Tahoe installation problem Asus Z170M-Plus - i5 - rx 560 4gb
Disable weg
Ur card rx560 is native
you have to disable  watevergreen.kext,   -->Located EFI/OC/kexts
 wegnoegpu  you mentioned is a boot arg !    --> located in config plist ( nvram)
Edited by Papawankenobi
Hi, sorry, I misunderstood. 🙂
Now I managed to install, but I can't mount the EFI; I see it doesn't exist. And I reinstalled Tahoe twice in GUID and APFS. Where am I going wrong?
Need expert help with your Hackintosh?
Get professional Olarila support for:
Support us - Donate HERE
