SuiteBench AI - Universal AI Benchmark for macOS with publish results
We are pleased to announce the release of SuiteBench AI, a free AI benchmarking application for macOS.
Donations Link HERE or HERE
SuiteBench AI was created to provide a practical and consistent way to measure AI-related performance across both Apple Silicon and Intel-based Macs, including systems with discrete GPUs.
Rather than generating a simple synthetic number, SuiteBench AI executes multiple computational workloads across the available CPU, GPU, Metal and Core ML paths and combines the measured performance into an easy-to-compare Global AI Score.
Main Features
  • Universal macOS application — Apple Silicon + Intel x86_64
  • CPU AI workloads
  • Metal GPU compute workloads
  • Core ML acceleration
  • Apple Neural Engine support when available
  • Automatic backend selection
  • Quick AI benchmark
  • Complete AI benchmark
  • Extended AI benchmark
  • AI Stress mode
  • Global AI Score
  • Detailed local benchmark results
  • Hardware and system information
  • Real-time benchmark visualization
  • Light and Dark Mode support
  • Integrated AI Assistant
  • Optional downloadable local AI models
  • Local AI engine management
  • AI-assisted benchmark interpretation
  • Online public result database
  • Global hardware rankings
  • Search by CPU, GPU, Mac model or public result ID
  • Compact and lightweight online result publishing
  • SHA-256 result integrity identification
  • Privacy-focused publication
  • Free to use
SuiteBench AI includes an integrated AI Assistant designed to help users understand benchmark results instead of simply presenting raw scores.
The assistant can analyze the current benchmark session and provide additional context about the measured performance.
It can help interpret:
  • Global AI performance
  • CPU performance
  • GPU performance
  • AI acceleration behavior
  • Benchmark categories
  • Strong and weak areas of the tested system
  • Performance differences between available backends
  • Diagnostic benchmark conditions
  • Overall hardware balance
This makes SuiteBench AI not only a benchmarking application, but also an interactive performance analysis tool.
The idea is simple:
Benchmark the machine. Then use AI to understand the benchmark.
Optional Downloadable Local AI
Users who want a more advanced AI experience can optionally download and use additional local AI models directly from SuiteBench AI.
These models are completely optional and are not required to run any benchmark.
The application allows the user to manage the local AI environment, select supported models and use them with the SuiteBench AI Assistant for deeper analysis and conversation.
Features include:
  • Optional AI model downloads
  • Model selection directly inside SuiteBench AI
  • Local AI engine installation and management
  • Starting and stopping the selected local AI
  • Local benchmark analysis
  • More advanced result interpretation
  • No dependency on an external AI model for benchmarking
The benchmark system remains completely independent from the downloadable AI models.
Users who only want to benchmark their hardware can use SuiteBench AI normally without downloading any additional AI model.
Users who want deeper analysis can enable a local AI model and turn SuiteBench AI into a more advanced hardware analysis assistant.
Local-First AI Design
When a downloaded local AI model is used, the model runs through the local AI engine on the Mac.
The AI Assistant and the online benchmark database are separate systems.
The optional local AI model is used to analyze benchmark information locally. It does not become part of the public benchmark upload.
The SuiteBench Browser receives only the compact benchmark result that the user explicitly chooses to publish.
SuiteBench Browser
SuiteBench AI includes optional integration with SuiteBench Browser, the public benchmark database developed by DNMTechLabs.
After completing a benchmark, users can manually publish their result and receive a unique public identifier such as:
SB-AI-XXXXXXXXXXXXXXXX
Published results can then be compared through the online Global AI ranking.
The leaderboard is automatically ordered from the highest Global AI Score to the lowest, making it easy to compare different processors, GPUs and Mac configurations.
The public result contains only information directly related to the benchmark, including:
  • Global AI Score
  • CPU
  • GPU
  • Mac model identifier
  • Architecture
  • macOS version
  • Benchmark mode
  • SuiteBench AI version and build
  • Benchmark methodology version
  • SHA-256 integrity hash
The online result format is intentionally compact and lightweight.
Privacy First
Online result publication is completely optional and manual.
SuiteBench AI does not include personal files or personal account information in the public benchmark result.
The result publication system is designed specifically around benchmark-related technical information.
Personal information such as the following is not part of the public result capsule:
  • Username
  • Computer name
  • Serial number
  • MAC address
  • Apple ID
  • Local file paths
  • Personal files
  • Raw benchmark latency samples
  • Detailed raw workload evidence
Before publication, SuiteBench AI shows the technical information associated with the result being submitted.
Lightweight Online Publishing
The online publication architecture was intentionally redesigned to remain extremely lightweight.
Instead of uploading large benchmark datasets containing thousands of latency samples and individual workload records, SuiteBench AI creates a compact result capsule containing only the information required for the public result and ranking.
A normal result payload is typically only a few hundred bytes.
This approach reduces:
  • Network traffic
  • Server processing
  • Database usage
  • Upload failures
  • Backend complexity
while keeping the public benchmark database fast and easy to maintain.
Benchmark Reliability
SuiteBench AI includes multiple mechanisms designed to improve consistency and usability across different hardware.
These include:
  • Benchmark warm-up phases
  • Repeated measurements
  • Latency stability analysis
  • Thermal-state monitoring
  • Automatic backend calibration
  • Native execution detection
  • Diagnostic workload handling
  • Resilient Global AI scoring
An unavailable or problematic individual workload does not unnecessarily invalidate an otherwise usable completed benchmark.
If a benchmark finishes successfully and produces meaningful performance measurements, SuiteBench AI preserves the usable data and calculates the best meaningful Global AI result available from that run.
Supported Hardware
SuiteBench AI is designed to support a wide range of macOS systems, including:
  • Apple Silicon Macs
  • Intel Macs
  • Integrated GPUs
  • Discrete AMD GPUs
  • Metal-capable GPUs
  • Apple Neural Engine capable systems
Available acceleration paths and performance naturally depend on the hardware and macOS configuration.
Free Software
SuiteBench AI is free.
Our goal is to provide the macOS community with a useful AI performance benchmark and gradually build a public database that makes it easier to compare CPUs, GPUs, Mac generations and AI acceleration technologies.
No account is required to run the benchmark.
Online result publication is optional.
Download HERE
SuiteBench AI 1.1
Developer: DNMTechLabs
Platform: macOS
Architecture: Universal — arm64 + x86_64
Price: Free
Online Database: SuiteBench Browser
Benchmark your Mac, compare your hardware, explore the public rankings and, if you want deeper analysis, use the integrated AI Assistant or an optional downloadable local AI model.
DNMTechLabs — Building practical tools for the macOS community.
