Ludovic Vienne Posted November 7, 2025 Posted November 7, 2025 Does not work with the latest version 26.1 build 25B78
adv_j Posted November 10, 2025 Posted November 10, 2025 Successfully upgraded to 26.1 and installed KDK from 26.0. Now the system is loaded only in safe mode (-x). No application is running. The system says that the launch is not possible because the system is 26.0 and the application is for 26.1. What should I do? Where can I get at least a terminal for 26.0?
Ludovic Vienne Posted November 12, 2025 Posted November 12, 2025 I have this message An error occurred during installation: XPC error: Couldn’t communicate with a helper application. Capture d’écran 2025-11-12 à 08.55.26.zip
Administrators MaLd0n Posted November 12, 2025 Author Administrators Posted November 12, 2025 @Mirone -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Alexsander Fernandes Posted November 15, 2025 Posted November 15, 2025 This helped me fix the problem I was having here.
Ludovic Vienne Posted November 21, 2025 Posted November 21, 2025 On 11/15/2025 at 8:49 PM, Alexsander Fernandes said: This helped me fix the problem I was having here. Thank you so much, it works perfectly.
Joeytic Posted November 21, 2025 Posted November 21, 2025 I need to know how to fix it using APPLEALC since I want native audio on my Hackintosh as I use a condenser microphone and I record using the pc sound card I tried voodooHDA but the sound quality is NOT good and it keeps distorting the mic with this static noise like you can never hear anything else so I need smth that works with Tahoe 26.0.1 please and thank you
Alexsander Fernandes Posted December 14, 2025 Posted December 14, 2025 (edited) On 11/15/2025 at 4:49 PM, Alexsander Fernandes said: This helped me fix the problem I was having here. Now isnt working again after update to 26.2 - speakers sound works fine, but headphones not... EDIT: Working using this Edited December 16, 2025 by Alexsander Fernandes
troyboy77 Posted December 15, 2025 Posted December 15, 2025 On 9/21/2025 at 1:22 PM, Sequoia24 said: After installing the KDK my system broke and no longer boots. I have the most recent version of Tahoe installed. I don't understand what's causing it to fail. You have the wrong kdk version check to make sure you have same version as your version of Tahoe it should be 26,1.
