Please convert the file to DSDT.aml thank you
CLOVER.zip
dear MaLd0n,
can you help me to tidy up my DSDT's files, cos i wanna making everything working like vanilla. i worried some error logs dsdt make my hackintosh reject to activate imessages & facetime. & i asked you how to make pci card showing under system information?
i hope u give me the right patched files. thx for problem solving given
this my RunMe files to get fixing.
Send me HanZos-iMac.zip
871045312_ScreenShot2018-09-16at17_31_23.thumb.png.418282abe9e3dd53fe0260ad1ba8f36a.png
Please correct the file and thank you
Added in 3 minutes 46 seconds:
dear MaLd0n,
Thanks for the tutorial.
I have reinstalled your system.
View the file sent again, thank you very much.
u can use same previous dsdt, dsdt is a bios table
Need New DSDT, bios update.
if u have a stable bios version, don't need update
fter bios update dsdt stoped working. Updated because have a critical security. New send-me attached.
Added in 2 minutes 42 seconds:
hello, can you help me please dsdt, z170 Hero, i7 7700k, 1080gtx on install Mojave, betathanking you in advance for your excellent work
CLOVER.zip
(1.66 MiB) Downloaded 5 times
Hi,
I have some problems because I can't find the .aml file to put MaciASL to compile or I can't understand how to do it.
Next this i have some problem with nvidia web driver that doesn't load in preferencies. Thank you for your time.
Hi,
RunMe.app
Thanks in Advance!!!
Hi Maldon,
Thanks for your contribution, can you please check on my DSDT file ? I mainly have the following issues (so far) on my Gigabyte Z370 Ultra Gaming 3.
1. Audio is not working (Unless I use VoodooHDA)
2. PCI Devices are not listed in system report
3. Intel UHD 630 only shows 7MB RAM
Send me GB-Z370-UG-3.zip
Hi Maldon,
a full video solution, check here
https://www.insanelymac.com/forum/topic/335018-intel-fb-patcher-v142/
Hi MaLdOn,
I'm using HighSierra, and freshly installed Mojave by following this guide. But I got an issue with graphic card or PCI(?). And maybe some more... :(
Would you take a look my SendMe file?
Send me SC-iMac-2.zip
Hi MaLdOn,
