iCpu for macOS: Advanced Hardware Information, SMBIOS, Memory, Graphics and Benchmark Utility
iCpu is a modern macOS hardware information utility created for users who want a clear, fast and organized view of their system.
Built with a native macOS interface and a dark metallic glass design, iCpu helps you inspect CPU, cache, mainboard, memory, SPD, graphics and benchmark information in one place.
Download iCpu for macOS HERE
Anyone who would like to support the project with donations is very welcome and greatly appreciated. Link HERE or HERE
iCpu is a modern hardware information utility for macOS, designed for Mac users, Hackintosh users, technicians and hardware enthusiasts, with a clean dark metallic glass interface, native system reading, organized tabs and fast access to CPU, cache, mainboard, memory, SPD, graphics and benchmark information.
The app shows processor name, vendor, architecture, cores, threads, frequency, instruction flags, cache data, motherboard information, firmware details, macOS SMBIOS, board ID, system UUID, serial number with hide/show control, memory size, memory type, memory speed, populated slots, memory pressure, dynamic SPD module information, GPU details, Metal support, connected displays and quick benchmark results.
iCpu supports Intel, AMD and Apple Silicon systems, filters generic or misleading memory values, ignores empty memory slots, separates physical hardware data from macOS SMBIOS identity, and can use optional dmidecode data when available for deeper DMI and SMBIOS inspection.
Built for local diagnostics, system validation, OpenCore checking, hardware comparison and troubleshooting, iCpu reads system information through macOS tools such as sysctl, system_profiler, ioreg, vm_stat and memory_pressure, without requesting camera, microphone, contacts, calendar or location access.
If you need a native macOS app to inspect CPU, memory, SPD, graphics, SMBIOS, motherboard, firmware and benchmark information, iCpu provides a fast, clean and practical hardware dashboard.
  • Like 5
  • Thanks 1
