[Help] RX 6700 XT (Navi 22) Black Screen with Visible Cursor on macOS Tahoe (Using NootRX)
Hi MaLd0n,
I successfully managed to install macOS Tahoe 26.5 onto a new partition from my working macOS Sequoia setup. However, I am currently stuck on a very specific display issue.
After completing the installation, the system boots fine, but right where the setup/desktop should appear, I get a completely black screen, but the mouse cursor is visible and moveable.
My Hardware Specs:
https://limewire.com/d/14Mz4#k5dYxsARHB
-Delete old EFI folder and paste new then empty trash. Don't use merge files.
-Don't use Drag and Drop into EFI partition. Use Copy/Paste instead.
-Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen.
DON`T ENABLE FILE VAULT
