Easy audio solution on Hackintosh on macOS Tahoe
Easy audio solution on Hackintosh on macOS Tahoe with VoodooHDA
Thanks and credits to @Slice
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
-Why Olarila doesn't support TonyMac, Reedit, Little-Translated and others HERE
1- Remove AppleAlc and use correct SIP value then reboot and Reset Nvram
SIP Clover  0x803
SIP Opencore  03080000
2- Dowload this pack HERE
3- Add device properties for your audio codec(Example: if you used alcid=12 on AppleAlc, use layout-id 12 on device properties with patch bellow.)
For correct device patch check HERE
Quote
<key>PciRoot(0x0)/Pci(0x1F,0x3)</key>
            <dict>
                <key>layout-id</key>
                <integer>12</integer>
            </dict>
4- Install VoodooHDA.prefPane
5- Now just run VoodooHDA.pkg and give permissions in Privacy & Security then reboot
We're all here to have fun and learn from each other! That's all Folks!
Credits:
Slice, rdmitry0911, max.1974, Rodion Shingarev, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad, headkaze, onemanosx, erroruser, Jenny David, Sampath007, Facebook Hackintosh community, Facebook Olarila community and many, many, many others!
  • Like 2
  • Thanks 3
I am Hardware ... Asus Prime Z590-P Intel i7-10700KF GPU Sapphire RX 6600 Pulse Opencore 1.0.5
I have Amd RX 6600 vga and I get image + sound from displayport in MacOS Tahoe Beta 2
Arşiv.zip
Edited by mavisakal_tr
2 hours ago, AbuAbdullah said:
How to input the correct SIP value
Nvram tab
On 7/15/2025 at 9:20 AM, Fabiano X said:
can works also in sequoia for my s1220 ?
Yes, it will work.
1. i5-13400, MSI PRO B760M-P DDR4, BIOS 1E, MSI RX570, ALC897 (VoodooHDA), Tahoe 26.3.1, Sequoia 15.7.4, ArchLinux 6.18, Clover 5171
2. ASUS X200CA, Pentium 2117U, 4GB, HD2500 (Software OpenGL), Mojave 10.14.6, ArchLinux , Clover5162
3. Huananzhi X79M-PRO, Xeon E5-2650v2, RX570, ALC887, RTL8111F, macOS 12.6, 10.14.6, Win10, multiboot by Clover 5150
4. GA 965P-S1, E6300 Conroe, Radeon HD5570, ALC888, OS⌘ 10.11.6 (15G22010), Clover 4928. Still working.
Since last time i got scolded by ask something in Portuguese in a english topic (even if you can understand Portuguese @MaLd0n), I will ask in English here...
Anyway, I have it successful installed the Tahoe in my potato pc. I kind fix the audio using your tutorial above, and the audio works fine but just in the speaker.  In the Headphones the audio is weird (like those low quality microphone sounds), but just in the Tahoe (the sound was ok on the Sequoia, I tested it again on a Linux that I have here and it's ok)
Also, My-Audio-ID.app returns me some values, but My-Audio-Coded.app says: "No audio codec detected!!"
I did some research and didn't find any fix to that because all the tutorials are the same from here or are "paid" and I can't afford the price required. Also, I have tested this bellow, but is the same thing.
Can you provide me with some guidance?
Hi everyone!
I'm facing a very strange behavior here haha
My hardware is a Lenovo IdeaPad Gaming 3i, with an Intel i5 10300H, with an Intel UHD 630 as iGPU and GTX 1650 as dGPU.
Everything was working perfectly on Sequoia, but, when I updated to Tahoe, audio stopped working. I followed this guide, but it doesn't helped. Still not working. The strange part is that macOS is now recognizing GTX's HDMI output as an available audio device (??). Embedded laptop speakers doesn't work, even 3mm jack headphones aren't working.
I didn't tried connecting an external display to HDMI port yet. But, as far as I know, the HDMI port is physically connected to dGPU.
My entire EFI is available at https://github.com/rbfraphael/efi-lenovo-gaming-3i/tree/sequoia
I'm using the exactly Sequoia EFI on Tahoe, just changed the SIP value to 850A0000 and disabled AppleALC, as per described on this thread.
Use MyKextInstaller. Check our tutorial.
On 10/3/2025 at 11:07 PM, MaLd0n said:
Use MyKextInstaller. Check our turorial.
Where is this tutorial?
The one with voodooHDA didn't work.
Just found about MykextInstaller in insanelymac and it worked!
Edited by asapreta
Hacks:
Main:
Gigabyte Z390 Gaming X  - Intel i5 9400F - 16 GB DDR4 2666 - Radeon RX 570 4GB - Tahoe 26.0.1
Backup: Gigabyte EP-45-UD3R - Intel Core2Quad 9550 @4.0Ghz - 8 GB DDR2 - GeForce 9800GT - Sierra
Thanks! It worked perfectly.
Also, for someone that has this laptop too (Lenovo IdeaPad Gaming 3i), I've put my EFI on GitHub, with a separate branch for Sequoia and another for Tahoe.
Edited by RBFraphael
Damn dude, you’re a lifesaver! I struggled with AppleALC the whole day, tried everything, nothing worked. Then I found your guide, followed it step by step, and miracle of miracles my sound finally works
I have an output of 5.1 Ch, but I need stereo. Only the sound of music in trailers in AppleTV is hearable, but not the sound of vocals. The sounds in YouTube are fine music and vocals. How to change the output to stereo?
Edited by RedBirdiii
Follow this tutorial or use VoodooHda
Update first post with new VodooHDA way
  • Thanks 1
Big Thanks @MaLd0n Working perfectly my friend!! 😃
Gigabyte Aorus Z790 Elite AX / Raptor Lake 13th Intel® Core™  13900K / AMD AORUS RX 6900 XT  2 rev. / Lenovo E470 i5-7200-U Kaby Lake iGPU intel HD620 64 GB Ram / ASUS Prime B365M-K Desktop intel i3-Coffe Lake / ASUS Sapphire Nitro+ AMD RX 580 4GB / Gigabyte B360 i5-Coffe Lake / RX 64 Vega OC Gigabyte / Gigabyte B660 Raptor Lake 13th Intel® Core™ i7-13700K  / Nvidia GeForce GTX 3060 Gainward 12GB /  Gigabyte Z170 XP SLi  Intel® Core™ i7  iGPU /  Mac mini M4 Pro 12/16  24 GB Ram  512 GB Nvme /   MacBook Air 2020 10th Ice Lake Intel® Quad-Core™ i7-1060NG7 T2  Iris Plus Graphics  /  Clover Hacky Color 5161  / Opencore 1.0.4 /  God Bless you!
