Need help installing Lion
Bertjj
Hello,
I got Lion running on my laptop, but it's not working properly (i think)
Lion boots just fine, but it laggs, the graphics aren't good. I think qe/ci is not enabled.
When i disable AppleIntelHDGraphics.kext and AppleIntelSNBGraphicsFB.kext the system is "working" but when i enable them the system gives this error: Transcript Offline - Buffer pool allocate [181000] failed
(I disable them by editing the .plist via transmac, and when i repair permissions (and of course reverting the edit) the system gives this error, even when i use kexthelper to install fresh ones)
So now i want to reinstall, i'm using myHack, since I only can boot that way. I want to use my extracted DSDT, do i need to make any changes in my DSDT?
How do I add kexts? just using kexthelper b7?
My system:
Core i7 2630 QM with Intel HD 3000 graphics
GT540M (it's not supported)
Atheros ar9002wb-1ng WiFi card (i now can use it, so i have that kext)
and i thought ALC269 sound card. Got it working now with a modified kext
Link to comment
Share on other sites
Hello,
My system:
to install kext use that utility http://www.insanelymac.com/forum/index.php?showtopic=253395
the dsdt only use if properly edited, if not don't use.
try to use chameleon branch Chimera 1.5.4 to boot giving support to yours graphics .
Link to comment
It compiled propperly i think, it only gave 2 warnings, no errors.
How do i get that branch of Chimera? nawcom gave me a boot.zip, just put that boot file in / of my osx installation?
Link to comment
chimera
http://tonycrapx86.blogspot.com/2011/09/chimera-154-update-facetime-fix.html
about the dsdt if compile no errors, copy to extra or / and remove nullcpupowermanagement
the boot file must be /
good luck
Link to comment
Hi i also have the same processor and garphics card plz help me how to install the lion I tried by booting in verbos mode and it hangs in (ntfs volume name version 3.1).my specificatio of laptop are-i7 2630 ,graphics optimus enabled nvidia gt540 m and intel hd 3000 and my Laptop is intel r sandy bridge mobile graphics accelerated integrated vga bios. Always it says to restart after booting some time in normal boot after apple logo appear.
Link to comment
