Hi everyone, I'm currently having a few issues with my device: the battery always shows as fully charged (I've tried various kexts but couldn't get it working), I can't adjust the brightness via the keyboard, and my processor seems to be running inefficiently—my laptop runs smoothly in Windows, but it feels a bit laggy and slow in Sequoia. I've included links to my EFI and config below for anyone who can help; thanks a lot, everyone.
EFİ: https://drive.google.com/file/d/1tkEOBnm1TowIcbIXyyeMA8EFABPfXw6i/view?usp=sharing
Config ; https://drive.google.com/file/d/1wxjMHGl9SZ9dWssXZhdTZhDKdKVzD-79/view?usp=sharing
Edited by Ali Arslan
18 hours ago, MaLd0n said:
Hello, the kext you mentioned is actually already installed in the EFI setup I linked above, yet I couldn't get it to work. I had a similar issue with the audio; it only started working correctly in macOS after I booted into Windows and disabled the Dolby Audio effects program.
(dualboot-HDAUniversal) By the way, I have your .aml file in my ACPI folder—thank you.
Edit : I've discovered something new: when I put the device into sleep mode and try to wake it up, a black screen appears, but the display doesn't come on... I would really appreciate your help with this issue as well.
This laptop is perfect. All working. I create one asussmc with automatic fan speed, create one layout 171 for hda universal. Just work nice cam, etc.
Yes but my audio gone again and sleeping mode ,battery percantege i cant fixed can you help me about this please
On 8/13/2026 at 4:02 PM, MaLd0n said:
hello maldon can you help me please i am student ,really don't have the financial means to make a donation. I'm trying to use a Mac because of Xcode.
casper s500 (i5-10210u, uhd graphics,realtek alc255 (soundcard)
i forgot to write my specs.
