zeta86 Posted September 8, 2018 Posted September 8, 2018 Hi Maldon, i pasted the dsdt in patched folder, reboot and extracted new SEND_ME. What should i do next? Send me Christians-iMac.zip
Administrators MaLd0n Posted September 8, 2018 Author Administrators Posted September 8, 2018 Hi Maldon, i pasted the dsdt in patched folder, reboot and extracted new SEND_ME. What should i do next? Attachments not load, remove old SEND_ME in ur desktop, unzip DSDT.aml.zipand put in clover/acpi/patched, reboot and run our app again -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
zeta86 Posted September 8, 2018 Posted September 8, 2018 Hope i did it right this time. Send me Christians-iMac.zip
Administrators MaLd0n Posted September 8, 2018 Author Administrators Posted September 8, 2018 nope -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dan_Marshall Posted September 9, 2018 Posted September 9, 2018 Hi MaLd0n, Hope you are well mate - need some help again. Managed to get a Lenovo Thinkpad T470s and have installed High Sierra using your wonderful guide and tools. However need some of your expertise to fine tune. Attached send me files. Hoping you can help out again Donated beer money as thanks in advance. Dan Send me Macbooks-MacBook-Pro.zip
Administrators MaLd0n Posted September 9, 2018 Author Administrators Posted September 9, 2018 Hi MaLd0n, Hope you are well mate - need some help again. Managed to get a Lenovo Thinkpad T470s and have installed High Sierra using your wonderful guide and tools. However need some of your expertise to fine tune. Attached send me files. Hoping you can help out again Donated beer money as thanks in advance. Dan Hey Let's go CLOVER.zip AppleBacklightInjector.kext use in l/e for avoid some problems new send_me after reboot and tell me what not work -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dan_Marshall Posted September 9, 2018 Posted September 9, 2018 Thanks MaLd0n, System boots fine and everything appears to be working. Trackpad issues though - not as responsive as I'd like however can look into this. Also battery indicator not showing up in toolbar - unable to click in sys prefs. New file dump attached Send me Macbooks-MacBook-Pro.zip
Administrators MaLd0n Posted September 9, 2018 Author Administrators Posted September 9, 2018 Thanks MaLd0n, System boots fine and everything appears to be working. Trackpad issues though - not as responsive as I'd like however can look into this. Also battery indicator not showing up in toolbar - unable to click in sys prefs. New file dump attached u know what trackpad u have? i'll check battery -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dan_Marshall Posted September 9, 2018 Posted September 9, 2018 Thanks MaLd0n - I believe it is an ALPS however the original driver under windows was from Synaptics
Administrators MaLd0n Posted September 9, 2018 Author Administrators Posted September 9, 2018 Thanks MaLd0n - I believe it is an ALPS however the original driver under windows was from Synaptics have this version by Dr. Hurt VoodooPS2Controller.kext.zip and have it too ApplePS2SmartTouchPad.kext.zip is just a correct kext for work good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted September 9, 2018 Author Administrators Posted September 9, 2018 will check now and report use it, avoid usb errors DSDT.aml.zip battery don't have patch, we need check it Added in 8 minutes 29 seconds: battery try it SSDT-BATC.aml.zip and add it in boot args abm_firstpolldelay=16000 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dan_Marshall Posted September 9, 2018 Posted September 9, 2018 Using the Aplpeps2Smart kext and no change. Using the voodoo kext resulted in no trackpad usage at all. Using Appleps2 kext with new DSDT. Dump files attached Trying SSDT now Added in 5 minutes 31 seconds: Added in 8 minutes 29 seconds: battery try it SSDT-BATC.aml.zip (1.07 KiB) Downloaded 1 time and add it in boot args abm_firstpolldelay=16000 No change unfortunately Send me MacBook-Pro-2.zip
Administrators MaLd0n Posted September 9, 2018 Author Administrators Posted September 9, 2018 Using the Aplpeps2Smart kext and no change. Using the voodoo kext resulted in no trackpad usage at all. Using Appleps2 kext with new DSDT. Dump files attached Trying SSDT now Added in 5 minutes 31 seconds: MaLd0n wrote: ↑ Added in 8 minutes 29 seconds: battery try it SSDT-BATC.aml.zip (1.07 KiB) Downloaded 1 time and add it in boot args abm_firstpolldelay=16000 No change unfortunately if dont work remove ssdt check here some info https://www.insanelymac.com/forum/topic/315451-guide-lenovo-t460-macos-with-clover/ have a similar files for t470p, is a very personal files, trackpad and battery Arquivo Comprimido.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dan_Marshall Posted September 10, 2018 Posted September 10, 2018 Thanks MaLd0n - I will do some research on this and see what I can come up with. Enjoy the beer
Administrators MaLd0n Posted September 10, 2018 Author Administrators Posted September 10, 2018 Thanks MaLd0n - I will do some research on this and see what I can come up with. Enjoy the beer for battery, rehabman have one https://www.tonycrapx86.com/threads/guide-how-to-patch-dsdt-for-working-battery-status.116102/ have one Slice kext too, VoodooBattery check here about lenovo notebooks, have a amazing tuto, files etc https://www.insanelymac.com/forum/topic/285678-lenovo-thinkpad-t420-with-uefi-only/?page=20&tab=comments#comment-1952283 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
lem120 Posted September 12, 2018 Posted September 12, 2018 Hi MaLdOn, here's my DSDT Thank you for your work and enjoy your beer Send me iMac-di-Mario.homenet.telecomitalia.it.zip
Administrators MaLd0n Posted September 12, 2018 Author Administrators Posted September 12, 2018 Hi MaLdOn, here's my DSDT Thank you for your work and enjoy your beer CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
StevenToast Posted September 14, 2018 Posted September 14, 2018 Hi, I'm trying to run the Run Me app and I permanently get in High Sierra 10.13.6 (I also added Run Me in Settings/Security & Privacy/Privacy - Allow these apps to control your computer, but the result is the same): IOREG dump failed. Retrying Increased delay x2 for IOREG dump. This will take a while...(33 sec) I get to save the IOREG file, but for some reason it is not passing on. I attached the files anyway, maybe IOREG dump was the last step in diagnostics. Patched bios, Asus P8Z68-V pro (first edition, not Gen3), i7-2600K. I can boot, I can run High Sierra, sleep is taking 2-3 minutes to wake up from and the CPU overclock is not working properly: the frequency on Intel Power Gadget jumps only between 1.6 GHz - 3.0 GHz - 4.4 GHz (4.4 is the max I set in BIOS). I tried generating SSDT with SSDT Automator but as soon as I put it in EFI drive, the boot hangs. Will a proper DSDT help my case? send_me.zip
asheq Posted September 14, 2018 Posted September 14, 2018 have a problem with the runme.app program After the file is extracted it appears as a zip. send asheq-iMAC.zip How do I install the file via MaciASl?
Administrators MaLd0n Posted September 14, 2018 Author Administrators Posted September 14, 2018 Asus P8Z68-V pro CLOVER.zip try generate one ssdt with overclock Added in 42 seconds: have a problem with the runme.app program After the file is extracted it appears as a zip. send asheq-iMAC.zip How do I install the file via MaciASl? "> -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
StevenToast Posted September 14, 2018 Posted September 14, 2018 try generate one ssdt with overclock Thank you for getting back to me, I tried two times only with overclock enabled in bios (100 x 44) for a total of 4400 MHz overclock speed. I suppose I should try with stock speeds. Anyway, I have he computer doing some encoding for another hour or so, so I can't try anything right now but I'll be back.
asheq Posted September 14, 2018 Posted September 14, 2018 How do I install the file send asheq-iMAC.zip via MaciASl? Thank you
Administrators MaLd0n Posted September 14, 2018 Author Administrators Posted September 14, 2018 no, is a full dump, not bios table -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
asheq Posted September 14, 2018 Posted September 14, 2018 Sorry for the inconvenience that I did not understand how to use MaciASl
