buy one RX560 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mrbrains77777 Posted October 18, 2018 Posted October 18, 2018 so would you recommend if using this setup that I disable sleep? display can sleep but computer doesn't? thanks for your help
Administrators MaLd0n Posted October 18, 2018 Author Administrators Posted October 18, 2018 IntelHD Skylake+ have a several problems with sleep u can check here https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v151/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
silencieux.le Posted October 19, 2018 Posted October 19, 2018 This is what I get when try to boot to the installer Anyone facing this issue? https://youtu.be/Q_ZZBPJ_sTQ
Administrators MaLd0n Posted October 19, 2018 Author Administrators Posted October 19, 2018 [ref]silencieux.le[/ref], is a video problem, uncheck injectintel or use -x -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
silencieux.le Posted October 20, 2018 Posted October 20, 2018 injectintel Is there windows hibernate issue? Cause I saw there some warning ragarding that and then it failed
Administrators MaLd0n Posted October 20, 2018 Author Administrators Posted October 20, 2018 disable hibernate https://Olarila.com/files/Utils/disablehibernate.command.zip Video https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v151/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
silencieux.le Posted October 20, 2018 Posted October 20, 2018 disable hibernate Actually I just boot to the installer only. I ttied to disable hibernate on Windows but same issue
Administrators MaLd0n Posted October 20, 2018 Author Administrators Posted October 20, 2018 i'm talking about mac, only mac -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
artnr28 Posted October 20, 2018 Posted October 20, 2018 hi, this is most likely the best website !! i love it, thanks a lot , i have my very first hackintosh because of you ! but i have problems , with sound the link you showing here is kind of to hard for me to understand. also, when i use handbrake to convert some files, mostly 1080p, the computer freezes . 2-3 sec. after o press - start. can you help ? please also ...where do you get the file to edit with MaciSL.app i dont have anything like this. i have Radeon Pro WX 7100 8192 MB, but is there any way i can also have sound from the intel HDMI build in?
Administrators MaLd0n Posted October 20, 2018 Author Administrators Posted October 20, 2018 [ref]artnr28[/ref], post ur files RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
artnr28 Posted October 20, 2018 Posted October 20, 2018 Send me HAK28s-iMac.zip Added in 43 seconds: i will be extremely happy to pay for the help , will donate via paypal man !
Administrators MaLd0n Posted October 20, 2018 Author Administrators Posted October 20, 2018 [ref]artnr28[/ref], CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
artnr28 Posted October 20, 2018 Posted October 20, 2018 nothing , no sound from 3.5mm output , i did not checked HDMI
Administrators MaLd0n Posted October 20, 2018 Author Administrators Posted October 20, 2018 [ref]artnr28[/ref], extract new SEND_ME, we just need a correct layout-id -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
artnr28 Posted October 20, 2018 Posted October 20, 2018 ok ))) Added in 2 minutes 45 seconds: Send me HAK28s-iMac.ziphere
Administrators MaLd0n Posted October 20, 2018 Author Administrators Posted October 20, 2018 [ref]artnr28[/ref], u need use my full clover folder, reboot and extract new SEND_ME -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
artnr28 Posted October 20, 2018 Posted October 20, 2018 it works )!!!!!!! My Man !!! i have 3 analog audio outputs now:) i will buy adapter DP to HDMI, to have 5.1 sound for movies, it will work via my Radeon card ? correct ? do you also recommend some bluetooth for me, please, because the one i have build in will never work?
Administrators MaLd0n Posted October 20, 2018 Author Administrators Posted October 20, 2018 [ref]artnr28[/ref], wifi combo card broadcom4360 is good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
artnr28 Posted October 20, 2018 Posted October 20, 2018 but i have Mini ITX, i need it usb i used my m.2 ports as hard drives
Administrators MaLd0n Posted October 20, 2018 Author Administrators Posted October 20, 2018 [ref]artnr28[/ref], some ppl use it, i never test https://www.amazon.com/IOGEAR-Bluetooth-Micro-Adapter-GBU521/dp/B007GFX0PY/ref=sr_1_3?s=electronics&ie=UTF8&qid=1540076090&sr=1-3&keywords=IOGEAR+Bluetooth+4.0+USB+Micro+Adapter Added in 36 seconds: too https://www.amazon.com/GMYLE-Bluetooth-Dongle-V4-0-Dual/dp/B007MKMJGO/ref=sr_1_fkmr0_1?s=electronics&ie=UTF8&qid=1540076163&sr=1-1-fkmr0&keywords=Bluetooth+Adapter+Dongle%2C+GMYLE+Ultra-Mini+USB+CSR4.0+Class+1+Bluetooth+V4.0+Long+Range+Dongle+Wireless+Adapter -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
artnr28 Posted October 20, 2018 Posted October 20, 2018 yes, i checked this ones all ready, if i buy it, will you help me with the coding for them?
Administrators MaLd0n Posted October 20, 2018 Author Administrators Posted October 20, 2018 [ref]artnr28[/ref], is native -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
