newdoodle Posted May 24, 2017 Posted May 24, 2017 Hi, Newbie here I installed yosemite on my laptop but there is no audio. Following are the device ids for my audio chipset. I will really appreciate it if you guys can help me out. Name - Intel High Definition Audio Vendor Id - Device Id 111D - 76D9 The compatible Ids are - 8086 - 1E20
Administrators MaLd0n Posted May 24, 2017 Administrators Posted May 24, 2017 VoodooHDA.kext-2.9.0d10.zipuse voodoohda -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
newdoodle Posted May 27, 2017 Author Posted May 27, 2017 [attachment=0]VoodooHDA.kext-2.9.0d10.zip[/attachment]use voodoohda I used it but the volume is too low I applied the half volume fix but still nothing
Administrators MaLd0n Posted May 27, 2017 Administrators Posted May 27, 2017 what ur audio codec? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
newdoodle Posted May 27, 2017 Author Posted May 27, 2017 what ur audio codec? Intel 7th series chipset High Definition Audio
Administrators MaLd0n Posted May 28, 2017 Administrators Posted May 28, 2017 Alcxxx e.g in my x99 have a alc1150 need correct codec -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
newdoodle Posted May 28, 2017 Author Posted May 28, 2017 Alcxxx e.g in my x99 have a alc1150 need correct codec Codec: IDT 92HD87B2/4
Administrators MaLd0n Posted May 28, 2017 Administrators Posted May 28, 2017 u can try a AppleAlc kext, id 12 work for ur codec -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
newdoodle Posted May 29, 2017 Author Posted May 29, 2017 Never mind I fixed it. I removed voodoohda, patched applehda and reinstalled voodoohda. Now my audio is working fine. I need help with wireless though. My broadcom card is not recognised , Vendor ID - 14e4 Device ID - 4727 NAME - Broadcom 4313 wireless
EddieSjet Posted June 8, 2019 Posted June 8, 2019 NГЈo seria um Aplicativo responsГЎvel por gravar o Audio do computador nГЈo? kext universal para Audio Г© VoodooHDA.
