Dofik Dofran Posted May 12 Posted May 12 I am with laptop Acer Aspire 3 A315-59 and my cpu is Intel Core I5-1235U with Iris Xe graphics, and i wanted to hackintosh my laptop. I tried ready clover installers from MacWin, this doesn`t work. I tried to create my opencore folder, tried opencore efi from olarila, nothing work, it stucks at [EB|#LOG:EXITBS:START] (the kernel starts).
Administrators MaLd0n Posted May 16 Administrators Posted May 16 Try with HT disabled -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dofik Dofran Posted May 25 Author Posted May 25 On 5/16/2026 at 1:28 PM, MaLd0n said: Try with HT disabled In my BIOS i didn't have a hyper-threading option
Administrators MaLd0n Posted May 25 Administrators Posted May 25 I think is a hide option. extract ACPI and usb kext on windows with USBTOOLBOX https://olarila.com/topic/37827-hackintosh-remap-usb-with-usbtoolbox-windows-or-macos/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dofik Dofran Posted May 27 Author Posted May 27 On 5/25/2026 at 8:54 PM, MaLd0n said: I think is a hide option. extract ACPI and usb kext on windows with USBTOOLBOX https://olarila.com/topic/37827-hackintosh-remap-usb-with-usbtoolbox-windows-or-macos/ usb.zip
Administrators MaLd0n Posted May 27 Administrators Posted May 27 Where acpi? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dofik Dofran Posted May 27 Author Posted May 27 usbtoolbox generated only kext, maybe generated froSSDT-USBX.zipm ssdttime? i attached it for
Administrators MaLd0n Posted May 28 Administrators Posted May 28 full acpi tables -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dofik Dofran Posted May 28 Author Posted May 28 Just now, MaLd0n said: full acpi tables and for be sure there is ssdt`s SSDT-HPET.zip
Administrators MaLd0n Posted May 28 Administrators Posted May 28 Try thisEFI.zip -Delete old EFI folder and paste new then empty trash. Don't use merge files. -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead. -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dofik Dofran Posted May 28 Author Posted May 28 Just now, MaLd0n said: Try thisEFI.zip -Delete old EFI folder and paste new then empty trash. Don't use merge files. -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead. -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen. still no result
Administrators MaLd0n Posted May 28 Administrators Posted May 28 Use debug and check what happens -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Dofik Dofran Posted May 28 Author Posted May 28 Just now, MaLd0n said: Use debug and check what happens opencore-2026-05-28-163531.zip
Dofik Dofran Posted Tuesday at 09:49 AM Author Posted Tuesday at 09:49 AM On 5/28/2026 at 7:51 PM, MaLd0n said: Use debug and check what happens did you find something?
