Administrators MaLd0n Posted October 2, 2018 Author Administrators Posted October 2, 2018 Nvdia driver is correct installed? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted October 2, 2018 Author Administrators Posted October 2, 2018 u need a full dsdt patched, essentials, cosmetics, etc -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jumebri Posted October 2, 2018 Posted October 2, 2018 and for this i need donate and send u run me file?right? okay try to send on saturday
ford2201 Posted October 2, 2018 Posted October 2, 2018 -FIX ERRORS AND WARNINGS -HPET -SATA -DMAC -SLPB -DARWIN -XHCI -PLUGIN TYPE -HDAS to HDEF -HDEF -RTC -IRQs -SBUS -MIKEY -BUS1 -MCHC -ALS0 -SHUTDOWN -LAN -USBX -PMCR -IMEI -EC -PNLF -GFX0 -HDAU -NVME -ASMEDIA USB 1 -ASMEDIA USB 2 -ARPT -INTELHDGRAPHICS please from where you can patched, you can give me TXT to teach me what you need because I see you do not give all the explanation, they are there for the laptop and where are the computer
Administrators MaLd0n Posted October 2, 2018 Author Administrators Posted October 2, 2018 i don't have time for it, sorry, is a long way -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ford2201 Posted October 2, 2018 Posted October 2, 2018 and how do you find the time you will not give but agree yes to the case with txt better send to me priv with fb I can see that you are using amd from HDAU number 7 audio and then you have nvidia too
Administrators MaLd0n Posted October 2, 2018 Author Administrators Posted October 2, 2018 i create my patches, acpi specs, chipset datasheet, dump real macs... -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ford2201 Posted October 2, 2018 Posted October 2, 2018 not singla ALC887 yes kaybal please fixed yes TV monitor HDAU and HDEF please config.plist Added in 5 minutes 29 seconds: problem not run
Administrators MaLd0n Posted October 3, 2018 Author Administrators Posted October 3, 2018 u need use my clover folder for ur chipset -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ford2201 Posted October 3, 2018 Posted October 3, 2018 ALLC887 not signal I am just saying that he has HDMi connected by hdmi to television should work by signal as I have to do if it does not work
Administrators MaLd0n Posted October 3, 2018 Author Administrators Posted October 3, 2018 ALLC887 not signal I am just saying that he has HDMi connected by hdmi to television should work by signal as I have to do if it does not work "> -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jumebri Posted October 3, 2018 Posted October 3, 2018 hi maldon maybe u can help me with my system man?pls Send me Jacks-iMac.zip
Administrators MaLd0n Posted October 3, 2018 Author Administrators Posted October 3, 2018 hi maldon maybe u can help me with my system man?pls DSDT.aml.zip Added in 24 seconds: error patch dsdt BNUM https://Olarila.com/files/Utils/MaciASL.app.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ford2201 Posted October 3, 2018 Posted October 3, 2018 XI. Nvidia HDMI Audio/10.13.4 The process that enabled all Nvidia HDMI audio codecs has been disabled in 10.13.4 AppleHDAController.kext. Device-ids for natively supported Nvidia graphics cards remain and work. Supported Nvidia HDMI audio controller device ids (10.13.4 AppleHDAController): DE 10 C0 0A DE 10 94 0D DE 10 E2 0B DE 10 E3 0B DE 10 E4 0B DE 10 E5 0B DE 10 EB 0B DE 10 E9 0B DE 10 EA 0B DE 10 EE 0B DE 10 08 0E DE 10 09 0E DE 10 0A 0E DE 10 0B 0E DE 10 1B 0E DE 10 1A 0E yes signal all or intel yes signal HDMI
ford2201 Posted October 3, 2018 Posted October 3, 2018 problem IO8021AssociationJoinSnapshot why? please fixed
jumebri Posted October 3, 2018 Posted October 3, 2018 i wait mor than hour is it normal?what i must to do? Added in 6 minutes 54 seconds: okay just clikc on enter so now look at screen my nvram is error so it normal?
ford2201 Posted October 3, 2018 Posted October 3, 2018 Please not applealc sygnał HDmi what? Nvidia please
jumebri Posted October 3, 2018 Posted October 3, 2018 okay maldon i plased ur dsdt file to clover acpi patched folder then use repairpermisions and restart pc now system report is ok but i have trouble with video i have install video driver with script form this post so in process of nvidia driver install in terminal says no drivers yet and automatically installed driver 387.10.10.10.40.105 so system says i have gtx 970 graphics card with 4 gb vram so what problem i have now when i open photoshop and go in to preferences -performance photoshop can't use graphic processor?why? can someone know?maybe cos don't have nvidia web driver for mojave? p.s i have installed cuda
Administrators MaLd0n Posted October 3, 2018 Author Administrators Posted October 3, 2018 okay maldon i plased ur dsdt file to clover acpi patched folder then use repairpermisions and restart pc now system report is ok but i have trouble with video i have install video driver with script form this post so in process of nvidia driver install in terminal says no drivers yet and automatically installed driver 387.10.10.10.40.105 so system says i have gtx 970 graphics card with 4 gb vram so what problem i have now when i open photoshop and go in to preferences -performance photoshop can't use graphic processor?why? can someone know?maybe cos don't have nvidia web driver for mojave? p.s i have installed cuda is about nvidia driver, idk, but is cosmetic try it https://Olarila.com/files/Utils/nvidia-update.command.zip Added in 39 seconds: How i can install driver for it? only if u Enable IntelHD -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
tranluan1 Posted October 3, 2018 Posted October 3, 2018 Hi MaLd0n, Please help me. I can't install Mojave on my PC. Dell Vostro 3667, Mainboard H110, CPU i3-6100, Graphic Onboard HD530. I can't disable Serial Port In Bios. Bios no that option
Administrators MaLd0n Posted October 3, 2018 Author Administrators Posted October 3, 2018 press O in clover boot screen, go to graphics and uncheck InjectIntel -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jumebri Posted October 3, 2018 Posted October 3, 2018 is about nvidia driver, idk, but is cosmetic try it https://Olarila.com/files/Utils/nvidia- ... ommand.zip i try it and look on screen
