alidzcom Posted September 25, 2025 Posted September 25, 2025 Hello everyone I hope you are all well I created a macOS Tahoe boot drive with (EFI.Desktop KabyLake ) and when I launch the installation with the USB drive, it reboots Please help me resolve this issue. Thank you very much. Carte mère asus MAXIMUS VIII HERO Processeur i7-7700K CPU @ 4.20GHz graphique AMD Radeon RX 580 8Go RAM 16 Go Canal-Double DDR4 3000 MHz Crucial Réseau: Intel(R) Ethernet Connection (2) I219-V config.plist.zip
Administrators MaLd0n Posted September 25, 2025 Administrators Posted September 25, 2025 disable whatevergeen 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
alidzcom Posted September 26, 2025 Author Posted September 26, 2025 Thank you for your help. The installation problem has been solved. But the sound is not working. Is there a solution to this problem? Thank you.
Administrators MaLd0n Posted September 26, 2025 Administrators Posted September 26, 2025 https://olarila.com/forum/111-tahoe-26/ 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
alidzcom Posted September 26, 2025 Author Posted September 26, 2025 Thank you for helping me, the sound problem has been solved. Thank you, thank you.
