Hardware:
  • Laptop: ASUS ROG Flow X13 GV301QE
  • CPU: AMD Ryzen 9 5900HS
  • Wi-Fi/Bluetooth: Intel AX200 (USB VID:8087 PID:0029)
  • macOS: Ventura 13.7.8
  • OpenCore: 1.0.7
  • SMBIOS: MacBookPro16,3
Current status:
  • Wi-Fi works correctly.
  • Battery and audio are fixed and working.
  • Bluetooth USB controller is detected:
    • Vendor ID: 0x8087 (Intel)
    • Product ID: 0x0029
    • Built-In: Yes
  • Bluetooth can be turned ON in System Settings.
  • Mac becomes discoverable (“This Mac is discoverable as …”).
Problem:
  • Nearby Devices always remains empty.
  • No devices are discovered (mouse, headphones, phone).
  • Bluetooth behaves like a “phantom” device: it is ON but performs no scanning or pairing.
Diagnostics:
  • system_profiler SPUSBDataType shows Intel Bluetooth controller correctly.
  • ioreg shows IntelBluetoothFirmware and IntelBTPatcher loaded.
  • Bluetooth logs contain NoBLEScan.
  • Previously I also saw:
    • Address: NULL
    • State: OFF
    • Bluetooth Power State: deadbeef
    • Chipset: BCM_4350C2
Things already tried:
  • Reset NVRAM
  • Different versions of IntelBluetoothFirmware
  • Different combinations of:
    • IntelBluetoothFirmware.kext
    • IntelBTPatcher.kext
    • BlueToolFixup.kext
    • IntelBluetoothInjector.kext
  • Rebuilt USB mapping and verified Bluetooth USB port
  • Updated OpenCore and kexts
  • Lilu stable version (1.7.2).
Has anyone managed to get Intel AX200 Bluetooth fully working on an ASUS ROG Flow X13 GV301QE (Ryzen 9 5900HS) running Ventura?
kmutil showloaded | grep -i -E "intel|blue"
com.zxystd.IntelBluetoothFirmware
com.zxystd.IntelBTPatcher
as.vit9696.BlueToolFixup
Address: NULL
State: OFF
Chipset: BCM_4350C2
Edited by Varo
Update bluetooth kexts. These kexts work good.
My IntelBTPatcher is 2.5.0
IntelBluetoothFirmware is 2.5.0
And BlueToolFixup - 2.7.2
